How do i replace a hardrive in an HP laptop computer. gives warning when boots up.
  • Chip
    Chip May 11, 2010
    All depends on what laptop you have. Look on the bottom of the case, there will be a model number, give that number please.
  • 557 Answers
Put laptop upsite down and you wil find a part thad are closed withe x screws 15 cm by 8 cm you can open it and take out the hd and replace it for a new one
if you buy a new one look out for the dimensions there are 2 diferend hight for the disk otherwise you can not close the plastic with the scews look also for the type idee or sata it are markt on disk you can also take a bigger disk insted of 80 gb take a 200 gb
good luck
ben.pluijm@viveole.com
Posted on Sep 27, 2009
Operating system not found HP Pavilion dv2-1039wm
The operating system is stored on the hard drive. If the BIOS can't find the O/S then the hard drive is damaged or the windows installation is corrupted. Boot to the BIOS screen and see if you can see the hardrive listed on the information tab. If you can see the drive, you either have bad sectors on the hard drive or a corrupted boot file. You can insert your windows disc and start the machine. Click install now, choose language and on the next screen click 'repair computer'. Choose 'startup repair' this will rewrite the windows boot files.
Mar 27, 2012 | HP Computers & Internet
If i connect a pendrive or netconnect into my dell inspiron 1545 laptop before strart the system is giving problem for turn on. so what to do for this problem plz solve my problem.
Try changing the BOOT order in the BIOS (F2 or DELat startup) it is probably set to first boot from a USB device and then the hardrive- Have the hardrive first
Dec 29, 2010 | Dell Inspiron 1525 Laptop
Hp pavilion dv 8000 will not boot from DVD drive or Hardrive. It goes to LAN card regardless of precedent set in the BIOS
when u start ur system try pessing f8 or f10 or watever is the key for boot option nd from there u can select from which device to boot
Apr 05, 2010 | HP Pavilion dv8000 Notebook
I have a problem with hp dv9000.. the operating system wont boot.. even wen i insert any booting disk, it shows the first screen with hp and its logo and then it becomes blank.. i presume my harddisk is...
Try going to the bios and reset the bios to load factory defaults and then reboot. If the same thing happens try taking the hard drive out and reboot, if the same thing happens again its not your hardrive because it would say no boot disk after post. Iam guesing it may be a bios fault because after the logo it goes blank not while loading the os(operating system).
Give this a try and post back your findings.
Jan 20, 2010 | HP Pavilion dv9700t Notebook PC
Hi my hp g6000 wont boot it comes on fan runs hard drive and cd kick in but no screen then the laptop reboots and just does this loop
When your system begins to come alive, press Esc or F8 to get to a BIOS Menuscreen. In there, look for Boot. Move the CD/DVD option to the top so that your computer will look for a cd to boot from. Hit F10 to save and exit. Put a bootable CD in the drive and let your computer boot from it. Once it's up, look to see if you see your harrdrive C:. If not, the problem is probably the boot sector on your hardrive has gone bad. Look at this site (it's legit) for bootable CDs and other help.
Aug 12, 2009 | Computers & Internet
Mx6128 gatway hard drive
The smallest hard drive that can be purchased is approx. 100Gb. You need a Windows installation CD, and provided you have the product installation code (it should be on a Windows label on the bottom of the laptop) installation is fairly straight forward. You may be able to get a Windows CD from a computer shop, they may install Windows for you at a cost. You need to download the device drivers for the laptop from the Gateway WEB site.
Jun 05, 2009 | Gateway MX6128 Notebook
My HP Pavilion laptop will not boot.
Usually the message about low virtual memory is because there isn't enough RAM and it was using up all the designated space on the hard drive as Virtual memory. (Uses a part of the hard drive like RAM)
That shouldn't account for being unable to boot into any Windows options though.
The one trick with HP computers, you can try is to take the battery out, make sure the Laptop isn't plugged in with an AC adapter then press and hold the power button in for 10 seconds with no power going to the laptop. This is doing a power drain. Then put the battery back in and try to power on and boot up the computer.
When you choose safe mode, does the computer ask which operating system you want to boot into and does it give you the option to choose "Recovery Console"? Or is there an option on the screen with the safe mode options to Choose your Operating System? If not then the recovery console wasn't installed. If you can choose the recovery console, you might be able to replace the failed files that are not allowing the computer to boot into any version of Windows. Unfortunately, the computer isn't reporting which files are the problem, winlogon.exe/userinit.exe/etc.
You can get a hardrive enclosure at a computer store that allows you to put the laptop hard drive in the enclosure, then plug the enclosure into another computer with a USB cable then you can copy the sensitive data onto the other computer.
If you aren't comfortable taking the Hard Drive out yourself, you can take the laptop to a computer store, and they will take the Hard Drive and hook it up to a second computer as a Slave (Secondary Hard Drive) and copy the data over for you
Apr 12, 2009 | HP Pavilion dv8000z Notebook
Black Screen
try hooking up an external video source. Check to see if the computer is actually booting up. if the computer boots up, then the LCD invertor or Backlight of the screen is bad, need to be replaced.
If the computer does not boot up after hooking up an external video source, then most likely your motherboard is bad!
Jun 29, 2008 | Computers & Internet
Problem: Cannot Load Windows/Windows Setup Does Not Detect Hardrive
My Hp Compaq tc4400 Does not load Windows and when i try to install a new one and error Message apears saying that it cannot detect any hardrive, but when i press F9 for boot selection Notebook Hardrive is dected and availble, i tried removing the hardrive and re-insert it also it dint work could somebody help plssss
Feb 01, 2008 | Compaq tc4400 Tablet PC (RL875AW#ABA)
Computers & Internet Logo
David Payne
David Payne
