Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
How do I adjust the chain on Chamberlin 1/3hp
    President:
  • 3,197 Answers
The chain adjustment is on the trolley. Don't over tighten. Some slack is necessary.
Posted on Sep 28, 2009
Shorten chain on chamberlin garage door opener
There is a special tool for this and is available at bicycle shops. Easy to use.
Nov 01, 2011 | Sears Craftsman LiftMaster Chamberlain...
Hello I have a chamberlin 1/2 HP chain drive how do i know if the sensors are lined up correctly?
The sensors each have a small light on them. One of the sensor lights stays on all the time and the other sensors light will only come on when they are pointed properly. If you cannot get the light to come on you have bad sensors.
Feb 19, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a chamberlin liftmaster 1/3 hp.. the chain is loose, it drags on the garage door as it goes up and down. I can only get the door to go down if I hold the button on the wall?? How do I fix this?
It sounds like a door sensor problem for one. If the main light flashes 10 times when you try to close the door the sensors are probably not pointed at one another. Tweak them a bit and check to make sure the small light on each one is lit and not flickering. If you cannot get both lights to come on you have bad sensors. The chain can be adjusted at the trolley.
Jan 12, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have 1half h\p chamberlin garage door opener
Unplug the opener and remove the bulbs. Use a small screwdriver to pull out on the center contact in the socket. Make sure you are using standard bulbs.
May 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
Unplug the unit and remove the bulbs. Using a small screwdriver pull out on the center connection in the socket.
Apr 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
Chamberlin Series 1100 Garage Door Opener will not move over 1 Ft
replaced gears on my neighbors and had same problem< took cover off of limit switches and found a switch had a bent arm. straightened it and all worked good.
Dec 31, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Door opener has problem opening door
Neither the chain nor the track require lubricant. The roller bearings, the hinges and the rail need lubricated from time to time.
On the rear of the motor unit you will find a control "up force." Increase this about a quarter turn.
Jun 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door opener will close door but will not open it chamberlin model 7200
IF THE DOOR WORKS PROPERLY - MANUALLY
TRY ADJUSTING THE UP SENSITIVITY.
IF IT IS HARD TO LIFT OR CATCHES ON ANYTHING - YOU NEED TO FIX THE DOOR.
HOPE THIS HELPS
Apr 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
166 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
