Question about GE JE1660 Microwave Oven
GE Profile JE1660GB01 magnetron failure?
I have a 2001 GE microwave oven model JE1660BG001 which stopped working (loud hum with no heat) in 2004. Even though the magnetron appeared to pass the basic resistance test (less than one ohm across filament terminals and infinity terminal to ground) GE replaced it under warranty and that fixed the problem.
Now I'm having the same problem (loud hum with no heat) but this time the microwave wasn't turned off in time and the H.V. transformer fried. I replaced the transformer but still have the same loud hum which leads me to believe the magnetron is bad again. When I tested the magnetron using the resistance test I mentioned earlier it appears to pass like the first one that GE replaced.
Anyway, here's my question...
Is there a better way to test a magnetron to determine if it's bad and is there a replacement magnetron that's engineered better than the original? I understand there is a high failure rate on the Samsung OM75P(31) magnetrons?
Thank you in advance,
Always Broke.
  • 1 more comment
  • AlwaysBroke2 Jan 17, 2008
    Thanks for the advice. I'll test the diode and if that's not it I'll probably just replace the magnetron. There's too much at stake to mess with that much voltage.
    Thanks again for the help!
  • hollyts Nov 08, 2008
    I think I have the same problem. Can anyone tell me about how much it should cost to replace the transformer? Thanks!!
  • Anonymous Mar 29, 2014
    GE model PEB2060DM1CC Magnetron checks out. How can one check the hi-voltage transformer?
  • GE Master
  • 9,098 Answers
It pass the resistance tests and still be bad, and I suspect it is.
I would also suggest that you check the high voltage diode to be sure it's not shorted.
If the filament voltage and high voltage are both present at the magnetron terminals, and not loaded down, but there is no heat, then it's the magnetron.
As a pro with over 20 years of expereince, I have always measured the high votlage, but I will never recommend it to a non-professional. Without the right equipment and procedure, you and your equipment can be "fried". No kidding.
Here are some good links to safety & troubleshooting:
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 31, 2007
Microwave was working fine then there was a loud pop now there is no heat everything else works fine lights vent and display
There was a component failure in the magnetron circuit. The magnetron is the device which produces the microwaves that heat the food. There are extremely high (and dangerous) voltages associated with this part of your oven. As a result, components often fail and make noise because these components can burst rather violently. You should take it to a competent service tech. The components associated with the magnetron can often be replaced when they fail and it is not always expensive to have repaired.
Jan 02, 2016 | GE Profile Spacemaker Over-the-Range...
No heat in microwave. Makes loud humming sound when turn on. Model GE Spacemaker JVM166OWBC 04
The humming can be caused by a couple of bad parts. Usually it's the magnetron tube, the microwave source. They often fail by shorting out, and the loud hum from the power supply is what you hear. Another part called the HV diode may also have shorted, but the magnetron is more common.
A bad magnetron can be replaced, but it's a costly part. And microwave service should be left to a professional, because there are dangerous voltages under the cover and a chance of microwave leakage if repairs aren't done correctly. Between the part and labor costs, it might be more economical to replace the oven. Let a qualified servicer give you a repair estimate and then decide.
Jan 09, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave is not heating the food. It is built into the walls of my kitchen in my condo/apartment. Can I fix this myself? How?
When the oven is running, does it make a loud buzzing or humming sound? If it does, then the problem is the magnetron, the part that generates the microwaves that heat the food. It not worth fixing since a new magnetron will cost almost as much as a new microwave. Ask your landlord that you need a new microwave oven. Sorry.
Jul 02, 2010 | GE Profile Spacemaker Over-the-Range...
The unit is 3 years old and when I turn it on there is a loud hum. Theunit also does not heat but turns the turntable?
From your description it sounds like the magnetron has failed in this oven. That's the part the makes the microwaves to heat the food. It typically fails by shorting out and making a loud hum noise. It not usually worth fixing since the price of a replacement magnetron is almost as much as a new oven.
Jul 01, 2010 | GE Profile Spacemaker JVM1871 Microwave...
GE Profile Spacemaker XL1800 The microwave runs, the lights come on, timers goes, but it does not heat/cook and it makes a loud buzzing sound.What is wrong with it,and can I repair or trouble shoot it?
Hi
Thanks for using FixYa. If it’s a loud hum/buzz sound then 90% it’s usually a bad magnetron and other times it’s a bad high voltage diode. However, from what you have described it seems to be the magnetron. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 29, 2010 | GE XL1800 1100 Watts Microwave Oven
I have a 2001 GE Spacemaker #JVM1840CD001 that does not heat anything, but runs. What's wrong and how can I fix it?
If your microwave oven "works" meaning that your display, cooking tray rotates, and the light turns on when you open the door, but does not heat the food, the problem usually is with the magnetron circuit. If you hear a loud hum when you try to heat something in the oven usually means that the magnetron has failed. The replacement magetron is about the same price as a new oven, so you are better off buying a new oven.
Feb 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool builtin microwave humkming loudly
yes for sure magnetron or diode has gone bad.but usually it is the mag.magnetron when go bad they start making noise and stop heating.when chaging magnetron chg the diode with it.
Aug 18, 2009 | Whirlpool MH7140XF Microwave Oven
JVM 1660WB 003 GE Profile Microwave humming sound/burning smell
the magnetron the unit has gone bad.sometimes there is burning smell as u mentioned.it is little expensive repair arond $ 150.00.find out the price of new unit plus iistallation/delivery chg and then make a decision.
Aug 17, 2009 | Microwave Ovens
GE Profile Microwave will not heat
Unfortunately, there is no way to tell which part the microwave needs without opening it up for examination. There are a few parts that, if defective, would prevent the oven from heating.
  • a high voltage transformer which passes energy to the magnetron
  • a magnetron which converts high-voltage electric energy to microwave radiation
  • a magnetron control circuit (usually with a microcontroller)
This is NOT a repair that you would want to attempt yourself. The labor for the repair would cost a minimum of $50 and shouldn't exceed $100. You'll also have to pay for the necessary part if it's still available from the manufacture or their parts distributor.
Feb 03, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Loud humming/no heating
Word has it that many of these models have a defect which causes the microwave energy to be reflected back to the magnetron, causing damage to the magnetron, and eventually damaging the high-voltage diode too. Also, the fuse or the magnetron theral cutout / thermostat can eventually blow, too. There is a replacement magnetron and stirrer kit available. I would definitely call the GE Answer Center at 800-626-2005 about this. It's not considered a recall, but a "campaign". They may pick up part of the cost. It's not cheap.
Dec 31, 2006 | GE JVM1440 Microwave Oven
GE JE1660 Microwave Oven Logo
3,563 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
