Question about Galaxy Radios DX- 88HL Base CB Radio
I have a galaxy 88 and a 44. Both radios erraticly change frequency up or down way out of the usable range.
    Champion:
  • 219 Answers
Crystal is bad..crystals will normal show out during cold weather
Posted on Nov 21, 2009
Power decrease in my galaxy dx979
As you go up in frequency do the SWR (VSWR) go up or down? what frequency did the antenna get tuned at ?
Dec 18, 2012 | Galaxy Radios DX-979 CB Radio with Single...
Galaxy dx 2547 base cb frequency drift problems
for upper ssb adjust L21 for 16.51250 mhz . adjust L22 for 16.50750 for lower ssb. you do have a frequency counter don't you ?
Jan 01, 2012 | Galaxy Radios DX-2547 40-Channels Base CB...
Changing colors on a Galaxy 88 or DX-88HL or DX88
  • There are no white ones at this time. Only Red, Green and Blue on the frequency displays. If you have any other questions please feel free to ask.
Oct 20, 2011 | Galaxy Radios DX- 88HL Base CB Radio
Galaxy 99 has same frequency 27.185 on am also on upper side and lower side band how come?? thank you
The frequency doesn't change when you change to USB or LSB. Basically the AM frequency takes up a certain amount of space, known as bandwidth, so it could fill in for example use 50 hertz above and below 27.185 giving 100 hertz bandwidth. When you use sidebands the am bandwidth is split in two so the upper side band would use the 50 hertz above 27.185 and the lower side band would use the 50 hertz below. The idea is that twice as many operators can operate without interference.
Sep 17, 2010 | Galaxy Radios DX-99V 40-Channels Base CB...
I have a Motorola Axu4100 , I want to change the frequence that I currently have on this radio to a Motorola CP-200...just wondeing if these two radio can work together....
Hi
Motorola CP-200 have frequency range
VHF: 136–162, 146–174MHz;
UHF: 403–440, 438–470, 465–495MHz depending on the model
Motorola AXU4100 have frequency range 435 - 480 Mhz
The first model has a wider frequency range so it is best to include transmitter Motorola Axu4100 to transfer and try to receive signal to Motorola CP-200
Sep 03, 2010 | Motorola AXU4100 (10 Channels) 2-Way Radio
How to adjust frequency on transmit??? Galaxy
hELLO THERE
hERE IS SOME MODIFICATIONS FOR THIS RADIO
Galaxy Mods DX 2527 - VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR11...Driver Bias, VR12...SSB ALC, VR13...Hi Power, VR14...AMC, VR15...AM Low Power, VR16...SSB Low Power, VC 1....10.240, VC 2....10.240. DX 2517- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5....FM Deviation, VR 6....SSB Carrier Balance, VR 7....TX Offset, VR 8....CW Beep Level, VR 9....RF Meter, VR10...Final Bias, VR11...Final Bias, VR12...Driver Bias, VR13...SSB ALC, VR14...AM/FM High Power, VR15...AM Modulation Meter, VR16...AM Modulation, VR17...SSB Power, VR18...AM/FM Low Power, VR601..13.8 Volt Power Supply. DX 22B- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR11...Driver Bias, VR12...SSB ALC, VR13...High Power, VR14...AMC, VR15...AM Low Power, VR16...SSB Low Power, VR21...TX Offset, VC 1....10.240, VC 2....10.240. DX 11B- VR 1....AM/FM S-Meter, VR 2....SSB/CW S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR10...Final Bias, VR11...Driver Bias, VR12...SSB ALC, VR13...AM/FM High Power, VR14...AM Modulation, VR16...CW Tone Level, VR20...Final Bias, VR21...TX Offset, VR601..13.8 Volt Power Supply, VR803..AM/FM Low Power. DX 77HML, DX 88HL, and DX 99V- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR10...Final Bias, VR11...Driver Bias, VR12...SSB ALC, VR13...AM/FM High Power, VR14...AM Modulation, VR16...AM/FM Low Power, VR20...Final Bias, VR21...TX Offset.
Unmarked VR in R189..AM/FM Medium Power for DX 77HML only. DX 33HML, DX 44V, DX 55V, DX 66V, and DX 73V- VR 1....AM/FM S-Meter, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 8....RF Meter, VR12...Low Power AM Modulation, VR13...AM/FM High Power, VR14...High Power AM Modulation, VR16...AM/FM Low Power.
Unmarked VR in R188..AM/FM Medium Power (DX 33HML only)
Unmarked VR in C139..Med Power AM modulation (DX 33HML only) DX 949,DX 959- VR 1....AM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM Squelch Range, VR 6.....SSB Carrier Balance, VR 7....TX Offset, VR 9....RF Meter, VR10...Final Bias, VR12...Driver Bias, VR13...SSB ALC, VR14...AM High Power, VR15...AM Modulation Meter, VR16...AM Modulation, VR17...SSB Power, VR18...AM Low Power, VC1....10.240. DX 2517 and DX 2527-
Symptom:Buzzing or motorboating sound in either the transmit or receive.
Problem: TR602 is oscillating
Cure: Replace C602 with a .01uF cap {Cap is located in the power supply board}.
RG 66,99,DX2517 Replace Q54 2SB754 60watt 7A with a higher power 2SB817 100 Watt 12A. Derating of this component will cool operation, provide better voltage stability,decrease wobble, allow voltage increase to 14.5 volts comfortably. (replace 10 volt caps in this section of the radio to a minimum of 16 volts before increasing supply voltage to this level)and provide faster swing rise time, Replace Q37 2SA473 to a 2SA1012-0 or ECG153 this will improve the clarity and volume of the modulation and it will also run a lot cooler.
Nov 12, 2009 | Galaxy Radios DX-949 40-Channels Base CB...
Galaxy 949 mobile CB is off frequency when
a friend of mine just told me he used the galaxy 2517 adjustment procedures. I hope this may help you. Buckeye back quiet.
Mar 03, 2009 | Galaxy Radios DX-949 40-Channels Base CB...
Super Star 3900 GHP
Can't help you there. It's most likely that you screwed the modulator up by extending the frequency range. I used to work for Galaxy and I know what happens to a radio when amateurs try to modify them (no offense). If you modify a high power radio such as your Super Star, you're bound to have modulation and SWR problems. In expert advice, never do amateur radio modifications to a high power radio. If you want a more versatile radio, get a Galaxy DX 2517 CB base station. The DX 2517 has PA/FM/AM/SSB/USB/LSB/CW modes, and bands A-F, and a frequency range from 25.615 to 29.205 MHz. The Galaxy DX 2517 has modifications that can be done right at the factory, they are optional however. The only thing I find annoying with the DX 2517 is that it's bulky, it leaves no room for any competition. When it was designed, the engineers left space saving out of the question.
Anyway, Good luck
and
Best Regards,
Gavin93
Aug 07, 2008 | Galaxy Radios DX- 88HL Base CB Radio
Lost channels in a galaxy 66v cb radio
as far as the transmit frequency changing while you have the mic keyed this is normal, the transmit frequency is a little different than the receive, as far as the lost channels go you need to check the galaxy website and check to see if thier is any fixes listed. if none is listed then you can send the tech's a e-mail and tell them your problem and they will advise you on what to do.
Aug 15, 2007 | Galaxy Radios DX-66V Base CB Radio
Galaxy Radios DX- 88HL Base CB Radio Logo
165 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
