Question about Sony Walkman MZ-R500 PC Personal MiniDisc Player
Disk won't fit
My disk won't fit in my computer
  • Woodwose May 11, 2010
    You don't mean a mini disc won't fit..?
  • 41 Answers
There is only one Minidisc Data format and it was discontinued over 10 years ago. Optical Miinidiscs are not not going to fit into a 90 mm floppy disc drive.
Posted on Oct 04, 2009
Can not get the mac pro osx 10 5 8 to start with the utility disk or with regular start up my on pilot lite keeps blinking
Put the Mac install disk back in. Try pressing command-option-escape to force quit. If nothing happens, then press command-control-power to force a restart. If that doesn't work, press and hold the power button for five seconds or so until the computer shuts down. Power up the computer again, and hold the option key so you can select the instal disc for startup. Run Disk Utility again. Sometimes you get a tangled file reference that requires several tries to undo - this could be calling the sleep routine instead of what it's supposed to do.
May 28, 2013 | Computers & Internet
Mac 0sx 10.5.8
The disk might not have a working OS on it.
It you have successfully run the disk utility the disk probably in full working order. I think that the OS on the disk is either missing, corrupt or not compatible with the computer you are running it on.
May 28, 2013 | Apple Leopard 10.5 Osx Mac Operating...
Gateway mp8708 s/n t23691006485 showing disk error won't boot just shows disk error help me
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.
Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
May 20, 2012 | Gateway Computers & Internet
Laptop won'y start up has non-system disk or disk error
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty.First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
May 02, 2012 | HP Computers & Internet
I'd like to replace the HD in my NEC Versa 9100. How do I get the notebook apart?
  • Look at the bottom of the laptop.
  • Remove the two or so screws that hold the disk cover in place.
  • Carefully remove the disk and
  • disconnect any cables.
  • Reverse the process to install a new disk.
Replacing your disk with a blank disk and the computer won't even start up. If you want to copy all the data including programs and the operating system, you need to CLONE the old disk to the new. There are several companies that make this software. Do a google search on CLONE DISK
I do this for fun & 4 thumbs not $$$
Jim
Oct 05, 2011 | NEC Versa VX Notebook
My computer won't turn on properly. It keeps saying disk error press control alt delete. When I do it just says it again and again. It won't load and turn on.
First you should check if there is any disk on your cd room, if there is any disk you should remove the disk from the cd room, if there is no disk the possibility is your hard drive getting error
Press f2 or delete to enter your bios set up system
Look for boot menu
Set the first boot as a HDD and the second boot as cd room and disable the third boot
Save and Exit the setting
if your computer still won't load you need to reinstall your windows
insert windows cd and go to set up again by pressing f2 or delete button
Set the first boot as cd room then the second boot as HDD
Save and exit the setting again
When the message press any key to boot from cd appears you should press the space bar or another key
Then just follow the instruction of formatting
Jun 03, 2011 | Acer Computers & Internet
Where can i download raid drivers for my caliber xn9010?
The driver you need is based on your raid controller on your motherboard or if you have one your raid card, so you need to determine the motherboard manufacturer or raid card manufacturer and get the chipset drivers from their website.
djbr1ck
May 12, 2011 | Cybertron Caliber XN9010 Server
I have recently bought an apple imac and the disc for my so speaky hdmi wont fit in it is there any software i can download
Find a computer that can fit your disk, and copy the files from the disk onto a CD-recordable disk.
Then, put the newly-recorded CD into your iMac's CD-drive.
Nov 15, 2010 | Dane Elec Dane-Elec (DA-HDO25-320G-N-T-PM)...
I have a Simple Tech (simple Drive) 320GB external hard drive.the light comes on But my computer won`t recognize it. The light comes on but that`s it.
Try connecting the drive to a different computer, to see if your computer is the problem.
If necessary, open the external case, and separate the disk-drive from the USB-to-disk-drive adapter.
Connect the disk-drive as a "slave" disk-drive in some computer, to see if the disk-drive itself still can be accessed.
If not, and you have "important" data on the disk-drive, search the Internet for a professional "Data Recovery Service" -- you ship your disk-drive to them, pay them a lot of money, and they repair the disk-drive, just long-enough to copy your files to a brand-new disk-drive.
Jun 12, 2010 | SimpleTech 320GB SimpleDrive External by...
Sony Walkman MZ-R500 PC Personal MiniDisc Player Logo
93 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
