Question about Apple iPod MA446LL/A MP3 Player
Headphone/hold circuit my headphone/ hold wire on the inside of my ipod ripped when i was taking it apart and i need to get a new one and i was wondering how much they cost or if i can even buy another one
  • 1 more comment
  • claytonius Jan 05, 2008
    I must have done the same thing because I just put a new hard drive in a 30 GB iPod Video and I'm pretty sure the hold worked before but now that I have a working Hard Drive, the hold button is busted! Grrr! I already screwed it up - I don't know if I should go back in!
    But I don't have a problem with my phone jack so maybe it's a different problem??
    and I don't know what is meant in solution a new what on ebay??
  • 135 Answers
Skins19, you can buy a back panel along with a headphone jack on eBay for a fairly cheap price.
claytonius, check if you put the wire all the way into the connector on the iPod's logic board. It could be that the wire itself was damaged partly, so the headphone jack can still communicate with the logic board while the part of the wire that the hold button is supposed to use to communicate with the logic board is damaged so it won't work properly. You should try buying a back panel along with a headphone jack on eBay as well.
Posted on Jan 05, 2008
  • 4,402 Answers
Buy a as -is from ebay
Posted on Dec 18, 2007
One side of the headphones does not give sound consistently... if I jiggle the connector to the ipod and hold it at a certain angel I can get sound to both headphones, but I'd like to find a real...
Well the good news is, it's not your ipod.. It's the wiring inside of the headphones. I suggest that you either return them for a new pair, or buy a new pair.
May 20, 2011 | Sennheiser PXC 250 Consumer Headphones
The wires got ripped out of the jack. Is there a way to resolder them or am I hopeless?
The wires are too delicate to solder back together if they are completely ripped apart. The heat will only make them melt.
You are better off buying a new pair.
Mar 03, 2011 | Skull Candy Riot Headphones
The connector piece ripped off
it may look crapy but take apart conector and replace the wires in it with longer wires and wire nut the to pieces together
May 10, 2010 | Bose TriPort Consumer Headphones
I stood up on and airplane while my I-pod headphones were plugged into the plane's ourlet and I ripped the wires from the plug. How can I rewire my headphones?
Its not worth the effort. Much easier to buy a new pair for less than 20 dollars. Ipod headphones are not very good to begin with. Try" skull candy" phones, they run about 15 dollars and are much better than apple phones.
Dec 29, 2009 | Apple Audio Players & Recorders
Wire loose
If you can carefully take the foam earpad off you might find screws holding the speaker plate to the cup.
May 11, 2009 | Altec Lansing AHP712i Consumer Headphones
Just bought an ipod touch gb second generation from amazon new nd
When you are dissatisfied and confused go straight to apple's support. They take care of you like they are ***********. One time my friends' headphone ripped and they gave him $200 worth in giftcards and he got an apple t-shirt and new headphones. You can email or call and they should have your solution ASAP
Apr 08, 2009 | Apple iPod touch
Ipod headphone problem
My headphones cut out when I am walking
Dec 28, 2008 | Apple (M9394G/A) Consumer Headphones
Right speakers don't work
After taking the unit apart, I found that the speaker wire had broken, at the point where it passes through the hinge. Although the wire is reinforced with plastic in this area, wiggling the wire showed that the break was there. I removed the coating and found that both wires were broken. That was it. No problem.
Aug 05, 2008 | Altec Lansing inMotion Plus Portable Audio...
Ipod head phone jack no good
I agree with Solution 5. The copper pins in the jack that make the connection to your headphone plug are bent in such a way that they are springy and will make a good tight connection to the plug. When those copper connections get worn, they are not so springy and they bend inward causing you to lose audio on one side of your headphones unless you wiggle the plug and find that sweet spot that makes a connection. Then you have to hold the wire to keep pressure on it... it gets annoying.
You can open the case and there are slots in the headphone jack that you can get a hook scribe (like the dentists use) or safety pin to bent those copper connections back out. Don't bend them too far or they will break. You can also pick get a new part for $25 or a used part much cheaper. Once you iPod is open, it's a matter of a couple screws and a ribbon cable to replace the jack. Problem solved!
Feb 08, 2008 | Apple iPod MA446LL/A MP3 Player
Apple iPod MA446LL/A MP3 Player Logo
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
