Question about Canon PowerShot SD550 / IXUS 750 Digital Camera
Canon powershot A700 - Battery drains in few seconds
Hi I have this canon powershot A700. When I charge a new set of sanyo rechargeable batteries 2700, and put it in the camera, it immediately says in 4-5 seconds battery low and switches off in 10 seconds. I have tried with 3 new sets of batteries. What should I do.
SOURCE: CANON POWERSHOT A530 LOW BATTERY READING
We had the same problem and it was so very frustrating. We sent the Camera back for assesment and repair only to be told there was nothing wrong with it. The solution was so simple we felt like real dummies.
All you have to do is use Energizer Lithium Batteries, since we started using them we have not had a problem with Batteries going flat or that annoying Battery indicator flashing.
Regards
John
Posted on Oct 15, 2008
t00nz
  • 4738 Answers
SOURCE: I have a Canon powershot A700. I took out the old
As you've already tried sliding the card's locking switch, see this link for additional things that you can try.
Posted on Sep 09, 2009
  • 11967 Answers
SOURCE: what to do to the change the battery error on Canon a700 camera
Have you been to the Canon website to see if there are any firmware updates for your camera?
Posted on Sep 30, 2009
SOURCE: Canon Powershot A470 - asks to 'change battery'
This happened with my Canon Powershot A470. I sent it back to he manufacturer and they said I was using the wrong batteries. Even though the camera is supplied with two alkaline batteries, they recommend using AA NimH rechargable batteries.
Posted on Jan 21, 2010
  • 1382 Answers
SOURCE: my canon powershot sd 1200 wont turn on.
Check whether your batteries are actually making contact with the battery posts, and that these posts are clean. If not, bend the posts up/down a little, and maybe clean them with a little rubbing alcohol on a Q-tip. Or if that does'nt work our for you , if your camera uses Compact Flash, check to make sure all pins are present and aligned in the card slot (if bent, simply unbend/straighten them with a skinny "jewelers" screwdriver, then insert the flash card for final realignment).
Thank you !!
Posted on Jun 01, 2010
Battery life-I put new batteries in and it lasted less than 30 minutes-maybe 20 pics before the camera stated replace batteries. Is there a reset-
If you are using alkaline batteries, you should switch to rechargeable NiMH batteries. I highly recommend the Sanyo Eneloop products. You should be able to get 300 to 400 shots before you need to recharge. Get two sets of four AA Eneloop batteries. Don't mix them. They hold their charge for a year and can be recharged a thousand times.
Jul 13, 2011 | Canon PowerShot SX10 IS Digital Camera
I'm using a Canon PowerShot A570IS, and am getting only 20 to 30 photos from fully charged Sanyo AA HR6 2000mAh batteries. I'm using the Sanyo Ni-MH quick charger that was sold along with the...
Unfortunately, this is not unusual with rechargeable batteries. The best thing you can do with a rechargeable battery is to fully and completely discharge it, and then recharge it fully. After that, there's nothing else you can do except buy a new battery. You can get brand new, unbranded ones on eBay for a fraction of branded ones, and they work great. Just buy from a seller with a good reputation, and you can't lose. I usually buy multiples and never run out of battery power this way.
Feb 18, 2011 | Canon PowerShot A570 IS Digital Camera
I have a Canon PowerShot A95 . PC 1099 #0126221312
‌hi
use rechargeable battery
and its very important to charge completely the 1st charge and try to use battery completely(discharge)
Jul 25, 2010 | Canon PowerShot A95 Digital Camera
My canon A710 says it needs batteries no matter
My A710 did exactly the same thing. Spoke to Canon support. According to them you have to use Canon 2500 mah batteries (quite expensive - need a different charger as well). I've just bought new rechargable batteries from Sanyo (Eneloop pre-charged). And it solved my problem. I've also changed the batteries quite a few times and it never worked. But this did solve the problem for me.
Nov 04, 2009 | Canon PowerShot A710 IS Digital Camera
What to do to the change the battery error on Canon a700 camera
Sep 30, 2009 | Canon PowerShot A700 Digital Camera
Canon camera sx10 IS battery dries out quickly
please use the batteries of the same spec. IE - 4 two 3000mA. please read the instructions carefully - they do mention that you have to use battiers of the same power rating.
Aug 08, 2009 | Canon PowerShot SX10 IS Digital Camera
Battery dies fast
There is no setting, that sounds just like a faulty Li ion rechargeable battery. Test the camera with alkaline batteries , if it works fine get a replacement rechargeable battery. Ensure that batteries are fully charged first.
Apr 16, 2009 | Canon PowerShot SD400 / IXUS 50 Digital...
S2 suddenly draining batteries rapidly
I have the same exact problem. I just now read a possible solution: try opening the battery compartment door and then closing it again to "trick" the camera into thinking it just got new batteries. There is definitely something wrong with the way the camera senses dead batteries.
Jul 28, 2007 | Canon PowerShot S2 IS Digital Camera
Canon PowerShot SD550 / IXUS 750 Digital Camera Logo
56 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
