Question about Garden
I have a kubota g5200 that will not turn over or crank. It was cranking but not start before I Changed fuse near the steering wheel. After changing the fuse it will not do anything.
  • 472 Answers
CK THE FUSE BY THE STARTE OR BY THE SOLEND
Posted on Sep 30, 2009
M108x kubota will not crank, checked all fuel lines fuses on top of engine 1800 rpm tractor starts to miss
if it will not crank , it will not start
if you get it running and it misses , that is injector or fuel flow problems
Mar 27, 2017 | Kubota Garden
L2050 kubota tractor after engine gets hot if i shutdown it will not crank over after cool down starts back up.
Nest time it is hot and does not start, check for spark. U could have a thermal issue where the ignition coil gets hot and stops working till it cools down.
U mentioned glow plugs - is this a diesel powered unit? Check for proper oil level in unit? Oil pump? Poor lubrication will cause an engine to expand when hot and not restart till it cools down.
Oct 13, 2015 | Kubota Garden
We changed water pump in Kubota l3010 tractor. It won't crank and water is coming out of exhaust pipe. Any suggestions?
Jonsas, right. Don't try to crank with water on pistons. If it crank, it would bent the rods. Pull spark plugs or injector precups first.
Mar 30, 2015 | Kubota Garden
97 jeep Cherokee sport no start turns over but no spark on fuel an no gages work what could it be already changed crank sensor
sounds like a crank sensor to me it is located on the bell housing of the transmission on drivers side near the top
Feb 05, 2015 | Jeep Cars & Trucks
2005 ford f150 king ranch changed fly wheel now it wont start
Did it start before?
Who did the flywheel?
Is the crank sensor still there?
Is the flywheel the correct one,that is where
the crank signal comes from ?
Dec 14, 2012 | Cars & Trucks
Why would turning the steering wheel while cranking engine gets my car to start?
The ignition switch in the column most likely has a break in it. So when you move the steering wheel, it moves the wire so it completes the connection when you turn the key. Have the ignition switch replaced.
Oct 19, 2012 | 1992 Honda Civic
I HAVE A 92 DODGE DAKOTA IT DOT TO WHERE IT WOULDNT START,IT WILL TURN OVER BUT NOT CRANK,IT HAS FIR TO PLUGS,AND TO THE COIL,AFTER IT SET A FEW DAYS IT STARTED TO CRANK,NOW WHEN DRIVING IT WILL SHUT DOWN...
The engine turning over & the engine cranking is the same thing,
are you not aware of that
You have a no start condition,failed fuel pump I would think
I owned a 92 for 18.5 years
Oct 05, 2012 | 1992 Dodge Dakota
Steering wheel wont lock and stuck in park
In the fuse block under the drivers side rear seat check the ignition 0 fuse. In the under hood fuse block check the B/U fuse and the BTSI fuse. If the b/u fuse is blown than you would not have back up lamps.
Dec 02, 2011 | 2002 Chevrolet TrailBlazer
99 740il will not crank
if it was starting up fine and stopped cranking all the lights light up on the dash but just dosent start look under the carpet on the passenger side the is another fuse box panel there if there hasnt been any water in the car it can rust it out and blow fuses and cause other electrical problems that what happened to us we are looking for this part right now my husband probe the wires and everything works
Mar 16, 2009 | 1999 BMW 7 Series
Garden Logo
518 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
