Motor runs but wont spin - Washing Machines
    Genius:
  • Washing Mach... Master
  • 1,461 Answers
Could be belt off / broken aree you sure its not the pump you hear running?...Always disconnect the electricity supply before repairs...
Posted on Sep 27, 2009
Replaced the clutch and motor coupler a month ago. Ran great. Washed tennis shoes. Came in to remove clothes, didn't spin. Wont agitate or spin, i could hear the motor running. Just replaced the motor...
Check for a failed capacitor under the control panel It is a start/run capacitor that the motor needs to start running. The motor will hum and if left will eventually burn out.
Aug 17, 2013 | Kenmore 23822 Top Load Washer
Lg DLE3777W wont start
if the motor is running and the drum is not spinning check the belt that wraps around the drum and motor. may have broke or just slipped off
Jun 21, 2012 | LG DLE2512W Electric Dryer
Wont agitate or spin tryied putting on drain spin setting pump will run and run but wont spin
Top loader washers the main reason is either the motor coupling has failed. You will hear a grinding or growling or whirring noise or the lid switch has failed. The lid switchy will keep it from spinning but usually it will agitate. Check and make sure the drum is not froze and won't move, if it is free, check the coupling under the tub and make sure the motor and tranny are connected. If they are then the transmission may have failed. If this is a front loader the main reasons are a bad motor.
Mar 31, 2011 | Washing Machines
Wont go into spin cycle and wont drain but makes a buzzing sound while in the spin cycle
plugged or bad pump or bad drive motor. if it has a seperate pump and motor for drain could have somthing in it if the pump is driven by the main motor pump could have frozen up or motor could be bad in spin mode sometimes the timer won't make the motor run just hums ges are good for this make and model #s help us help you good luck
Dec 08, 2009 | Washing Machines
Water wont drain and will not go into spin cycle
You have a bad motor. Whirlpool direct drive machines, the motor runs in one direction to agitate and the other direction to spin and pump out. The pump runs all the time due to it being attached directly to the motor shaft, but only pumps when the motor is running in the direction that it runs when it spins.
Please rate solution
Sep 08, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Blows 6 amp fuse in top panel. On spin cycle runs the pump but motor wont rotate for spin. If left blows fuse again.
Remove the hoses and check the impeller of the pump for an obstruction.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 29, 2009 | Washing Machines
Wont spin does everything else but spin
Your spin cycle control seems to be bad. This is also called your timer. Check for power supply by pulling off your top panel and checking for power everywhere.
Apr 17, 2009 | Crosley CAWC529JQ Top Load Washer
My washer wont spin
Your symptoms that indicates a broken motor coupler. If your washer will drain and fill but has not agitation action or spinning action that would indicate a broken motor coupler. The motor coupler links the drive motor to the transmission.
Jan 31, 2009 | Frigidaire Affinity ATF7000E Front Load...
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
