Question about Sears 60301 Electric Kitchen Range
Where is the fuse panel on galaxy stove - Sears 60301 Electric Kitchen Range
Hi is there avfuse box or fuses on the stove?
If its an electric stove the fuse panel should be in the upper back of the stove. Ours was in the top behind the clock. There should be a fuse for each burner and one for the oven.
Jul 19, 2015 | Ovens
Where are fuses in Kenmore stove C970
Stoves generally do not have internal fuses they rely on the house circuit breaker to protect the circuit. Some stoves have what is called a thermal fuse. These can trip when the oven or broiler has overheated. Some are located on the back panel and some are located on the top panel under the top of the stove. Since this is a smooth top model there may be one on the back panel. More than likely there is a problem with the oven control circuit possibly in the electronic control. The relays can go bad on the control and the oven will not work.
Oct 11, 2014 | Kenmore Electric Smooth Top Stove
Where can i find my kelvinator stove fuses
Fuses located on the top under panel. Pull the front ends and bring it up. Oven fuse (two of them) separate from burner fuse
Jun 09, 2014 | Refrigerators
No power
Your stove should be on its own breaker or have its own fuse. Some models of stoves have fuses within their own control panels too. Check your home's panel to see if a breaker has been flipped or a fuse blown, and follow up with the owners manual for your make and model of stove.
Mar 05, 2014 | Magic Chef Microwave Ovens
Fuse location on ge stove
If there is a fuse it should be located on the back of the unit behind a cover plate.Make sure to unplug stove before working on it.Hope this helps.
Dec 30, 2013 | Ovens
Just cooked Xmas dinner and electronic control panel went dead oven light comes on as does burners
Step 1:
Unplug the stove or turn off main breaker.
Step 2:
Pull stove away from wall and remove screws at the back of the panel to expose a fuse in the panel. It is probably blown!
Step 3:
Replace with the exact same fuse after cleaning all the wires and the areas around the wires (circuit boards as needed).
Dec 25, 2012 | Kitchen Ranges
WE have a GE Stove top Range. The burners aren't
If you have power to the stove as in the oven light works and the clock works but the burners and oven will not work you only have 120 volts coming to the stove. The stove requires 240 volts for the burners and oven to work. Check the service panel for a blown fuse. There will be 2 fuses in the fuse holder. One of them is blown. If that is not the case then one of the wires has come loose either in the service panel or in the outlet behind the stove. Use a multimeter to check the input voltage at the outlet.
Apr 25, 2010 | General Electric Stove/Oven/Range Chrome...
I just wired a 220 outlet for an electric stove. when i plugged in the stove i heard a pop. so i unplugged it. took off the rear panel, and found that someone had disconnected the two hot wires from the...
If you have shorted the wires to the metal panel, then at least one wire had blown.
You need to test wires and electronic parts that may be affected. Start testing the shorted wires using a multimeter on Ohms to verify that they have continuity between the two ends of the wire.
Mar 02, 2010 | Kitchen Ranges
Stove control panel not working
You do not have a fuse or overload button on a Maytag cook-top. If you heard a pop, it was the touch pad on your control board blowing out.
Oct 22, 2009 | Kitchen Ranges
Sears 60301 Electric Kitchen Range Logo
246 people viewed this question
Top Sears Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Sears Kitchen Range Expert? Answer questions, earn points and help others
