Question about Whirlpool Washing Machines
Awm1403 water isnt draining properly - Whirlpool Washing Machines
    Genius:
  • Whirlpool Master
  • 1,460 Answers
Could be blocked filter or pump jammed check filter at bottom of machine first ..Be aware water will come out....
Posted on Sep 27, 2009
A few times the machine has not been rinsing properly
Posted on Sep 12, 2010
I have a LG plasma gold airconditioner. water leaks from the inside panel. can I fix it myself?
remove the front cover some wire inside the drain line
replace the cover and clean the filter.
Jul 08, 2014 | LG LS-L1210CL Mini Split Air Conditioner
F21 code
F-21 on this washer means long drain which mean s the drain isnt working properly open the lower panel and open the drian sump (might gush water) and make sure that no objects are stuck if you find anything remove it and try the drain and spin option if it does not help or if you dont find anythin replace the drain pump, hope that helps
Sep 04, 2011 | Maytag MHWZ400T Front Load Washer
My westinghouse washing machine LT809s keeps beeping at me and displaying the error code LL?
It means Low Level. Your water level is too low. Your machine isnt filling up properly or the water is being siphoned out as it fills which means your drain is lower than your water level. or your drain does not have an air lock in it any more.
Mar 31, 2011 | Washing Machines
It isnt draining water. checked waist pipe and it isnt blocked Looks like the problem is in the machine. regards Brian
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 08, 2010 | Dishwashers
Washer will not drain water or spin
Check your drain pump motor. water isnt draining properly or not at all. It could be either something stuck in the piping (drainage), or the pump is not operating.once rectified, it should work properly again.
May 18, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Not draining properly - white film build up everywhere Bosch SHX33A02UC/14
make sure air gap isnt clogged. film is calcium on water. add rinse aid to help film on dishes
Feb 06, 2010 | Bosch Dishwashers
It isnt cleaning ot rinsing properly
Make sure the drain hose has a clear path. Also where the hose connects to your sink drain,if you pull off the hose to check the connection for a blockage have a empty bucket handy to catch the water. If the drainage path is totally clear and it still does not work right then the water pump is weak. I hope this helps you.
Sep 06, 2009 | Electrolux 18 in. ESL4114 Slim-Line...
Clog
Pull the drain hose out and try draining it into a sink or large container. Your present drain source may not have a proper vent. Also sounds like you are using too much detergent. This also can cause a slow drainage. Empty the washer as much as possible then run an empty cycle with only water and see how it drains.
Aug 25, 2009 | Bosch Axxis WFL 2060 Front Load Washer
What causes Cabrio washer to get unbalanced in spin cycle?
Try making sure that your draining hose isnt jammed all the way down the hole. When you installed it the u shaped accessory was needed for the draining hose. Try pulling the draining hose out...curve the front and zip tying it to your cold water valve. This will allow it to drain properly and not get water push back into the drum causing it to be unlevel
Aug 02, 2009 | Whirlpool WTW6200S Top Load Washer
Water isnt draining
Check your drain line and/or drain pump. The drain line should have a high loop at the point prior to where it connects to your drainage system in order to prevent drain water from the kitchen sink from back flowing into the dishwasher. In addition, most drain pumps have a small check valve that prevents this water from backing up as well. However, if you have something lodged in the drain pump (i.e., a toothpick) it can prevent the check valve from closing properly. This can cause water to back up into the dishwasher. You mentioned that the water will not drain. Is the drain pumping runnings at all? Please post back and let me know.
Apr 29, 2008 | Whirlpool 24 in. GU3200XTP Built-in...
Washing Machines Logo
29 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
