Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
Good battery, good starter. Wen coil wire is connected, the engine goes whoop/whoop before starting . 140,000 miles on the engine . The manuals say that the timing cannot be adjusted. How would I tell if is the Timing Chain?
  • 344 Answers
If it was your timing chain my freind your engine wouldn't run
Posted on Sep 29, 2009
Bownes lawn tractor wont turn over. Battery fully charged and all safety switches were changed. its a briggs and stratton 12 1/2 horsepower
with a volt meter set to DC, pull the wires off of the starter solenoid coil (the small wires) and check for 8 - 12 volts DC at the wires when the key is turned. A poor connection at the solenoid coil will cause slow turning engine cranking or none at all.
If you have 8 - 12 volts there check for voltage to ground on the large cable that goes from the solenoid to the starter motor, one probe on the cable and the other on ground or ( - ) at the battery. Turn the key to start, if you have voltage to the starter motor but it does not turn loosen and retighten the mounting bolts to the starter motor and if that does not help do the same for the engine to ensure you have a good ground. If none of that works your starter motor needs to be replaced, if you have no voltage to the motor the solenoid or battery connections are faulty.
You can also quickly test starter health by conecting a set of jumper cables to a good battery, clamp the neg. to the engine block anywhere and tap the pos. to the starter cable connection from the starter solenoid, if the engine spins over your starter is healthy and the issue is certainly between the key switch and the starter solenoid.
Jul 07, 2014 | Briggs & Stratton Briggs Stratton Intek V...
I have a 1991 honda accord that recently began to give me problems when starting. The car has 245,000 miles on it. Initially it was sluggish in turning over, would catch and try 2 start, start, but...
You have got good use of it. I through 200,000 was it. Its a neutral switch. About time for new one. I am on fixed income too. Know how you fill.
May 01, 2014 | 1991 Honda Accord
Chevy Tahoe Intermittent No Crank
I will try to help, powell. Your start circuit from battery to ignition switch to starter-and back to battery. You may need to check every thing here, including the grounds, for a loose connection, or just possibly a failing part.
If only complaint is intermittent starter action, and no other problems with ignition switch, let's assume switch is good, so battery to ignition switch is good. Now from the switch, a yellow start wire goes to the instrument panel fuse block, to "crank" fuse #8 (10 amp), from there a purple wire goes to the safety switch. If manual it is a clutch pedal position switch (simple on/off switch-when clutch down switch is on). If automatic, purple wire goes to Transmission Range Switch on the transm.-in park or neutral the purple wire has continuity in and out of switch.
From that switch, the purple wire goes to the starter relay (under hood fuse-relay center). Now the relay: purple wire in start will energize the relay- wire goes to coil side of relay, and then coil side goes to ground. On relay power side, the power feed is a red wire-and it is the same red wire that initially sends power to the ignition switch. A 40 amp fuse in fuse-relay center sends power to ignition switch, and a splice goes to the starter relay as the power feed for relay. When relay is energized, contacts close, and power is sent from relay to the starter solenoid, again on a purple wire. When solenoid contacts close, starter motor is connected to the big battery cable on the starter.
There is your start circuit. try a new or different relay, try a new or test the clutch switch (or transm. range switch). Buy a $5 test light and use it to check where power is lost when starter won't operate. Hold key in start and check if fuse #8 is getting power. Check the safety switch, with key held in start, the purple wire should be hot. Check if relay has a power feed (pull relay out and check terminals) and if relay coil has a power signal in start. Check the relay's coil side ground. If that ground is intermittent, relay won't work.
When it won't start, use a test light, you should be able to find it.
Good luck.
Jan 10, 2014 | 1997 Chevrolet Tahoe
When the temperature is in the mid to low 30's, 92 Honda Civic will not turn over. No griinding or anything, not even a click. I've been told the battery, starter and carburator are ok. Help! Taxi's are...
Let's see if I can explain it. Pretty simple start circuit, but starting issues are very common to Hondas and Toyotas of the '80's and early'90's. Lots of guys used to rewire their start circuits with new wiring and relays from ignition switch to the starter solenoid just to stop those no starts.
From the ignition switch is the black/white start wire, it is hot only in start, goes direct to the "starter cut relay"- a 4 pole starter relay, the black/ white wire (black with a white stripe) is both the power feed and the coil power to the relay. Before the wire enters the relay it is spliced. one wire goes to power feed at relay, other wire goes to coil side of relay. Here's where the clutch switch comes in: the clutch switch acts as the ground for the relay's coil side. Okay, you turn key to start, power goes to the relay on both the power side and the coil side. When clutch is depressed, it grounds the coil side of relay, this energizes the relay, so power goes out of relay on the power side, as a black/red wire...and goes direct to the starter solenoid. Somewhere before it reaches the solenoid, it turns back into a black/white wire. But nothing else is in a wiring diagram for your start circuit. Buy a can of CRC electronic cleaner. Spray all connectors in the start circuit. Pull off the solenoid wire at starter-that connector. Also the starter relay , pull it out and clean the relay terminals where it plugs in. Get all clean connections in the circuit. If no help, swap in a different relay. If still no help, get a voltmeter (or a test light), when the starter doesn't want to work, check for power at the starter solenoid with key held in start, and clutch depressed. If power there, the solenoid is the problem. If no power, work back to the relay. Pull relay out. With key held in start, two terminals for the relay should have power-the coil plus side, and the power feed from the ignition switch. If both have power, may be the clutch switch not grounding the relays coil side. If no power to relay, check the start wire out of the ignition switch.
Need a wiring diagram? This site is awesome-free wir. diagrams and TSB's for every make and model:
Dec 26, 2013 | 1992 Honda Civic
2004 kia rio won start
check your battery, starter or ignition.
___________
allscanner its3
Dec 27, 2012 | 2004 Kia Rio
I have a 1994 honda civic and it wont start the dash lights light up but then nothing there is no sound of the engine trying to turn over..what is it likely to be? just the starter or more?
1st check battery terminals to be making connections,next,make sure battery fully charged,then move to fuse box under the hood for burnt battery fuse, then check battery charge,if good,then suspect bad connection to starter (wires) then suspect bad starter. if not that,then try to turn engine over manually by crankshaft bolt to see if cranks locked. thank you for choosing fixya.com
Apr 01, 2011 | 1994 Honda Civic
I just finished rebuilding my truck engine and will like to test it before installing back in the truck. I know how to get the starter going, but I don't know how to wire the coil, distributor, alternator...
To start the engine you need a+ feed from the battery to the + side of the coil[this acts as an ignition live,to be disconnected when not testing the engine ]Next you need a heavy + feed directly from the starter to the battery[use good heavy cable]Also a good heavy earth lead from the battery negative to the engine block[jump leads work great]Connect the distributor contact breaker wire to the coil - side.To start take a live+ wire from the starter + to the "pull in" terminal of the starter[this is a male spade connector and the lightest terminal on the solenoid.when you connect the starter to the battery + the engine should turn over,Check for a spark using an old plug earthed to the block,add some fuel and listen to that baby run.
Mar 08, 2010 | Ford F-100 Cars & Trucks
Starting problem
do you have a volt meter at all? If so check power on the small connecter on the starter. the small connecter only has power when the key is in the "start" position. If you have 12Volts or very close while in "start" then you have good power from your lock cyl.
If it drops in voltage while cranking then you have wiring problems or bad connections. If you do not have any power then the problem is within the wiring or something before ther starter. if you have power to the starter., everything is working to that point, But this doesnt mean istarter is good.
To check the starter you need to make sure its drawing amps. if you have a starter removed it can test amps only continuity cause there is no real load on it like turning an engine..(very common) you can do a very easy test by turning headlights on while in "start" position. if your lights dim slightly then your starter is working the way it should and if it dims alot or goes out, you have another issue.(bad battery, or connections, or locked up engine) to be sure make sure your connections are good on everything and check for bad battery cables and or corrosion. change as needed.
If your lights dont dim at all then most of the time the starrter is bad cause it doesnt draw ant amps, which usually is a bad motor or bad connections somewhere. I know this is long but i tried to cover all the areas at once. This goes for every car. :)
good luck ,
Michael
Apr 29, 2009 | 2000 Pontiac Grand Prix
Not starting
i had the same problem with my 92 cherokee laredo, could be the crank positioning sensor. if it goes bad you dont get spark from the coil. or it could be the coil, distributor, or even spark plugs.
Mar 22, 2009 | 1992 Jeep Cherokee Sport
1990 bronco v8 4wd short version wont start
did you try giving it a good tune up?
If it has been more than a year since you have given it a tune up, plugs and wires, this is more than likely your problem, with a truck of this age, they tend to gunk the plugs up....
Nov 26, 2008 | 1990 Ford Bronco
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
99 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
