Question about Garmin nuvi 650 GPS Receiver
My garmin nuvi 650 will not go to next screen it
When I turn my garmin nuvi 650 on it will not go to next screen when I tap to advance. It seems to be frozen.
    President:
  • 1,111 Answers
Have you tried the master reset?
plug it in to the usb port on your computer for a few hours.if that fails,then try the master reset.
note: that the master reset will erase all your saved data
with the unit off,and unplugged, try pressing and holding your finger on the low right corner of the screen and slide the power switch to the on position until you see the message "confirm if you really want to delete all user data?" hit yes and let it restart. then it will set up the nuvi again, so follow the prompts.
if that fails, hook up the nuvi to the web updater and get the latest update.
download the updater HERE
(actually i would do this either way)
bill
Posted on Sep 27, 2009
My Gamin Nuvi can't unlock maps
Use a Garmin 1450
The Garmin Nuvi 1450 can be used while driving or walking.
While driving, use the Nuvi 1450 to create a route to your destination and get step-by-step directions, to hear the names of upcoming streets, to tell you when to change lanes and to find out the speed limits on unfamiliar streets.
As a pedestrian, you can have the Nuvi 1450 create a route for you that uses a mixture of walking and public transportation, such as the subway or bus system, if you have purchased cityXplorer maps for that area.
Tap "Where to?" to set up a route. The "Where to?" icon is a large magnifying glass.
Tap "Addresses." The available categories are address, points of interest, go home, recently found, favorites and intersections.
Input the name of the state or county, if it is out of town.
Then tap "Spell city." Spell out the name of the city using the pop up keyboard.
Press "Done."
Enter the address number and press "Done."
Then enter the street name and press "Done."
The "Go" screen opens automatically.
Tap the green "Go" button. The Nuvi 1450 will now calculate a route to the address.
Follow the voice prompts and map highlight to your destination.
Navigate Using Coordinates
Tap "Where to?" and then tap "Coordinates."
Tap the coordinate you want to adjust/input a new coordinate.
Tap "Format" to choose the right coordinate format for the map you are using.
Enter the coordinates. Tap "Next."
Tap the green "Go" button to calculate a route.
Use the Map Page
Navigate to your destination by following the voice prompts, highlighted route on the map and directions located at the top of the map screen.
Tap the "turn" icon located in the upper left corner of the screen to see the next turn. It may have a turning or straight arrow and the number of miles until the turn. Tap the bar across the top with the next direction listed on it to see a list of all directions.
Tap the plus or minus signs on the right side of the screen to zoom in or out.
Press the spinning arrow in the lower left corner of the screen to return to the main menu.
Tap the "car" icon traveling along the highlighted route to enter the "Where Am I?" screen and get your exact location, coordinates and nearby emergency services.
Hope this helps
Oct 29, 2012 | Garmin Nuvi 1450 GPS Standard Red LED Wall...
No sound
Turn the volume up. Turn on the Garmin Nuvi. Tap the "Volume" button on the "Where to?" or home screen. Move the slider for the volume up.
Unmute the Garmin Nuvi. Tap the "Volume" icon again. Uncheck the "Mute" option, if it is currently checked.
Make sure the voice is not faulty. The navigation instructions are provided by a voice.To verify whether or not the present voice is faulty, you must switch the voice. Power on the Nuvi and tap the "Tool" icon. Tap "Settings" in the Tool menu. Tap the "Language" option and tap the language you want. Then select another voice to use. Now go back to the home screen and enter an address into the "Where to?" option. See if you can hear sound now.
Update the Garmin Nuvi with WebUpdater. Download and install WebUpdater from the Garmin website (see Resources). Launch WebUpdater on the computer, and connect the Nuvi to the computer with the USB cable. The software will detect the Nuvi and locate all updates for the device. Confirm that you want to update the device when prompted and WebUpdater will download the updates to the Nuvi.
Reset the Garmin Nuvi. A master reset will restore the Nuvi to its factory configurations and delete all favorites and waypoints that have been added. Power off the Nuvi and unplug it from any power source. Hold your finger down on the bottom right corner of the Nuvi screen, at the same time power the device back on. When asked "Do you really want to erase all user data?," remove your finger from the bottom corner of the screen and tap "Yes." The device will reset and sound should be restored.
Here is a direct link to the user manual >>
http://static.garmincdn.com/pumac/nuvi_1100_1200_1300_1400_OM.pdf
Jan 06, 2012 | Garmin Nuvi 1490LMT GPS Receiver
Touch screen not responding at all. Garmin powers up okay.
This is Garmin's response to me after having the same problem on a 2 year old Nuvi 650: We are no longer replacing or repairing this model unit. However, let me give you some steps to try to calibrate the screen of your unit. The following 'Fix' did not work. I won't be buying another Garmin.
To recalibrate the touchscreen on your nuvi 600 series device please follow the steps below:
  1. Plug the device into the computer via USB data cable
  2. Double click My Computer (Mac Users can skip this step)
  3. Double Click the Garmin or nuvi drive
  4. Double click the Garmin folder
  5. Delete the GUPDATE.GCD file (if this file is not on the device please skip to the next step)
  6. Unplug the GPS device from the computer
  7. Power the device off
  8. Press and hold the Power button
  9. After a short period a screen should appear that says Touch Dot
  10. Release the Power button
  11. Touch the dots as they move around the screen.
Your touchscreen should now be recalibrated.
If the screen is still not responding, then the unit will need to be replaced with a new unit at this time.
With Best Regards,
Benjamin B
Product Support Specialist
Automotive Team
Garmin International
913-397-8200
800-800-1020
913-440-8280 (fax) Att: Benjamin B, Associate #6891
www.garmin.com
Additional solutions may be found at http://www.garmin.com/garmin/cms/site/us/support/searchsupport
Sep 05, 2010 | Garmin nuvi 650 GPS Receiver
Nuvi 650 touch screen stopped working
My Garmin Nuvi 650 would boot up and load maps, but I could not enter my access code. Screen would not respond. Turned off & on a number of times, but still same problem. This occurred on first use after upgrading the maps. Thinking it may have overheated on the dashboard of my truck, I held the device in front of the air conditioner vent for about five minutes to cool it down. When I then turned it on, it worked fine. For the rest of my 3-week vacation, I kept it cool & out of the sun when it was not turned on. No problems after that.
Jul 17, 2010 | Garmin StreetPilot c340 GPS Receiver
Garmin Nuvi 650 powers off when connected with car
I had this problem. The problem turned out to be my car charger. Hooking the GPS up to my computer allowed it to charge and operate normally. A new car adapter might fix you right up.
Jul 06, 2009 | Garmin nuvi 650 GPS Receiver
Replacing battery in Garmin Nuvi 650
I discovered a video on how to replace the Nuvi 650 battery. Hope this helps, Rob
Feb 15, 2009 | Garmin nuvi 650 GPS Receiver
Garmin nuvi 650
Got a solution for you:
You need to set the language properly in order to get the speech for street name
Go to setup --> Locale - Voice Language
Select language with TTS (Text-To_Speech) next to it:
ie:
American English-Jack (TTS )
American English-Jill (TTS)
Australia English-Karen (TTS)
Apr 22, 2008 | Garmin nuvi 650 GPS Receiver
Garmin nuvi 650 GPS Receiver Logo
809 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
