Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
My washer keeps going F1, as soon as I start it. Then I have to open it move the tub around start it again. It does it about 2 or 3 times then again during the rinse cycle
  • 15,935 Answers
Keypad/User Interface Failure
A fault code of "F" then "1" flashes when there is a primary control failure.
You will need to replace the machine/motor control assembly.
Page 14 and 16, in the manual link below will help you with this.
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
To Access/replace the CCU:
#1
Unplug the Whirlpool Cabrio power cord from the wall outlet. Turn off the water supply to the washing machine. Pull the washer away from the wall so that you can access the screws behind the control console. Remove the hex head screws securing the control console to the washer with a nut driver. The screws are on the lower rear edge of the control console.
#2
Lift the control console up, and rotate the console forward so that the face of the console is resting on the top of the washer. Locate the interface board cable connector to the right of the plastic tube on the back of the console. Pull the end of the connector straight out of the control console. The primary machine control is the box that the plastic tube connects.
#3
Place small pieces of masking tape around the nine wires connecting to the primary machine console. Label the wire locations onto the masking tape with a pencil. Grasp each wire at the connector with your fingers, and pull the wires away from the primary control. Pull the plastic tube out of the primary control.
#4
Locate the nut toward the bottom of the primary control. Remove the nut with a nut driver. Lift the front of the primary control slightly, and slide it down to disengage the retaining clips. Pull the primary control out of the control console. Insert the new primary control into the control console. Slide the primary control up to engage the lower clips. Secure the primary control to the console with the single hex head screw.
#5
Push each of the wire connectors into their respective positions on the primary control until they lock into place. Push the plastic tube hose over the port on the right side of the primary control. Remove the small pieces of masking tape from the wires.
#6
Position the control console back upright on the top of the washer. Secure the control console to the washer with the three hex head retaining screws. Slide the washer back against the wall. Turn on the water supply and plug the washer into the wall outlet.
TECH SHEET LINK: http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208567037.pdf
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$%5
Posted on Sep 21, 2010
Shakes like crazy spin
Your maytag washer tub and basket assembly sits on a base counter balanced by 6 springs. Is is possible to move the tub around by hand. The best test is to start a spin with the unit empty of cloths, allow the tub to reach speed for a few seconds, lift the lid and check the tub position after it stops, if the tub is off center with the lid opening, re center the tub and run spin again. If your tub returns to an off center stopped position you most likely will need the base kit replaced. The base kit replaces the entire bottom of the unit along with new springs, and snubber, if so packaged per your application. Maytag experienced a defective stamping dye when these bases were stamped, thus they were stamped crooked. This test is performed with the machine it's self relatively level on the floor. If the tub assy leans and favors any one direction while you are trying to center it with the lid open, you may have a rusted or broken counter spring in side the unit. Pleazer Appliance...
Apr 11, 2014 | Maytag Washing Machines
Tub is off balance
The tub is out of balance. When it starts hitting the sides, stop the washer and move your clothes around inside the tub to balance the tub. Now start it to spin again. This should stop the tub from hitting the sides.
Feb 14, 2012 | GE Washing Machines
The tub on my admiral spins out of control hitting the walls of the washer and even moving the washer out of position
The problem i believe with your washer is a snubber ring. What is is and does is a teflon coated coated that fits between the tub support and the base frame ,both the support and frame are metal and during spin the tub has some movement espically during the high speed spin. This snubber fits between those two parts and allows the tub to move and is will slide around on this snubber.when that snubber has ground down to nothing when the tub moves it's not sliding on this snubber but grinding into the base and rocking the entire machine around,vibrating and walking all oveer the place(hehe..i seen one washer that had that snubber bad walk to the corner store and get a sandwich) Replacing that snubber will once again allow the tub to move freely and the snubber will asorb that movement,keeping the base solid and not rocking. To replace that snubber the entire tub asm. must be removed from the washer to replace the snubber
Gene
Aug 13, 2011 | Maytag Admiral AAV7000A
Keep getting an F1 code after starting washer. I have to keep pressing the cancel/pause button and then press start several times to get the washer going.
You must have trash or sediment in your pressure tube hose. b66bfab.jpgRemove it from the pressure switch and blow the stuff out then re-secure the hose and pump out any water in the tub. Then retry. Use this handy dandy service manual as a GUIDE
Aug 28, 2010 | Maytag Bravos MTW6600T Top Load Washer
My dish washer has a f1 code i put to much
f1 code indicates a leak.open bottom drawer,find the spring clips on side of tub where tub meets the front panel.push the clip and you will be able to slide the track back and remove tub. put tub on floor to left you should see a puddle,dry it up should be ok. Sensor is sensitive to moisture allow 24 hrs to reset if all visible water has been dried up. hope this helps ,please rate my solution :)
Jun 25, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 error code
This was copied from a website called WORLD OF WASHERS....I just copied the whole paragraph......sounds like some $$$
Let me know if this helps.......mtg
I am new to this online blog stuff, so I figured an email would be best. I own a Kenmore Elite Oasis washer Model #110.27042602. Everytime we try to use the washer we get error code F1 flashing. This happens withins seconds of the machine first starting to fill and about ten times thereafter until enough water gets into the tub for balance, I assume. We have started pouring about 2 gallons of water onto the clothes in the tub by hand before starting the machine which usually works. About half the time the machine stops again between wash and rinse cycle as it starts to fill with water again.
In my online research, I guess its good we don't have error code F51, but this is a pain and 1 year warranty has passed. It appears I may need to get a new Machine Motor Control Assembly. Any thoughts????
Thank you,
Darrell S.
Darrell,
I'm probably not going to tell you anything you don't already know. You know you may have to replace the motor control assembly, so you have done your due diligence.
I found a thread related to your problem at the "Samurai Appliance Repair Forums" at ApplianceGuru.com. That link will take you to the discussion, in case you haven't already read it. The poster described a situation identical to yours, and I have also read of this problem at other sites on the web.
Contained within that thread is a link to a Service Matters (Whirlpool Corp.) tech sheet related to the F1 error code. This is the document any qualified servicer will refer to when addressing your problem. Here is a link to that sheet in case you want to have it on hand in the event of a service call.
The tech sheet calls to replace the control, but only after three other tests have been conducted. Everything I have read indicates the control will be replaced the vast majority of the time. I am not a technician, but I would say there really is no way around that.
Please keep in mind that this sheet applies to specific models and serial numbers within the Whirlpool line. There may be a separate sheet for your washer, but I imagine the end result is the same.
The million dollar question is how much will such a repair cost. I am seeing prices ranging from $150 to $200 just for the part. With labor, you will probably have at least $300 invested in this repair. I would encourage you to contact Whirlpool at 866-769-7260. I have read instances of other owners receiving satisfactory service in out-of-warranty situations via this number. Whirlpool knows these washers are ****, so they no doubt have a scripted procedure in place to deal with these situations. Be firm, but also be polite. Maybe drop the word "recall" and see what happens.
Apr 11, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Machine continues to display F1 and other F displays. Moved clothes around and pushed power which started machine again, but interupted again shortly afterwards with beeping.
There is a recall on this washer.
Please call Whirlpool...800-253-1301
There is a recall on the Cabrio Whirlpool washer for the F1 code.
The problem is the main computer brain - it is a common defect that whirlpool likes to keep quiet.
Hope this is helpful for you. There is, unfortunately, no end-user fix.
Thanks for using FixYa - a FixYa rating is appreciated for the time taken to answer your FREE question.
Mar 02, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
27 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
