Question about RTO Beckett # W1150 WTRFall/Str Pump
Where can I find a replacement impeller for a 10 year old beckett water pump? The only model information I have is "798" stamped on the out side of the casing.
    Problem Solver:
  • 7 Answers
I'll bet you need to buy a new pump.Most pond pumps from Beckett are sealed and the impeller can't be or should not be changed.
Posted on Sep 27, 2009
How to remove a pressed on impeller
Is it pressed on using a keyway on the impeller shaft or is it simply a pressed interference fit?
Jul 21, 2014 | Beckett Corporation Beckett Professional...
Where sale a impeler for beckett w3500.
http://www.homedepot.com/p/Beckett-3500-GPH-Submersible-Waterfall-Pump-W3500HD/100024869
Or if Home Depot can't help you in ordering an impeller for a pump they carry, try sending an email directly to Beckett and ask for assistance on where to get one...
customerservice@beckettpumps.com
Good Luck
May 09, 2014 | Beckett Corporation Beckett W3500 7114310...
Bosch shy66c02uc
JESUS ALMIGHTY
Dec 18, 2013 | Dishwashers
I have a year old kitchen aid dishwasher and during fill cycle it makes a thumping noise. The dishwasher every 5 or 10 seconds shuts off fill cycle then turns back on which I think is what's causing...
Drain Pump
If the dishwasher is loud during operation, the drain pump might be defective or might have some debris in it. This is a common problem.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Circulation Pump
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the circulation pump sound, it's likely that the circulation pump motor bearings have failed. Once this happens the circulation pump will have to be replaced, the bearings are not repairable.
Drain Impeller
If the dishwasher is loud during operation, the drain impeller might be broken, or there might be debris in the pump. Generally, to gain access to the pump the top of the pump housing will have to be removed.
Pump and Motor Assembly
If the dishwasher is loud the motor bearings, drain impeller or wash impeller might have worn out. All three of these components are part of the pump and motor assembly. It may be possible to replace one of the impellers, but the motor bearings cannot be repaired. In that case the pump and motor assembly will need to be replaced.
Wash Impeller
The wash impeller is a small, plastic blade. The motor spins the impeller forcing water through the spray arms to clean the dishes. If one or more blades has broken off of the impeller the dishwasher is loud. The impeller can also scrape against the pump housing if it is damaged, warped or bent.
Circulation and Drain Pump Motor
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the motor sound, it's likely that the circulation and drain pump motor bearings have failed. Once this happens the motor will have to be replaced, the bearings are not repairable.
Water Inlet Valve
The water inlet valve is an electrically controlled water valve. When it is new, the water inlet valve is very quiet. Over time, the diaphragm inside the valve deteriorates and deforms. This deformation interacts with the water rushing in and can cause a loud vibration, buzzing, squealing or other noises. If the dishwasher is loud during the filling cycle, replacing the water inlet valve may solve the problem.
God bless you255fe28d-9cc9-4874-b381-9c9de59f3f75.jpgc98d91d6-ba21-42ff-b684-98f0b3e856c0.gif
May 24, 2013 | Dishwashers
We have a Beckett W5000 a rock got in the systems and broke the plastic puppelor. Where can we buy trhe part to fix it???
Email Beckett at: customerservice@beckettpumps.com
Call Beckett at:
972-871-8000 or Toll Free at 1-888-BECKETT (232-5388)
Fax Beckett at:
972-871-8888
Write to Beckett at:
Beckett Corporation
c/o Customer Service
3250 N Skyway Circle Dr
Irving, TX 75038
Warranty & Technical Assistance:
The NEW toll free number for warranty information, replacement parts, and technical assistance with water gardening and fountain products is 866-466-4319 or email Beckett atCustomerCare@beckettpumps.com
For information on CE, VDE, or DENAN (PSE mark) certified pumps:
Please email Beckett at: customerservice@beckettpumps.com
Or write to them at the address above.
Aug 28, 2011 | Beckett Water Gardening Beckett Statuary...
How do i change a water pump on 1996 grand cherokee limited V8
I'll assume you have a 4.0l
The 4.0L engine is equipped with a reverse rotation (counterclockwise) water pump. The word REVERSE is stamped or imprinted on the cover of the viscous fan drive and on the inner side of t he fan. The letter R is stamped onto the water pump impeller. When replacing water pump, ensure proper pump is installed. Installation of the wrong water pump will cause engine overheating.
NOTE:On models with 4.0 L engine, front grill must be removed to access radiator draincock. Draining cooling system can be accomplished by removing drain plug from side of block as well as by loosening radiator draincock. Drain plug is located on lower left side of engine block.
Disconnect negative battery cable. Drain cooling system. Disconnect electric cooling fan connector. Remove electric cooling fan and electric fan shroud assembly (if equipped).
Loosen, but do not remove, 4 water pump pulley-to-water pump hub bolts and 4 viscous fan-to-idler pulley nuts. Remove accessory drive belt. Remove 4 viscous fan to idler pulley nuts, and remove fan and shroud together.
Remove 4 water pump pulley bolts and remove pulley. Remove power steering pump and bracket. Disconnect heater hoses and lower radiator hose at water pump. Remove 4 water pump retaining bolts. Remove water pump.
to install just reverse procedures
Apr 05, 2010 | 1996 Jeep Grand Cherokee
Have a 10 year old salt water pool with a PH1 Dura-Glas pump which is now not pumping enough water. Have recently fitted new filter etc. Does the pump head wear on this model and if so where do I...
If you had a crack in your basket then you may have a plugged impeller. You can reach the center of the impeller with a screwdriver and needle nose plier from the hole inside the pump pot.
If not you may have a problem with your impeller or the small "O" ring on the difuser. For this you will need to take the pump apart at the band clamp. Good luck.
Jan 31, 2010 | Water Warehouse Nsf Approved Sta - Rite...
Maytag washer leaks water from bottom
I would remove the hoses from the pump and use a flashlight to look into the suction port. Check for anything clogging the pump (like the occasional stray sock) and check the pump impeller. Make sure there are no blades missing or broken and that the impeller will spin freely. If any blades are broken/missing or if you cannot get the impeller to spin freely, the pump is defective. Hopefully it is just a clogged pump or jammed impeller. If you can find no fault with the pump, then it could be the tub seal, but I would check the pump first. Very sorry for your trouble and I hope this helped. Best wishes.
Sep 01, 2009 | Washing Machines
Pond pump trips circuit breaker
The circuit breaker trips because there is an electrical short in the pump itself or in the wire feeding the pump. A cause of this could be a bare wire, or a crack in a wire. Remove the pump and put it in a five gallon pail of water and test it. If it still trips the breaker you will know the problem is in the pump or the cord to the pump.
May 02, 2009 | Beckett Corporation Beckett Professional...
Water fountaian will not work
The curcuit should be simple. The pump is the heart or this system it draws water to the pump(if it can't then the hose is plugged, or damaged) or the pump is bad. If the pump is working then it should be pushing water to its destination. if the water comes out the pump but wont or cant push the water to its destination then the impeller is bad.
Apr 26, 2009 | Beckett Water Gardening Beckett 7124110...
RTO Beckett # W1150 WTRFall/Str Pump Logo
617 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
JOHN BROWN
Are you a RTO Garden Expert? Answer questions, earn points and help others
