The door do not open when the wash is over and it say somthing about the pumpe
    Genius:
  • Washing Mach... Master
  • 1,461 Answers
It is a safety feature Door will not open if water is in machine Drop drain hose to floor level and it should drain and allow opening of the door, Next check pump
Posted on Sep 27, 2009
Frigidair flexcare top load washer. Is there a reset button or somthing els i could try ro get it to agitate and spin again?
Most common cause, if all else works Fill , Pump out ) is a loose or faulty door switch or one of its connections .
Apr 17, 2016 | Washing Machines
Zanussi jetstream zwf14179W lock will not release
it sounds like your pump might have somthing in side it try opening the flap on the bottom right you will see a plastic screw undo it and clean it out that should help ok
Oct 18, 2012 | Washing Machines
Door will not open door light just flashing on and off
washer not spining mini load button flashing on/of buton flashing
Apr 27, 2010 | Hotpoint Aquarius WD640 Front Load...
I cannot open the door on my Hotpoint Aquarius wt740 after it finished a wash. Door handle is floppy and door light is off.
it sounds like you have a broken door handle Disconnect power before doing anthing remove lid , what you will need to do is usining a screw driver or somthing simular look down to where the catch is (you may need a tourch) and look carefully you should be able to to the door catch mechanisim from inside you will need to mimic the action of the door handel but using a screw driver it a bit fiddley but can be done there is no grate force needed and it the catch will only need to move a bout 3-8 mm to open
Jan 17, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint wdd960 washer dryer error f05
f05 means blockage and cannot drain-switch off at mains to reset error-turn to drain if pump runs but dont drain filter in sump blocked/if no pump action then somthing is jammed inn pump
Nov 08, 2009 | Washing Machines
Door will not open after wash
pull the plug and leave out for 10 seconds and replug it in, that should reset things, if not there could be somthing wrong with the door solonoid .
Oct 29, 2009 | GE WSXH208A Front Load Washer
Everything works fine but it will not spin
Hi, you got water pump problem, some pump have a filter you can remove and clean, or some some small clothing could get into it. or you can open water pump and manually check for foreign object. you can empty machine, by lowering drain hose to floor level, you will need somthing to collect water, then check pump.
Aug 02, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
The machine will not drain or spin
you will need to open up the front panel and remove the hose on the pump sounds like an obstruction in pump.To do that you must use a puddy knife and push it inbetween the top panal and body of washer on both right and left side.Then pull paneloff.You will see the pump on the bottom right side there are 2 hoses on there pump remove both and see if there is somthing stuck in there.
May 10, 2009 | Washing Machines
My maytag top loading washing maching only fills up with water
take the two screws out of back controll panel than jam somthing to hold the door closed switch forward mine did same many times and it is always that switch moved back a little to far you can check by holding open door and push in switch with a pen or somthing
Apr 01, 2009 | Washing Machines
Door would not unlock - got an error code f-22 what does that mean?
your door switch may be going bad.try pushing the door in and hit drain spin and if that works then it will unlock.I need to know what code is flashing to help further.hope it helps.
Mar 05, 2009 | Whirlpool WFW9200S Front Load Washer
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
