Question about Samsung PCJ522R 52" Rear Projection Television
Wont power on
I plug the tv in and the red light comes on and stays on, does not flash. will not power up with either the button or the remote.
Suggestions?
    Problem Solver:
  • 10 Answers
It sounds like the tv power supply has problems. you probably should call a service center about a repair.
there are "safety" features built in to any tv with a "crt" type of screen that will not allow the tv to run when there is a problem.
Posted on Dec 27, 2007
My sony tv wont turn on
There is a powerbutton on my sony TV - no amount of pressing the remote will activate the telly unless I forstpop the power button on the top. Once it has been initiated teh remotes work fine.
ALSO check the remote is working by activating a digital camera - can even be a smartphone - point the remote at the lens and you should see a flashing light on the camera screen, if not, check the batteries etc (try another remote for something you know is working to compare the result)
If all that fails, it may well be the TV that's broken.
Jan 03, 2015 | Sony Televison & Video
Hi I have a Sony fwd-50px1. It's plugged into the wall and without hitting the power on the TV the red standby light is on, as it should be. Now I press power on the TV itself and nothing happens. No...
Try unplugging and plugging the tv back in. Could also be a problem with the power button itself. Make sure the membrane contacts are clean and that the membrane is making contact with the contacts.
Dec 10, 2013 | Televison & Video
Samsung LN46D630 Wont turn on
http://www.tvrepairdoctor.com
Oct 26, 2012 | Samsung LN46D630 LCD TV
My converter box will not turn on. The light stays red. i plug it in and it lights red but it wont turn on it stays off and i use remote and i manually push the power button but it wont turn on!!
TRY
Unplug receiver.
Leave for 10mins.
Plug in again.
Wait another 10 mins.
Press the hand control stand by button.
In a few minutes the light should turn green and start options should appear.
Good luck. This works when my HD box freezes.
Feb 02, 2010 | Televison & Video
Red ir light floashing and tv wont come on Onn lcd tv
red light flashing on bottom of tv and no picture
Nov 27, 2009 | Televison & Video
Wont turn on
The power supply board has been defected. Replace it with a new one.
Aug 15, 2009 | Samsung LN32A330 32 in. LCD TV
The Power Light is Red
yeah, should stay red when unit is turned off, indicating there's power but it's doing nothing.
Per user manual:
Solid red - power off (standby mode)
blinking red - power off (now cooling)
blinking green - power on (preparing to light lamp)
solid green - power on
Mar 08, 2009 | Panasonic PT-40LC12 40" Rear Projection...
Samsung flat screen wont turn on red light just flashes..
wont turn on red light just flashes?
On my samsung flat screen tv when you are watching the televison there is no red light on the power button but when you turn the television off the red light stays on all the time? what can I do to turn this light off?
Jul 20, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Sony bravia tv
Solution is simple....
First, unplug power cable from the back of your TV. You will notice the flashing light is still flashing. Don't worry, go to the Second step.
Second, keep pressing on the POWER button, located on the panel at the top of your TV, to shut off your TV. This will stop the flashing light from appearing.
Third, Plug the power cable back onto your TV
Fourth, press the POWER botton ONCE, using the same button used in the Second step to turn your TV back on.
Fifth, you will see the POWER light comes on, as normal.
Sixth, using your remote control, press the green button to turn on. Your TV should work as normal.
Jun 08, 2008 | Televison & Video
42" Plasma TV Problem
same frustrating symptoms on brand new 42inch here! tv just turns itself off sometimes without warning or if changing to certain channels. leaves red light flashing for a while then red light goes away. any attempts with remote gives flashing green liht on tv. manual power off and on restarts tv but auto off again. found while manual power on keep changing channel on remote till stable picture appears. then use remote to shut down tv - solid red light indicates standby mode. then use remote to turn on again... till next time it happens. but what is technical fault??
Aug 18, 2007 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Samsung PCJ522R 52" Rear Projection Television Logo
66 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
