The blower starts fine , but to keep it running you have to hold the the choke in between full and half. I'm wondering which inlet on the fuel bulb gets the large fuel line. Also I may have put the fuel filter in the tank on the wrong line. I presently have the large line on the top inlet of the primer bulb and the filter (in the tank) on the smaller line. Where did I go wrong?
The smaller line is the supply to the carb. and should have the filter in the tank, with sufficient length to allow fuel pickup from the bottom of the tank.The larger line returns excess fuel and pressure to the top of the tank.By squeezing the bulb and watching the fuel lines you will be able to determine if you have them right on the carb.
Testimonial: "Somewhat clearer, I haven't had a chance to test the primer bulb to see if I can figure this out. Thanks for the input."
I just replaced my fuel lines as well. The bottom inlet is for the smaller line, the feed. The larger line goes on the top inlet, the return.
