Question about Sony VAIO PCWA-C150S 802.11b Wireless Adapter
Changed HDD, unable to detect wireless hardware
I have a Sony Vaio VGN-NR21Z and having just changed the hard drive, the wireless hardware is not showing in the network adapters list. I'm sure I need the drivers. I can't connect with that laptop but I have a working laptop which can connect, and a 16GB flash drive which I hope I can use to transfer the driver, if I can get some guidance as to how to do that! I can't work out which drivers I need so please help!
Thanks
Charlie
  • 63 Answers
Well google search the drivers to find out what you need then make shure your fash has enuff memory on it to fit the driver on it then click and drag the driver's program files to the flash and then plug it in to the other pc then open mycomputer then program files then drag and drop driver's files there. Then instal driver (if needed)
Posted on Sep 27, 2009
My vaio van sz483N will not start following a hard drive replacement?
The HDD has not been placed correctly leading to a short circuit so the laptop does not switch-on . Remove the HDD and power-on the laptop if it switches on then need to check the HDD .
Jun 17, 2015 | Sony Vaio Vgn-sz436n/b / Vgn-sz476n/c /...
Hi, own a Sony Vaio VGN P530H with hardisk Toshiba MK6028GAL damaged. as forced to replace unit, wonder could install a higher capacity? Brand & model if available please!!! thanks to all of you!!!
The VAIO VGN-T350 is a notebook computer designed and distributed by Sony.
The hard drive on your Sony VAIO VGN-T350, which is the unit that stores data, consists of many clusters of data that can be rewritten with new data.
If you are looking for a memory capacity upgrade, or if your old hard drive is having errors, it's time for an upgrade.
Upgrading the hard drive on your Sony VAIO will require the use of a screwdriver and will take you about 30 minutes to complete.
Turn off your Sony VAIO VGN-T350 and remove the power cord and any other peripheral components.
Turn over your Sony VAIO VGN-T350 and locate the hard drive chamber on the bottom of your laptop. It will be clearly labeled.
Use the screwdriver to remove the screw holding the lid in place.
Gently lift the hard drive and its cage away from your laptop and disconnect the data cord.
Remove the four screws located at the corners, and then remove your old hard drive from its cage.
Place your new internal laptop hard drive into the cage and replace the screws.
Connect the data cord to your new hard drive and place your new hard drive into its chamber.
Close the lid and replace the screw to complete the operation.
http://www.fonerbooks.com/laptop_1.htm
http://www.youtube.com/watch?v=rg_GvaMunas
Sony Vaio Hard Drive Replacement
This might not be your specific laptop it might give you an insight into the hard drive installation.
Ebay this hard drive should fit there are smaller capacity drives that will be compatible.
http://www.ebay.com.au/itm/New-500GB-Sata-Hard-Disk-Hdd-for-Sony-VAIO-PCG-3H2L-VGN-P530H-VGN-SR410J-B-/190882270487?pt=US_Internal_Hard_Disk_Drives&hash=item2c71784d17
500GB Sata Hard Disk Hdd for Sony VAIO PCG-3H2L VGN-P530H VGN-SR410J/B
Aug 14, 2013 | Computers & Internet
Error 58 unable to write to boot sector
Run CHKDSK, if you see a message "The drive contains one or more unrecoverable problems", you need a new hard drive.
If you cant get on to Windows try a fresh install. If that fails buy a new HDD should fix it.
Nov 26, 2011 | Sony VAIO VGN-A230P PC Notebook
Hi I have a Sony vaio vgn-nr21z I don't know how to go bios setup pls tell me how to do that
Please follow these steps,there are different way od going to BIOS depending on the brand of the laptop.
Turn on your computer
Hold down F2, this will take you into BIOS. On some computers it might be the DEL key, or F1.
Change the settings in BIOS to what you desire. You will see parameters for various devices, if your BIOS allows it, you can even overclock the CPU.
Look at the BIOS menu. You will be able to see the make, model, and capacity of your hard drive, processor speed, time and date, among many other settings.
5
Click "exit without saving changes" if you make a mistake, and nothing will be changed.
Hope this will help...Your response is very much appreciated...
Feb 15, 2011 | Sony Computers & Internet
Sony VGN-TX750P laptop Operating System not found message
try seating the hard drive, the HDD might have been loosened when you changed the part.
Hope it helps!
Feb 14, 2010 | Sony VAIO VGN-A170P Notebook
OPEN Sony VAIO VGN-T330FP TO CHANGE HDD
turn the laptop upside down ...remove a partial plastic cover attached by a screw on its edge ( there is a small sign showing the hard drive usually) after taking the cover of plastic away the hard disk is visible . pull it gently aside (sideway)
and replace it with the new one.
May 29, 2009 | Sony VAIO VGN-T350 Notebook
I could not find your specific model, but here is a tutorial on how to dissasemble a Sony VGN-TX2P
model. Hope this helps:
http://www.r3uk.com/index.php/tech-tips/34-disassembly-guides/47-sony-vaio-vgn-tx2xp-disassembly
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 21, 2009 | Sony VAIO VGN-T350 Notebook
Sony VAIO PCWA-C150S 802.11b Wireless Adapter Logo
221 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
