Question about Intel D101GGC Motherboard
A question mark in S M Bus controller and video controller
A question mark is shown when i open the device manager in the following driver
S M Bus controller
Video Controller(VGA Compatible)\
i tried downloading them from many websites but none helped.
  • 138 Answers
I feel you are not having the right drivers,, for the video card,, you try go from device manager,, and from there click on properties,, and then. update driver.. then give path to the relevant drivers... let me know the video card name and details
Posted on Sep 27, 2009
My usb device i/o error
Two of the most common causes of I/O (Input/Output) device errors are driver based. Typically, either the device's driver is not enabled or it is out of date. The driver component has an important function, as it acts as a motorlike force that propels USB/plug-and-play hardware into a driving action within the computer. It is the connecting communicating link signaling the CPU to a desired movement. And while not all I/O device error solutions are simplistic, as a good starting point, you can try troubleshooting using a few basic steps, and you might not need to attempt anything else. Access "Control Panel" from the Start menu and then choose "Performance and Maintenance." Click "System" and then go to the Hardware tab and click on "Device Manager." Find the device that is registering an error by expanding the nodes of the appropriate category. If the device has a red "X" on the icon next to its description, the hardware is disabled; proceed to Step 4 to enable it. Otherwise, go to Step 5. Go to the General tab and click "Enable Device" found under the Device Status section; then press "OK." (Note: You may have to follow prompts, as indicated through an enabling device wizard. If you do, continue to click "Next" and follow the prompts until the process has completed.) Test the hardware. If an error is shown, proceed to Step 5. Go to the General tab and click "Troubleshoot" found under the Device Status section then press "OK." Follow the prompts to solve the issue. If an error is still shown, proceed to Step 6. Go to the Driver tab and click "Update Driver." Follow the prompts until the process has completed and then test the hardware.
w7 First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. for xp or earlier click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts Hope this helps.
Jan 25, 2013 | Kingston Digital 4GB DATATRAVELER C10...
Usb bus does not notice drive plugged in
w7
for xp or earlier
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
hope it helps
Oct 18, 2012 | SimpleTech Simpledrive Computers &...
I have a flash drive that it dose'nt shown up in my computer, but it has light on it
w7
for xp or earlier
if you need more help with this or if i have missed the problem post a reply
hope it helps
Oct 06, 2012 | Kanguru 16GB Defender Elite USB 2.0 Flash...
Usb port not recoginzed
w7
for xp
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
if you can see your usb but its not working
ports(com&lpt)right click update driver
hope this helps
Aug 02, 2012 | Kingston Data Traveler 100 G2 4GB USB 2.0...
Resource conflict PCI in slot 01 bus 1A device 04 function at startup and then the DVD player doesn't show up under device manager
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
hope this helps you
Aug 19, 2011 | Computers & Internet
Hi sir, I need help on my pc, i install a usb 2.0 pci to usb card on the mother board but cant get it working, i have on device manager under other devices have an exclamation mark on universal serial...
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question mark?
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
http://download.cnet.com/via-usb-2-0/3000-2098_4-10163319.html
Available in this download are drivers for VIA USB 2.0 host controller on a system running on Windows 98/98SE/Me. Due to licensing agreements, USB 2.0 drivers for Windows 2000/XP are not available for download. They are supplied on CD with new mainboards or available through Windows Update. This version is a bug-fixing release.
hope this helps
Jul 30, 2011 | NEC Televison & Video
Usb flash shown problem code 43
this might be a driver issue
hope this helps
Jul 10, 2011 | Verbatim STORE-N-GO (95312) 8 GB Hard...
Yellow question mark on high definition audio bus at device manager, already installed driver dvd package with motherboard.
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
Apr 20, 2011 | Computers & Internet
There is a yellow question mark on SM bus controller, video controller, audio device as shown on device manager after i have clean install Windows XP pro in my desktop pc. and no sound coming from the...
You will need to go to the compaq site and download the drivers for your machine. You will have a tag number on the computer , enter that and it will take you to your machine to download the drivers you need
Jan 02, 2010 | Compaq Computers & Internet
Intel D101GGC Motherboard Logo
378 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
