Question about Toshiba SDV395 DVD Player/VCR
It says no disc inserted
My Toshiba sdv395 dvd/vcr player is about a year old and it stopped recognizing dvds. Now it always says "no disc inserted" on dvds it used to play
  • 63 Answers
Well it sounds like a problem with your lense. so just take it apart and look at your lens and see if there is anything wrong or out of the ordinary with it.
Posted on Sep 27, 2009
How unlock a Toshiba sdv398kc dvd?
Toshiba SD1200 / SD1600 / SD1700 / SD210E / SD2109 / SD2150 / SD220E / SD2800 / SD3750
  1. Insert DVD with foreign region code
  2. Wait for the error message to appear
  3. Press M (Memory)
  4. Press 1
  5. Press PLAY
Toshiba SD120E / SD125E / SD220E
  1. Get the multi-region update disc for the SD220E (http://www.geocities.com/its_yahell/toshiba_sd220e.html)
  2. Write it in DAO mode
  3. Switch on DVD Player
  4. Press SETUP
  5. Under the Picture option change Pal/Auto setting to Auto
  6. Press SETUP
  7. Insert the update CD
  8. The following images are displayed: ?'Nabe the Wiz?' and then ?'FIN?'
  9. Remove CD
  10. Switch DVD Player On/Off
Toshiba SD240 / SD350E / SD3960 / SD3980
  1. Open the disc tray
  2. Press 2, 4, 0, 3, 9, 6, 0
  3. Select region using ENTER (9 = multi-region)
  4. Close the disc tray
  5. Power off
Toshiba SD3109
  2. Insert foreign DVD
  3. Close the disc tray
  4. Press STOP before the error message is displayed
  5. Press "T" twice
  6. Enter a time of one second
  7. Press PLAY
Toshiba SD43HK
  1. Turn on the player (without a disc inserted)
  2. Press ENTER
  3. Press 8, 4, 2, 6, 9
  4. Press ENTER
  5. If the player doesn't turn off automatically, turn it off
Toshiba 23HLV84 / SD-24 VLSL / D-KR2 / D-R1 / D-R2 / D-R255 / D-R4 / D-VR30 / D-VR4 / MD13N1 / MD13N3 / MD13P3 / MD14FN1 / MD20FM1 / MD20FN1 / MD20FP1 / MD20P1 / MD9DM1 / MD9DP1 / MW20FM1 / MW20FN1 / MW20FP1 / MW20FP3 / MW24FM1 / MW24FN3 / MW24FP3 / RD-X2 / RD-XS34 / RDXS30 / RDXS32 / RDXS52 / RSTX20 / RSTX60 / SD1008 / SD100X / SD106E / SD114E / SD1209 / SD1209 / SD114E / SD1209 / SD1300 / SD130E / SD1402 / SD140E / SD145E / SD1850 / SD1900 / SD2006 / SD2008 / SD2108 / SD214E / SD22VE / SD22VL / SD245 / SD248E / SD24VB / SD250E / SD2600 / SD2650 / SD2710 / SD2715 / SD2805 / SD2810 / SD2815 / SD2850 / SD320V / SD324ES / SD34VL / SD35VF / SD36VESE / SD3860 / SD400V / SD412V / SD4205 / SD44HK / SD4960 / SD500E / SD5205T / SD5907 / SD5915 / SD5980 / SD6915 / SD9100 / SDH400 / SDK200 / SDK220 / SDK330 / SDK350 / SDK530 / SDK730 / SDK740 / SDK750 / SDP1000 / SDP1400 / SDP1500 / SDP1600 / SDP2500 / SDP2600 / SDV290 / SDV291 / SDV390 / SDV391 / SDV395 / SDV396 / SDV593 / SDV65HT / VTD1420 / VTD1431 / VTW2185
Dec 17, 2016 | Toshiba Televison & Video
"No disc" message when DVD inserted.
Buy a DVD cleaning kit and follow instructions, if no! the laser pickup assembly is bad, and not cost effective to repair
Mar 16, 2012 | Toshiba SDV395 DVD Player/VCR
I need to unlock a Toshiba DVD player/VCR Combo SDV395 to view DVDs' purchased in Francs
You can change the Region Code of you DVD player but be aware that you have a limited number of changes, then the DVD player will be stuck to a certain region.
Search in the Options menu and change the region code to one printed on the french dvd case. To watch DVDs from your region again you have to change the region once more. Watch for changes left.
Nov 02, 2010 | Toshiba SDV395 DVD Player/VCR
My 2 1/2 year old LG dvd/vcr recorder will play some dvds but will not play others. It says unknown disc. I was told to try a lens cleaner; I bought one and the lens cleaner says unknown disc as well. ...
Your DVD /VCR says unknown disc because the
dvd which you have inserted is not of the supported format by player.
If you insert unsupported formats only it will say as unknown disc.This is not related with disc cleaners.
Please insert the supported formats and it will play the disc.
Thanx
Jul 31, 2010 | LG Televison & Video
Can not get closed captions on dvd to play on sony tv with captions on tv set on.
Hi, you might have to turn the CC feature off from your TV and select the CC feature from the DVD disc set up.Refer to page 35 of the owners manual to get the correct language caption on your disc(dvd): basically press the audio key on your remote control until the desired captioning appears.
Jun 21, 2010 | Toshiba SDV395 DVD Player/VCR
Dvd play works but vcr playing does not
For this unit the component output (green, blue, and red cables) only work for the DVD player portion of it. You will need to connect either the av input on the back or the front with composite (yellow, red, and white cables) to your television in addition to the component cables I assume you have connected already. Once you have done so you will need to switch this unit over to the right av output in order to access the vcr and also switch your television over to the right av input in order to pick up the signal from the vcr.
May 05, 2010 | Toshiba SDV395 DVD Player/VCR
Hi. I have Toshiba sdv395 & was told I could dub VHS to DVD. There is no info in the manual. Can it be done & how. Roy
This is a DVD player. It will not write to DVD but will play discs you have recorded elsewhere. You could (with non-copy protected discs) dub the DVD to VHS. To go the other way, you would need to connect the player to a computer with appropriate software or other DVD recording device.
I hope this helps.
Mar 14, 2010 | Toshiba SDV395 DVD Player/VCR
SAMSUNG SV-DVD440 Combo
how old is the player, it sounds like the lazer has gone down if it reads cds and not dvds
Feb 09, 2008 | Samsung SV-DVD440 DVD Player/VCR
DVD Player/recorder
yes ,you can try to buy at radioshack a cd cleaner if that does'nt fix the problem you'll need a new optic,let me know
Jun 10, 2007 | GoVideo VR4940 DVD Player/VCR
Toshiba SDV395 DVD Player/VCR Logo
143 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
