Question about LG Flatron L1951S-SN 19" LCD Flat Panel Monitor
Out of the blue one day, monitor started displaying "anaolog power saving mode." This is a stand-alone computer which has never been hooked up to internet.Took tower unit to PC World to see if it was a computer fault. It wasn't. Ended up sending monitor back to manufacturers, LG. Now have a brand new monitor, connected it to computer tonight with brand new leads, but all you get is LG logo on screen and before you can do anything, it goes to "analog power saving mode", so I dont get as far as desktop. Dont understand how computer has worked fine for the year or so we have had it, but it is now doing this and despite using all new leads and now a brand new monitor, it is still doing the same. Any ideas?
  • 138 Answers
You go to control panel starting your pc ,, then display settings,, from there,, screen saver tab, then make screen saver to none, and click on button power,, there you make everything to never,, and then see. it should work good
Posted on Sep 27, 2009
Lenovo g550 laptop with an external monitor would only display of broken original screen after crash dump
When the computer is starting up PRESS & HOLD the "F" key which controls the external monitor. It may be F4, F5, F6. You should get image on the external screen. Go into video properties and select dual monitors or allow computer to use external display or something like that.
Nov 19, 2014 | Acer Computers & Internet
Gateway fpd 1530says
If you see a message box that says "Power Saving Mode" after pressing the power button, then it simply means that the monitor/display is not detecting the computer. Check the connection/cable between the display and the computer and make sure your computer is not in standby mode by moving your mouse.
From what you stated in your problem, you dont need a inverter or a bulb. If you have any image like the message box displayed then its working fine. It just isnt seeing any signal changes on the input and therefore goes into power saving mde. Try another cable or hook it up to a different computer to check the cable.
Oct 16, 2012 | Gateway FPD1530 15" Flat Panel LCD Monitor
Power saving mode
Power saving modes are automatic for some LCD monitors some have setting like after 20 ,30 mins to an hour the computer monitor itself will go into standy saving modes like power led switch indication go to yellow led lighting or the monitor of the lcd screen go blank if ur computer have no pictures for displaying as a screen saver modes.Power saving modes it best for uses if ur computer it on all day long.If u don't touch the mouse or a keyboard the monitor will go in the power saving modes for less electricities consumption for less stress for the monitor electronic components for working to hard for the monitor not to malfuctions sooner or the monitor life cut too short because the computer it on all day.
Oct 12, 2012 | Computers & Internet
Dell E207WFP Display Problem
check your system vga out put is working or not, conform this by connecting another monitor or connect monitor to another computer.
May 11, 2012 | Dell E207WFP LCD Monitor
Acer d241H display plus mode shows no signal. I want to use the monitor stand alone. When i press the source key to change to display plus mode. the screen shows no signal. (the first time I powered on the...
I had the same issue as yours. After contacting the Acer support team, I got the response as follows. I tired and it worked.
"In order to resolve this issue, you may please perform a power reset. This will remove any static electricity stored in the hardware components that may cause the issue.
- Turn the monitor off and unplug the power cord and VGA cable from the monitor.
- Hold the power button on the unit down for 30 seconds.
- Release the power button and plug only the power cord back into the unit. "
Hope it helped.
Oct 30, 2011 | Acer D241H LCD Monitor
My monitor shuts down after one second.
Dell monitors automatically go into power-save mode after a preset amount of time when the computer is inactive. The Dell monitor will go completely black, instead of showing a screensaver. This doesn't mean that your Dell computermag-glass_10x10.gif has shut down. Instead, this allows your monitor to essentially turn off until it's needed again. You can change how long it is before the Dell monitor goes into power-save mode by changing your display settings.
  1. Step 1 Press any key on your keyboard or move your mouse. Either will turn off power-save mode. Alternately, you can press the power button on your Dell computer tower or laptop.
  2. Step 2 Press any key a second time if the monitor goes from power-save to stand-by mode. Stand-by mode allows the screensaver to appear.
  3. Step 3 Enter your user name and password into the login prompt if your computer requires a login. Press "Enter" to begin using your Dell computer.
  4. Step 4 Change the display settings on your Dell monitor to prevent your monitor from going into power-save mode prematurely. Right-click anywhere on your desktop and choose "Properties." Click the "Screensaver" tab and press "Power." Beside "Turn off Monitor," choose a time amount from the drop-down list and press "Apply."
Nov 13, 2009 | Dell Dimension 3100 PC Desktop
Problem Using stand alone monitor with laptop computer
signal out of range suggests that your laptop is asleep..open the display settings, and disable those, until you get this resolved.
Oct 15, 2008 | Dell Inspiron 8600 Notebook
Analog Power Saving Mode
Right click on your desktop>Properties, then click on Screen saver tab, then at botton of the box you should see 'Monitor Power'. Click on 'Power' then Power schemes tab. Look at 'Turn off monitor' and set to 'Never'
Nov 30, 2006 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Digital power saving mode
Are you sure someone hasn't changed the power setting in windows. I've seen similar tricks pulled by so called mates. :-) If windows is OK then check the manual for the monitor and if you still can't crack it take it for a ride to the repair shop. It is under warranty after all. BMW
Jun 03, 2006 | LG 1720B 17" LCD Monitor
LG Flatron L1951S-SN 19" LCD Flat Panel Monitor Logo
443 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
