Question about Saeco Starbucks Sirena Espresso Machine
Starbucks sirena won't heat up; blue light flashing-brand new
I turn the power on and the blue light flashes, temp guage doesn't move, nothing comes out of the steamer wand. I can't figure this out! I thought if I primed it I could get the machine going, but can't get that far. Please help
  • 8 Answers
Johnshami had this solution on another post, and it worked for us:
  1. make sure the water in the tank is stone cold -- which is a no brainer since it will not heat h2o unless it's primed.
  2. take off steamer wand cover, turn the steamer knob clockwise till pump starts.
  3. then s*ck (as you would on a straw, with your lips sealed around the end of the steamer wand) the tip of the end of the metal tip hard until pump stops
  4. may need to do it a couple of times. yes this seems crazy, but it works! you are flushing out the vapor lock in the pump.
Posted on Dec 26, 2009
  • Dave Johnston Jun 07, 2013
    What do I do if my pump doesn't start after opening the steam knob? Help!
The blue light comes on when the water container is low/empty. I assume you already tried filling that container?
If you follow the instructions for descaling your machine (in your Sirena handbook), you can get the little blue light to go away long enough to get the machine pressure gauge to move. I think you can start by pulling the portafilter/handle-thing out of the machine and then turning it on --- so the machine doesn't think it's supposed to be preparing to brew a shot.
Posted on Dec 21, 2009
    What do you mean by 'machine pressure gauge'? The only visible gauge on the machine is the temperature gauge... Still can't get this thing primed:(
I have the exact same problem
Posted on Dec 05, 2009
Starbucks Sirena espresso flashing blue light & does not heat up
Gary,
I have the same exact problem with mine starting today, did you get this figured out? I'd love to know if it's fixable or not as I was planning on selling my previous machine. If it's an expensive repair, I'll just have to ditch this one and go back to my previous one.
Jan 04, 2010 | Saeco Starbucks Sirena Espresso Machine
I can't stop the water light from flashing
we had the exact problem with the same Sirena machine: per the manual, just use the steam wand (turn on and let flow) until the blue light goes off; this will prime the machine and it solved our problem.
Sep 19, 2009 | Saeco Starbucks Sirena Espresso Machine
Just out of the box, the sirena espresso maker doesn't heat and buttons don't flash
You need to prime the machine with water. Fill the water tank. Plug the machine in and turn the power on. Instructions state the lights will flash, but they won't. Blue water drop will illuminate indicating the machine is empty (the water tank is full, but the pipes in the machine are empty until you do the following). Place a cup under the steam wand, and rotate the steam knob fully to the "on" position (fully clockwise as you view it from the side until you hit the hard stop). No need to use force, just rotate until you hear the pump turn on. At this point, you'll hear a pump running, and after 10-30 seconds, water will be ejected from the wand. Continue until the blue light goes out and you're ready to brew. At this point, I think the lights flash and it comes up to temp. One more thing, when using the steam wand, always turn the knob until the pump engages, or you run the risk of emptying the water line. Hope this helps and enjoy!
Sep 15, 2009 | Saeco Starbucks Sirena Espresso Machine
Starbucks sirena lights won't turn on
Just had this happen. Finally I let water run through the steam wand (thought it had to heat up first). Water ran through (until blue light stopped blinking) and now the other lights are blinking...we will see if it works now.
Sep 05, 2009 | Saeco Starbucks Sirena Espresso Machine
Starbucks Sirena. lights blink, won't heat.
johnshami had this solution on another post, and it worked for us:
Jun 10, 2009 | Saeco Starbucks Sirena Espresso Machine
My sirena does not work
anytime the water runs out and you need to refill the tank, you need to bleed the line so to speak. Take an empty cup and put it under the wand and open the knob of the steam wand until the blue light stops flashing
Feb 13, 2009 | Saeco Starbucks Sirena Espresso Machine
Saeco Starbucks Sirena Espresso Machine Logo
973 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
