Won't rinse clean - Washing Machines
    President:
  • 1,776 Answers
Check for a cold water supply problem since cold water is what's used in the rinse cycle. Unplug the machine and turn off the water. Remove the water supply hoses and check the small metal screens inside the valve. Make sure they are clear of rust or debris. Check the solenoids using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a bad solenoid and the water inlet valve assy will need replaced. I'll attach a photo for reference. Sorry for your trouble and I hope this helped. Best wishes.
Posted on Sep 27, 2009
Just hums won t start
Their is 2 screens towards the back right that are plugged up. . You can take out 2 screws out and clean them up. Or the fill level adjustment in the front left isn't working right. It also can be fixed with 2 screws and cleaned.
Apr 21, 2014 | Haier Dishwashers
Hotpoint Aquaris df62 - the rinse aid reservoir seems to be blocked with crude and won't allow me to fill it up..How do i clean this out?
you cannot clean it out ,the whole dispenser needs to be replaced . you should be able to get the dispenser kinda cheap
Feb 20, 2013 | Dishwashers
My washer won't drain the water when it spins to rinse cycle and it won't drain when it's on the spin cycle
there is a screen that needs to be cleaned out on the bottom under the wash drum
Jan 15, 2013 | Washing Machines
My lg model wm2277hs won't rinse water stays after washing
you need to ck the filter in the front down at the bottom left corner of the washer if it is clean you will need a new drain pump motor
Nov 02, 2012 | Washing Machines
My bissell proheat 2 x won't spray water
PLEASE GO TO THE PAGE FOR TROUBLESHOOTING AND HELP
http://www.bissell.com/how-to-videos/
God bless you
Jul 23, 2012 | Bissell Vacuums
My bissell proheat 2 x won't spray water or vacuum water
please go to the web pages videos for troubleshooting and help:
God bless you
Jul 23, 2012 | Vacuums
Maytag LSE7806ACE washer won't rinse. Machine fills with water and agitates, spins also. Just won"t rinse......help!!!!!!!
Your washer uses cold water only for the rinse cycle.
Start you washer and put the water temperature switch on 'cold' to see if you have any cold water.
If you find that there is no cold water then turn the water off and remove the cold water hose from the back of the washer.
Once you have the cold water hose removed you will be able to look in the water valve and check the screen. A lot of times the screens get plugged up and need to be cleaned. The screen will just pull out of the valve so you can rinse it out good.
Make sure to put the screen back in place.
If you have no cold water and the screen is clean then you will need to replace the water inlet valve.
Aug 03, 2011 | Washing Machines
My dishwasher won't clean the dishes properly - very poor cleaning results with residue left on the dishes.
Check The Salt-Level ? Dishwashers rely, On salt and cleaning Fluids/Rinse Aids et,c. Also check for Any Blockages or Obstructions/Kinks/Bends et,c. in The External Outlet/Waste pipe.
Mike.
Jun 02, 2011 | Hotpoint 24 in. FDW60 Free-standing...
Greetings from Downunder, i have a HDWSE12 dishwasher Rinse aid light flashes all the time and it won t go. I put dish liquid in rinse aid container - still flashes. Don't normally have to use rinse...
the rinse aid compartment has to be one of the biggest things in your unit. it helps with drying process or you will have wet dishes, helps with spots, and also with the cleaning process, this is what you can do . add jet dry or rinse aid not soap .fill compartment then close door ,then raise and lower door 3times then open the compartment door and add more repeat this process until you cant add anymore. this will pull all of the air out of the dispenser and allow you to fully fill compartment . the light should go off .
Mar 04, 2010 | Dishwashers
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
