Question about HP CapShare 920 Handheld Scanner
The copy light won't stay to copy
Every time I try to make a copy, the copy light won't stay on.
    Problem Solver:
  • 6 Answers
Yellow copy light wont stay on could be from weak bat or a problem in the scanner head we have a 50% rate of repair to fix this problem. also check the two round led's on the base that they are clean and free from dirt. www.direct911.com
Posted on Jun 07, 2011
That is often an un-fixable problem. However, sometimes a fully charged fresh set of batteries will handle. (Use high-quality rechargables, not disposable alkalines.) Also try power cycling the unit several times.
Posted on Oct 02, 2009
Scx 3200 samsung status light
If you refiil the toner cartridge ,now must be change the cartridge chip.The chip countered the total copy,not how many time you refill the toner.The original chip working 1500 copies,change one new chip to 1,5K or 3 k or moreK(K=1000 copies).
Mar 26, 2013 | Samsung CLP 300 Laser Printer
Citron xsara Picasso won't start and battery light stays on
Most of the time, this is an indication that the alternator is not charging the battery enough...could be loose or worn out belt?
Mar 18, 2013 | Cars & Trucks
2000 Ford Expedition, Lights won't time out
You either have a windshield leak & water in the
delayed relay & or the GEM Module failed
If only the lights are effected & not the radio,
blower,interior lights- the the GEM is most likely
okey
Then you trouble shoot the main problem
Try Google There is an overwhelming amount of ford
problems you can read
Feb 13, 2013 | 2000 Ford Expedition
I have a gas furnace that won't stay running. It
Sounds like its the pressure switch try jumping it out some times you can fool it into working
Mar 05, 2012 | Heating & Cooling
When I tried to light my furnace, the electrical wires from the thermostat don't spark all the time, therefore my furnace won't stay lighted. What can I do to fix this?
Is this an older furnace where you have a pilot light? Are you saying the pilot light will not stay lit? If thats the case then likely you need a new thermal couple. That is what the pilot light keeps hot while it stays lit. It is a safety device that is there so your furnace will not come on if there is no pilot light present. Very common. Hardware store item. Need Furnace's make and model #'s.
If this is an electronically controlled furnace, you will need a service call.
Jan 13, 2012 | Heating & Cooling
I changed the fuse as the turn lights and hazard lights were not working but all other light including brake and interior worked. Now the hazard light stays on and I cannot turn it off. can you Help p
if your hazard lights stay on, you may have a problem with the hazard switch on your stearing collum. try moving it back & forth several times, eg. on, off, on, off always ending @ off & see if that works. they do get sticky @ times. your brake lights will work but your turn signals won't work properly with the hazard switch turned on. let me know if problem persists & will see if i can help you more. good luck.
Nov 24, 2011 | 1999 Saab 9-5
Filter Queen Defender red light will not blink
no with the red lite on it mean that you need to change your filter its a safety feature so you dont burn out your motor and also so you dont blow unpurified air through out your home
Oct 13, 2007 | Filter Queen Defender Air Purifier
HP CapShare 920 Handheld Scanner Logo
98 people viewed this question
Seeker5211
Seeker5211
