Question about Mitsubishi WS-65807 65" Rear Projection Television
Color distorted when viewing non-hdtv
My tv works fine when viewing in HDTV format but the colors are all distorted when watching non-hdtv signals. What could cause this?
  • colbs Jun 03, 2008
    When turned on cold the picture bows and the images have a shadow in a different color almost like the alignment is off. When the TV warms up the problem goes away. It is taking longer to go away as the problem seems to be getting worse. This TV is used very little and is just out of warranty.
    President:
  • 4,402 Answers
Convergence ic going. you may also want to check some caps;
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
caps
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Posted on Jan 18, 2008
I replaced both backlight boards but still having problem with LCD TV...it is too dark and color distortion.
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 05, 2015 | LG 42LC2D 42 in. LCD HDTV
What happened to my color on screen?
I experienced a similar problem with my 52" Sharp Aquos TV. I called and spoke with Sharp service dept. and they walked me thru the process of resetting the TV to it's original "default" values. It worked great once I completed the steps while on the phone with them.
suggest you do the same thing with JVC.
Aug 15, 2014 | LG 42LC2D 42 in. LCD HDTV
Visio Strange Color/Pixel Problem As of now, every time i turn my 32" Visio HDTV (VX32LHDTV10A) on, certain areas and colors are going crazy and it has progressively gotten worse over the past...
The tv main Tuner signal board it is the causes and the problems.The board it is dying and shorting out.U have some mechanicals skills,like take things aparts and putting it back togetther again?Yes.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv main Tuner signal board for the replacement.
Jul 14, 2011 | Vizio L32 32 in. LCD HDTV
Lamp light on front of tv stays on, it is amber in color
Hi,do you mean tv is showing an amber picture? If you do,it could be an issue with the color wheel or dmd board.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.This is how the DMD works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Here's a video that will help you find where the DMd chip is located : http://www.youtube.com/watch?v=0jr_9A5Xd2Q Have a blessed one!
Apr 02, 2010 | Mitsubishi WD-52525 52" Rear Projection...
RE: Toshiba 32AV502R 32
NO,Ur tv have problems.The Main Tuner Signal is dead,have burn electronics componnents.Still under warrenty call for service.Not Tries websites Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
Mar 17, 2010 | Toshiba 32AV502R LCD TV
Can only see an image using Twin View and colors are distorted
Ur convergence it dead.Know how to solders?Try these websites.Tv repair world.com,Tv Repair kits for convergence kit,use what in that kit.
Oct 30, 2009 | Sony KP-53HS30 53" Rear Projection...
50 in rca tv
Either color wheel or ballast is faulty.
Oct 06, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
55'' vizio screen color is distorted
I have been pleased with the help from Vizio. Try techsupp@ vizio.com. Good luck. I believe they respond within 48hrs.
Jun 27, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Rainbow color effect appears when Samsung LCD plays Wii or DVD
Hello, I have a question which video inputs are you using for your DVD and Wii connections? The reason I ask is because this sounds like video distortion cuased by noise. If possible can you send a picture of the screen when it has this problem and send which video ports are being used? If it is noise in the video you may have a saw filter problem, or a decoupling issue. In any event I'll know more once you send those pictures and which inputs you are using for your DVD and Wii. Thank you, Shuttle83 http://www.electron-age-technologies-llc.com service@electron-age-technologies-llc.com
May 30, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
Philips hdtv color distortion
your tv has a prolem in the color circuit there is a ic that controls this circuit changing it will restore your tv to normal.since you are not a tech have a tech look at it for repairs.good luck.
Aug 03, 2007 | Samsung TXM3296HF 32" TV
Open Questions:
See all Mitsubishi WS-65807 65" Rear Projection Television Questions
Mitsubishi WS-65807 65" Rear Projection Television Logo
161 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
