Ge washing machine with magnetic lid switch is not spinning or agitating . it is not the lid switch the motor makes no noise at all. I opened the lid while it was spinning , heard a loud crack and never spun or agitated again.
  • kendicott Sep 27, 2009
    If you could send the video that would be great tha
    nk you
    President:
  • Washing Mach... Master
  • 1,723 Answers
The 'coupler' broke when the motor was braking to a stop. It's a cheap part but a bit hard to change yourself. Do you have the tools and knowledge to get into the machine? I can send you a video that shows how to change the coupling for the motor...??
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Sep 27, 2009
Ge profile top load washing machine won't agitate or spin. Fills and drains fine. Tried motor reset (lift lid 6 times). To no avail. Lid switch is magnetic.
make and model information might help. try contacting the factory for guidance if you have those pieces of info.
age might be a factor...... how old is it ?
Mar 24, 2018 | GE Washing Machines
I have a GE WJRE5550KWW it fills and drains but will not agitate or spin
Possible bad lid switch. On that model the lid switch is the flat plastic square on the right front recess area that the lid closes into. The switch is activated by a magnet mounted on the washer lid on the front right corner.
Dec 22, 2014 | GE Washing Machines
Machine will agitate until lid is open? will not spin unless I play with the lid...i can see the motor start to turn then it cuts off...after some playing with the lid I can get it to spin?
The lid has to be closed for agitate and spin. The lid switch is loose or defective.
Open the control console to retrieve the mini service manual.
Follow the steps to access the lid switch and repair.
Feb 17, 2010 | GE WDSR2080D Top Load Washer
Washer will not agitate or spin
If it also makes a noise, then more likely it's a broken Motor Coupler.
If not, you need to investigate :-
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 19, 2009 | GE WPRE6150HWT
GE washer GNSR2140A0WW wont spin/agitate but fills and drains
Hello, your problem is going to be with the lids switch, in this machine it is going to be a magnetic contact. You can confirm this my pulling the front panel off and accessing the wireing to the lids switch, If you have electrical knowledge bypass the lid switch using a wire nut and run the machine. If all is ok make sure you relpace the lid switch since it is there for a reason. If you have any other questions or concerns please feel free to comment again. Good Luck!!!
Jul 19, 2009 | GE WBSR3140DW Top Load Washer
Need to know about safety switch on washer lid
First, this machine has an electronic motor. Check to see if belt is broken. If not then unplug for 2 minutes, plug back in and open and close lid 7 times slowly. This will reset motor. A common problem with this machine. I dont think it is the magnetic lid switch.
Jun 15, 2009 | GE WBSR3140DW Top Load Washer
GE washer no main motor run so no agitate or spin
This is the electronic washer. Unplug for two minutes, plugin then open and close lid 7 times. This will reset motor. Also make sure belt is not broken.
Jun 07, 2009 | GE WBSR3140DW Top Load Washer
WHDRR418G1WW WASHER WON'T AGITATE OR SPIN, NOT MAKING NOISES. FILLS AND DRAINS FINE.
sounds like you have a broken lid switch on the washer, maybe someone slammed the door or placed or stood on top of the washer, a broken lid switch won't allow washer to go into spin mode is a safety device so if is on spin cycle an someone sticks their hand it the machine stops an not breaks your hand.
broken lid swtich
good luck leave some feedback thanks!
May 28, 2009 | GE Washing Machines
GE washing machine, wont spin
Same problem (but without any smell). You should try to reset the two computer boards in the washer. You do this by 1) unplugging machine and wait for 30 secs; 2) plug in machine; and 3) open and fully close the lid at least 5 times. This resets computer boards, which can get messed up by power surges, etc.
Mar 24, 2008 | Washing Machines
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
