Question about Sony Computers & Internet
Screen was covered in circles then lines now blank
    Problem Solver:
  • 8 Answers
Graphics card probably dead.
Replace motherboard.
Posted on Sep 27, 2009
Why is there two black spots in image on screen. Two round black circles. Not sure what it means and where they came from
1st make sure screen is clean. inspect when off. use only cloth slightly damp with water.
2nd make sure it is not the image by looking at another image or a blank white screen. Some test images will display each color.
if it is there on any image the pixels are dead. But being circles sounds more line screen cleaning
Sep 14, 2014 | Vtech InnoTab 2 - VTECH
How do i set the timing on an 87' kawasaki 454ltd?
there are two flat head screw on left side side cover take them out one will have a nut to turn crank will looking in other hole turn motor till u seee a T with a line now the should be a notch in the threads of the hole u are looking through line the line beside the T with the notttch u see now with valve cover off u will see ether one circle or two straight lines one the gear attached to crack if it is one circle put that straight up or if two lines adjust them till both lines go staight (side to side) with the top of the head
Feb 11, 2014 | Motorcycles
Phone screen blank and when on charger circle ring w/3 colors
That means that your phone has corrupt firmware. Please get the firmware reinstalled from Samsung Service Center. That would remove the virus too which may be the cause of corrupt firmware. And after that install an anti virus software too.
Feb 20, 2010 | Samsung Propel A767 Cell Phone
My satellite toshiba laptop shows a screen of fine colorful lines
did you ever try to go on gateway site to find a fix or microsoft.com to see if there is a update display driver for you computer
Feb 10, 2010 | Toshiba Computers & Internet
How do I remove & replace screen on Xda orbit.
I used a T6 Torx screwdriver, a piece of flat strong plastic (other people have suggested old credit cards), and a small flathead screwdriver (but not essential).
1) After taking the battery out I also removed the SIM card, the memory card, and the stylus
2) This picture shows the first screws to remove (circled in red), by using the torx
3) I then levered the hole the stylus fits into, by prising up with the end of the stylus (to remove the back cover)
4) Using the plastic tool I slid it around the edge, being careful not to put to much force into it to remove the rest of the clips around the back cover.
This is a picture of the back cover off with the locations of the clips (note the camera hole for orientation)
5) I then removed the next set of screws (with the torx again)
6) I then removed the middle cover by prising against the front (the front was connected to the circuit), I found if it didn't want to release in one direction, then I would tackle it from the other way round
7) Then to prise off the front cover was straight forward by using the flathead to lever the two clips in red
** The connector circled in yellow is for the front button set, and I didn't need to remove this to change the screen **
8) I then removed the flexi circuit connecting the screen (circled in blue) - I did tear mine, but that is fine for me as the screen was broken anyway, so if I was to do it again I would take more care
This shows the front cover with the clips circled
9) The screen was held on with two strips of sticky tape, and I just used the flathead to prise it away
Connecting the new screen back was straight forward, as was putting the phone back together once I knew where the clips were. I did need to make sure the volume button was lined up with the connection on the circuit however.
If the links don't work go here
Hope it helped.
Nov 26, 2009 | O2 Xda Orbit Smartphone
The calculator is only graphing a half circle when it should be a full circle, specifically not in the negative y-values of the plane.
A circle is not a function and cannot be graphed in the regular y=screen. You can graph a circle in parametric mode.
To graph a circle in the regular y= screen, you have to graph it in 2 lines on the y= screen. I assume you've solved for y and gotten a square root equation. Remember a square root can be positive or negative. In line 1 of y= screen graph what you've been graphing and then graph the same equation in line 2 but with a negative in front of the equation. You'll get something that looks like an oval since the calculator screen is rectanglular. To make it look more circular (both parts aren't going to connect), press zoom and then select #5 (square).
Aug 01, 2009 | Texas Instruments TI-83 Plus Calculator
Intermittent blank screen with r,g and b semi-circles at top of screen
the blinking standby light should be a help. It should be blinking a repeating code. Can you post that here please?
Thanks,
Dan
Sep 09, 2008 | Sony KP-46V35 TV
YIKES! Have a 46 inch 1080p Sharp Aquos. Last night when attaching the S video cable and was teetering the TV, the LCD screen scraped the corner of the stand and now there is 3 small black circles in the...
This will be horrible news, the screens are fragile and what happened is you broke the screen, And since this falls under customer abuse it will not be covered by warranty, so the cost of replacing that screen will run anywhere from $1200.00 to 1600.00
Feb 22, 2008 | Televison & Video
Sony Ericsson K810i Cam Blank
Hi..
Sounds like there could be a manufacturer defect so if the phone is still within the warranty, I would definitely contact them and let them know about the green circle and such. I've never seen anything like that before on any of my Sony phones..
Hope this helps..
donster74
Feb 11, 2008 | Sony Ericsson K800i Cellular Phone
Screen is blank
· Samsung parts for convergance problem
· http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
Nov 08, 2007 | Samsung HCN4226W 42" Rear Projection...
Computers & Internet Logo
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
