Question about Dell Dimension 3000 PC Desktop
Would like to go inside comeputer to clean dust build up out
  • 557 Answers
I have to disagree with the dell expert. The side of the case slides open. Tere is a release latch on the back, and there also may be 2 screws you have to remove before being able to use the latch. Also do not use a vacum to get the dust out. A vaccum cleaner can create static. Use compressed air. To verify I am inserting a link from the Dell site as to how to open the 3000 case.
http://support.dell.com/support/edocs/systems/dim3000/en/SM/cvrop.htm#wp1076111
Posted on Sep 27, 2009
    President:
  • 2,600 Answers
Lay the case on its side, push in the two long eliptacal buttons and lift the case open like a clamshell. If it feels really heavy in you hands, it may be upside down, you want the motherboard section on the floor, look at the output panel on the back of the computer for a reference.
Here is the link for the user/service manual...
http://support.dell.com/support/edocs/systems/dim3000/en/SM/index.htm
Water/ice build up in center column of fridge
clean the backside fins of the fridge..they get gummed up with dust and cannot cool the water effectively..clean inside and especially outside back and bottom..also..defrost it fully first..
Jan 08, 2014 | GE Refrigerators
The faceplate display on my JVC stereo has a lot of dust inside it. Can I disassemble the faceplate and clean the inside? Everything works great, it is just more of an irritant!!
Yes, you can take the faceplate apart and use air pressure or a photo lens brush to remove the dust. You probably won't get all of it off as the dust is attracted to that area due to the static build up. You can try using an antistatic spray on the lens to try to dampen down the issue longer.
Nov 29, 2012 | JVC KD-S890 CD Player
Optiplex 755 Internal Speaker Not Working
Download from Dell Suport the R64900.EXE driver. It's workerd for me.
Mar 22, 2012 | Dell Computers & Internet
Is there any fuse inside the KH624 power supply?
Typically, there are no fuses inside these devices. You'd think that there should be - but it's not the case. Most of the time, power supply units (PSU) begin to overheat and ever so slowly die. Replacement PSU have dropped in price - like everything else. Your best bet is to replace it and maintain it from here on in to ensure a long life.
PSU's overheat and fail because of dust. Lots of it. The fan inside blows air into the PSU case to help keep the component cool. Unfortunately, dust gets blown in at the same time - and slowly builds up on all surfaces and components. The dust build up acts as a thermal insulator that prevents the air from removing the heat. A PC on the floor will have a great deal more dust build up inside than if it were on a desk top. Oh, and the fans in the PC (not just the PSU) blow dust all over the motherboard components and expansion cards inside it, too. The most expensive components are the CPU and video card(s).
Move the PC to the desk and regularly clean the components that have fans on or near them ideally with a vacuum or if unable to vacuum - blow out with compressed air to keep them running reliably.
Nov 26, 2011 | Dell L375P00 (KH624) 375Watt Power Supply
The 3 filters were very dirty - so i cleaned them . Is the something inside the unit that also needs cleaning??
Hello, it is also a good idea to check out the blower compartment for dust and vacuum if needed. If large amounts of dust build up on the blower wheel it can cause the unit to trip on the high limit switch due to low airflow.
Sep 28, 2011 | Heating & Cooling
Hitatchi lcd tv model 32LD6600 B can I clean
Yes,take a cotton cloth damp it with some water nothing else,softly move all around the LCD screen to clean the dust off.Or tries Ebay.com,Amazon.com to buy a package of cloth call the Micro Fiber clothes to clean.These Micro Fiber clothes are for cleaning eye glasses,deligate surfaces,and electronic devices screen.
May 18, 2010 | Televison & Video
IN MY JUST PURCHASED UNIT I HAVE ENCOUNTERED WHAT APPEARS TO BE DUST OR PARTICLE SPECKS IN THE VIEWING SURFACE WHICH ARE MOT RELATED TO THE NEGATIVES OR SKIDES. I HAVE SCANNED APPROXIMATELU 900 SLIDES AND...
Most of these devices have photoelectric sensors build-in, which tells the unit whether there is too much paper dust on the sensors, When there is too much paper dust covering the sensor, the device will report to the User that there is too much paper dust on the sensor, and the device will not function properly, due to the build up of paper dust.
Get a can of compressed air and gently spray inside the device, to remove the build up of paper dust,
-a.
Dec 06, 2009 | Pacific Image Electronics Memor-ease...
My acer 5420 keeps overheating and shutting down
Clean the insides of your Desktop case.
1. make sure all the fans(CASE FANS, POWER SUPPLY FANS AND CPU FANS) are working dust and lint free.
2.remove dust and dirt build up in CPU heat sinks.
3. remove dust and dirt build up in the motherboard, RAM and
expansion slots.
4. remove dust and dirt build up on CD-ROM's, Hard Disk Drives and expansion bays.
5.apply new thermal paste on your CPU.
Jan 20, 2009 | Computers & Internet
Dell Dimension 3000 PC Desktop Logo
139 people viewed this question
Alun Cox
