Question about Hotpoint WF430 Front Load Washer
Really noisy when spinning - Hotpoint WF430 Front Load Washer
    Genius:
  • Hotpoint Master
  • 1,461 Answers
Sound like drum bearings ..However try checking concrete Weights top and bottom .. they may be loose
Posted on Sep 27, 2009
How to clean drum wont let me choose cycle ?
If it is really loud and noisy when on spin it will almost certainly be worn or rusty bearings. Workshop job to dismantle and replace the parts.
Jul 18, 2016 | Fisher and Paykel Fisher & Paykel Washer
MAH3000AWW washer goes thru spin cycle but leaves the clothes really wet and is really noisy.
had similiar problem , there was a piece of clothing stuck in a drain hose
Mar 02, 2013 | Maytag Neptune Washer
My top loader Kenmore type 111 is working fine until it get to the spin cycle. It won't spin and it makes a really loud buzzing sound. like a weedwacker or something. Help!!!
verify that hot and cold water are not reversed and BOTH are turned on. Sounds like water is shut off. Water valves are noisy without water pressure.
Sep 06, 2010 | Kenmore 22642 Top Load Washer
During spinning it is really noisy now. works
you should never use bleach in any machine as it will damage your machine beond repair.and yes i think your spot on the main bearing is gone and needs replaced.adrian,,,,
Jun 28, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Noisy spin cycle
If the machine has been overloaded you may have partially damaged the coupling between the motor and the gearbox.or you may have damaged the gearbox itself...The coupling is a simple job for a tech but the other problem can be more expensive. Fortunately changing a gearbox does not take a long time. Check with a tech....Good luck....Nomess
Apr 20, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Ariston Margarita 2000 NOISY spin cycle....
Remove drum drive belt, and spin drum by hand, if there is any resistance,. or it feels rough or noisy, the the main bearigs have probably failed.
If it is o/k then check motor for worn or noisy bearings,
Please rate my solution.
Thanks.
Jul 24, 2009 | Ariston Technologies Ariston AWD12 Front...
Really noisy when in spin mode
If the machine is brand new then you should have removed the transit bolts from the back of the machine before use. If you have had it some time then you will find that the concrete counterweight on the underside of the machine has come loose and needs to be re-tightened. It can be quite awkward on some machines so if it is too indepth for you then please ask a competent person to help you.
Apr 11, 2009 | Hotpoint Aquarius WMA56 Front Load Washer
Kenmore front load washer that's noisy when it spins
on most kenmore front loader after some time the bearing start to wear and the washer will get louder and louder,it is a big repair job!-mike
Mar 23, 2009 | Kenmore HE2 Plus Front Load Washer
REALLY NOISY
posted by mikey b from st Helen's. after experiencing a similar fault on my wt741.i set about determined to find the cause of the noise.On spin,particularly fast spin the washing machine was making a horrendous vibrating banging noise.i eventually traced the fault to the lower concrete weight which simply needed tightening. which is held on with 4 10mm bolts.the weight can be easily accessed by turning the washer on its side.support the outer drum with a small block of wood against casing before lying on its side. you will need a 10mm spanner to get on bolts.hope this was helpful !
Jan 15, 2009 | Siemens WFXD8400UC Front Load Washer
Washing machine really noisy on spin!
Probably main drum bearings worn
If you turn the drum by hand and it feels rough or noisy ,then definately bearings worn and noisy.
Nov 19, 2008 | Washing Machines
Hotpoint WF430 Front Load Washer Logo
117 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
