Question about Krups Orchestro Dialog FNF2 Espresso Machine
Krups Orchestro FNF1 Expresso-Coffee Dumps Straight to Drip Tray
I have aKrups Orchestro FNF141 Expresso Maker. It was working perfectly, with no history of leaks, when between making 2 successive cups the first was normal but the second failed. When it came to make the second it dumped the liquid coffee dierctly into the drip tray - with nothing coming out of the nozzels. I have taken it to bits - as far as I can and then run it in the open state to see if I can spot the problem. It appears that the liquid coffee is pouring straght from the expresso making capsule down behind the two flaps.
I am not sure whether there should be some form of pipe to convey it from the expreso making capsule through to the larger pipe that empties onto the back of the nozzels - if there is it has broken/disappeared. Ther are no signs of any pieces of boken pipe.
However, my guess is that a pipe has broken/disconnected - but I cannot find where - and I cannot find a manual listing the various parts to see what is missing.
Grateful for any considered advice on a) exactly the nature of the problem & b) how to fix it.
Thanks. Joe Corrigan
4 Suggested Answers
SOURCE: the hot water and steam commes inside the machine KRUPS FNF1
The mashine dont pull water from the water container and it ask us to press hot water , but nothing happend when we press , anyone knows how to sole this question ?
Allan
Posted on Mar 19, 2010
  • 17 Answers
SOURCE: Hi, I have an XP7240 and recently i only half a
I can remove the bean container by pulling off the grind selector knob and removing the only screw.
Then remove the scute for the cleaning tablets. Then remove the two screws that were covered by the scute. Remove the water tank. Under the tank remove the two screws.
Then the trick where everyone seems to look for: The facade of aluminum can be moved off. Set the machine on the floor and pull hard upwards at the facade. This comes off (pull hard!) and four screw are uncovered. Remove them and pull then back housing of the machine (remove first the containers/drawers). Now the inner parts are freely accessible. Take photos and remove the components from top till bottom to get to the bad parts that need replacement. It's a lot of work but if you're handy you can get to the valve on the bottom of the machine. I have the same problem but haven't looked up the replacement part (can be expensive). Good luck!
Posted on Aug 07, 2010
  • 5 Answers
SOURCE: krups orchestro art889 water is coming down
Most likely the main O-rings have to be replaced. There is an excellent step-by-step instruction available on http://www.kaffeemaschinendoctor.de/Downloads:_:30.html under Jura, Aeg, Krups - It's in German, but Google can translate it. This repair is not for the faint at heart, but it can be done. The O-Rings can be found in any decent hardware store.
Posted on Oct 04, 2010
I need a cleaner for the Krups Orchestro 889
Krups have their own cleaning tablets and descaling powder, your local Krups agent should be able to help you.
Nov 28, 2015 | Krups Coffee Makers & Espresso Machines
Krups orchestro art889 water is coming down into drip tray and coffee grout holder instead of the coffee dispenser
Mar 26, 2010 | Krups Orchestro 889 Espresso Machine
The hot water and steam commes inside the machine KRUPS FNF1
Allan
Dec 30, 2009 | Krups Orchestro Dialog FNF2 Espresso...
We lost instuctions on our krups coffee/cappuccino maker dont know how to use
XP4050 Krupps
pumps water through machine into drip tray not through coffee anymore
Apr 26, 2009 | Krups Cappuccino/Espresso Maker -...
Cant steam milk and brew expresso at the same time.
You are not doing anything wrong.. that's the way this uint works.
Jan 14, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
Krups Caffe Bistro 867 Expresso & Coffee Maker INSTRUCTIONS
http://www.krupsusa.com/All+Products/Coffee+Machines/Espresso+coffee+machines/Products/867+Bistro/867+Bistro.htm
Aug 12, 2008 | Krups Caffe Bistro 867 Espresso & Coffee...
Krups XP2070 coffee machine - new - espresso side - water goes straight into the drip tray & not thru the filter.
This will most likely happen when the pressure valves become defective. Replacing the two valves (they come in pairs) should fix the problem.
Aug 03, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
The krups coffee machine is letting out hot water but not coffee ?
If you find water in the spend grounds drawer or with the cup grid out you see water being dispensed into the drip tray your brew unit needs repair or replacement. If none of that is happening the tube that brings hot water to the brew unit is clogged.
May 24, 2008 | Krups Orchestro Dialog FNF2 Espresso...
Krups Orchestro Dialog FNF2 Espresso Machine Logo
279 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
