Question about Sanyo PLC XU50 Multimedia Projector
Sanyo Projector PLC-XU50 Lamp Hours
I am trying to sell the aboe item and people want to know how many lamp hours it has left, but I don't know how to find this out.
Could you please let me know how to find this out from my machine?
Regards
Karyn Hall
Turn projector on and before doing anything else, press and hold the UP arrow on the machine for 30-40 seconds WHILE watching the display screen on the wall - the remaining hours will display only momentarily - if you look away you could miss it. Cheers
Posted on Jan 31, 2008
Sanyo plc-xt16 Projector After the projector is turned on and the countdown finishes on initial start up the projector shuts itself off within 5 seconds. The fan runs for 1 minute and then the projector...
It sounds like the lamp is going.
Do you know how many hours of use are reported on the lamp?
Many times these projectors have circuitry to shutdown when they suspect the lamp is near the end of life. Lamp hours vary and usually will go up to and even beyond expectancy, but there is occasions you can receive a bad lamp and have it blow in a matter of hours...not common but it does occur.
I hope this helps,
Magoo
Mar 09, 2011 | Sanyo PLC-XT16 Multimedia Projector
Sanyo PLC XU48 Need to know the lamp hours!
press and hold down the power button for about 20 seconds. The info will show in the top right of the screen.
Micketec
May 25, 2010 | Sanyo PLC XU48 Multimedia Projector
How do i reset the timer
go to the menu, find lamp settings then select, lamp counter resit. confirm.
Oct 22, 2009 | Sanyo PLC XU50 Multimedia Projector
Is there any way to check the bulb life on a Sanyo PLC-XU30 projector? I know some projectors have an option on the menu screen which lets you know how long the bulb has left. Its just that i bought it off...
on my XU 55 the trick to read the lamp hours is to press and hold down the power button in about 20 seconds when the projector is turned on. there will come a window in the upper left corner that tells about total hours and lamp hours. the window will disappear quite fast, so one might need to do it twice.
Jul 28, 2009 | Sanyo PLC-XU30 LCD Projector
Sanyo plc-xp46 lcd projector
In the on-screen menu...
Press MENU, go to SETTINGS ICON, Move to Lamp Reset
Also, to see lamp hours used, press and hold the UP ARROW (on the unit, not on the remote) for 30 seconds while projector is on
Feb 10, 2009 | Sanyo Projector Lamp for PLC-XU100,...
Sanyo PLC XU50
It may be that the lamp actually does need replacing so that may be why it's not coming on?
May 13, 2008 | Sanyo PLC XU50 Multimedia Projector
Sanyo XU50 not coming on after lamp replacement
Hi oatesy13
You will have to reset the lamp timer to resolve the problem.
Consult ypour user's manual on how to do this.
Should do the trick , If you do however need any further assistance , please send me a request and I'll respond to it.
How to check lamp hours on xf-45 or xf-35?
On the XF-45, you push the "UP" button and then the "Menu" button and hold both of them for approximately 20 seconds. After that you will see a bunch of numbers in the top left hand corner of the screen. Using the Left and Right arrow keys, move the "Group" number until it reads 111. Then using the Up and Down arrow keys to scroll through each lamp (0-3).
If you move the "Group" number to 110, you can see total number of hours that socket has run.
Jan 22, 2008 | Sanyo PLC XF45 Multimedia Projector
Warning lamp glow
Hi
Does your projector still work?
The warning lamp is there to let you know there is a problem, usually overheating! Make sure it is well ventilated and that the filters have been cleaned.
Try disconnecting the AC power cord and then reconnect it to check if it is still happening.
Oct 05, 2007 | Sanyo PLC XU50 Multimedia Projector
Sanyo PLC XU50 Multimedia Projector Logo
337 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
