Question about HP PSC 1315 All-In-One InkJet Printer
I can't get my scanner to work- the printer works but the scanner doesn't do anything-am I doing something wrong
  • 138 Answers
May be did you installed all the scanner drivers,,, first check them.. and let me know
Posted on Sep 27, 2009
Just had a paper jam , removed paper and now when i try to print, it just shoots blank paper. Help?
try to print anything from your pc if its working that means you have something wrong with scan unit,but if its blank too make sure that your copier has toner and get yourself a new drum unit.
Mar 10, 2016 | Canon MG2920 Wireless Printer Scanner
!My printer works fine but doesn't print in color. I have checked all the ususal culprits and can't finnd anything wrong, HELP
Check that your Print Preferences is not set to print in greyscale or print only in black.Also you could reset the printer by turning the printer off, unplug printer from outlet, wait awhile,.then plug printer back in and turn printer on.
Nov 15, 2011 | Office Equipment & Supplies
I installed a printer on my PC and the scanner does not work. Should i install the scanner aswell?
Do you have the combo printer that comes with scanner and printer in one machine? If you do, then one installation should work the device as the computer will recognize it as one. If that's what you have, and the scanner still doesn't work, return the machine and ask for a new one.
If you have separate scanner and printer machines, then you should have two installation discs as each should have its own. You will need to install the scanner if this is the case.
Hope this helps.
Aug 30, 2011 | Office Equipment & Supplies
My spacebar is not working correctly it sticks and I really have to push it hard for it to work correctly
try flipping the keyboard upside down and see if anything falls out. if it still doesn't work your best bet is probably to just buy new keyboard. they aren't expensive.
May 13, 2011 | Computers & Internet
When i try to print something it doesn't make anything.Sometimes it works.What i do wrong?
Verify the printer is installed correctly. Make sure the drivers for the printer are up to date by downloading the newest ones from the printer's manufacturer. Also, make sure all connections to the printer are tight, meaning they are plugged in correctly and are not becoming disconnected. If the connections are fine and the drivers are up to date, reinstall the printer. Assuming the operating system you are using is Windows, go to Start->Devices and Printers-> then right click the printer and select uninstall. To reinstall, insert the CD that came with the printer and follow the instructions on the printer. If you do not have the CD, plug the printer in and Windows will install with the default driver if it has one.
May 10, 2011 | Computers & Internet
Scanner seems to not be aligned properly. Documents are cut off, or wrong size.
Scanners are pretty much impossible to fix yourself, if they're experiencing hardware issues. Try making sure you have the latest software and firmware updates for your computer as well as your scanner/printer. If it still doesn't work, it's time to call Brother - it likely needs to be shipped for service.
May 06, 2011 | Brother MFC 6490CW InkJet Printer
Scan doesn't work
i have a hp F4272 all in one ,when i used the scanner hp cue scanning flow component has stop working,any one who has an idea of this problem?
Sep 06, 2009 | HP Officejet Pro L7680 All-In-One Printer
Replacing cartridge
If it normally does move over to let you remove it and now it doesn't then something could be wrong with the printer. You can manually move it very delicately. If it allows you to do so then try to change it out. If this doesn't work turn the power off and try it.
Oct 22, 2007 | Lexmark X2350 All-In-One InkJet Printer
?Scanner failure? error message
Usually this type of error message pops up when the scanner lamp isn?t warming up properly. This is what you should do: 1. Check if the lamp is on. 2. Unplug the scanner?s power supply and plug it back in. Try connecting it diretly to the wall. 3. If that doesn?t work: a. Unplug the unit?s power supply. b. Press ?cancel? and left arrow while reconnecting the unit. c. Release the buttons when the printer starts up. 4. Try scanning again. 5. If it doesn?t work, have it serviced.
Feb 22, 2006 | HP PSC 750 All-In-One InkJet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
50 people viewed this question
Seeker5211
Seeker5211
