Question about HP Officejet 5610 All-In-One InkJet Printer
Printer ran out of paper, will not print again. status report states out of paper.
Tip
Lexmark laser paper jams and wrong size paper reporting
the quickest way to find out if your paper jams are due to wrong size paper reporting is to print the network status page.
This page is outline with a line that runs 1/2inch from the edge all the way around the outer edge.
if the box of this page prints smaller than the letter size paper the paper reporting is smaller than 8 1/2 x 11 and if the line at the bottom of the page is missing its reporting a size larger than 8 1/2 x 11 either of these occurances willl be the cause of your paper jams
on Jun 07, 2010 | Office Equipment & Supplies
When i refill toner it still show toner low.how sovle the problem
Good day.
First try to print a print status report. Here are the steps:
1.Push setup menu button, that would be the wrench icon. 2.Push the right button to navigate until you get to the Tools Menu 3.Tools Menu>Push button for Printer Status Report
This will give you the accurate ink levels on your printer. If it still shows low ink based on the printer status report, you have to reseat the ink cartridge and make sure the orange tape near the HP Logo on the ink cartridge has been peeled off.
If the report shows ink levels are fine, then that status report on the front panel is just a false report. Try powering off your printer and powering it back on again. As long as you don't have print quality issues, you should be fine.
Jun 20, 2011 | HP LaserJet CP1515n Printer
Printer status states paper jam although there is
Have you check the rear side of your printer?
Try the below..maybe it will help...
Disconnect the USB cable or parallel cable from the rear of the product then turn off the printer. Turn the knob on the rear access door counter clockwise, and then pull the door out to remove it.Check if there is any paper there..
May 24, 2010 | HP DeskJet 5550 InkJet Printer
I printed a report from the internet a couple of days ago. Now my printer continually prints header information (one line) over and over. It won't stop! If I load the paper tray, it immediately starts...
Take the paper out, go to control panel - printers, open your printer's folder, and choose from the menu Purge all print jobs. If you have some kind of printer status monitor, go there and look for any job that's pending, and try to cancel it. Now turn the printer off, on again, and insert paper - it should be over.
Nov 11, 2009 | HP Photosmart 2575 All-In-One InkJet...
HP 2210 New Black Ink Cartridge print alignment page over & over.
unplug the printer while it is in ON state..it will reset all settings..^_^
May 16, 2009 | HP PSC 2210 All-In-One InkJet Printer
I have a HP Photosmart C5180 printer. It is not printing purple-instead what comes out is blue. I have done a print test report and it showed the Light magenta and magenta with missing bars and streaks. I...
If your color improved slightly when running the printhead option then doing more should help get better results. Sometime the printheads get really dirty/clogged and running the cleaning option more then once is needed.
If you get a slight line running across the page (from left to right) usually the indicates dust build up on the printhead or ink carriage. The dust acts as a paint brush being dragged across your paper as the carriage moves across the page during printing. You can clean the bottom of the carriage with a Q-tip or purchase some cleaning paper for your printer.
Apr 16, 2009 | HP Photosmart C3180 All-In-One InkJet...
Receipt not printing
I believe this might help, not exactly familiar with this exact model but here it goes.
Receipt ON/OFF function
When you use the printer to issue receipts, you can disable receipt printing in the REG mode to save paper
using the receipt ON/OFF function. To disable receipt printing, press the Rkey in the OP X/Z position. This
key toggles the receipt printing status ON and OFF.
The register will print reports regardless of the receipt state, so the paper roll must be installed.
To issue a receipt when receipt ON/OFF function is set to OFF:
If your customer wants a receipt after you finalized a transaction with the receipt ON/OFF function being OFF
status, press the Rkey. This will produce a receipt. However, if more than 30 items were entered, the
receipt will be issued in a summary receipt.
Copy receipt
You can print a copy receipt by pressing the Rkey when the receipt ON/OFF function is in the “ON” status.
To realize this function, you must enable the function. Please refer to page 62 (Job code 63).
Nov 11, 2008 | Sharp XE-A404 PC Desktop
HP Officejet 5610 All-In-One InkJet Printer Logo
48 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
