Question about Jenn-Air JMV8208A Microwave Oven
Sharp carolsel model r1505 on/off buttons broken
My select buttons, not the touch pad, are either loose or one is broken. i think i have a part number to replace, but how do i get to the buttons to replace?
Unplug micro wave.
3 screws to remove top vent.
1-screw to remove touch panel from chassis.
tilts foward disconnect wires from board . I labeled for
reassembly .
1-screw holds the touch panel electrics to face plate.
There are 4-6 snap in plastic tabs holding it in place.
you have full access to the cheap plastic hinged buttons.
I hot glued mine once but they broke after 6 months.
I found this site:http://207.234.249.73/mwd/#brands
Good pics and you can see the buttons.
They sell a replacement button for $15 . There is also a
complete service manual for the Sharp 1505 for free download.
Did I mention to unplug the microwave before starting...
Rob H
Posted on Dec 24, 2007
My Sharp R1505 over the range microwave probably has a door switch out of alignment. The door itself is level and aligned. The unit will show the heating time but will not heat. It will heat if I push the...
Assuming your hinges are tight, your bottom door switch is probably defective, or its mount is loose, misaligned, or broken.
This is usually caused by opening the door while it's cooking (instead of hitting "stop" first) or slamming the door.
I have the service manual at my site here. See my help file on door switches here.
More questions? Contact me directly here.*
* always include the full model number and FCC ID number from the label on / in your microwave (or a clear photo of the tag)
Jan 27, 2018 | Sharp Microwave Ovens
Sharp microwave 8888 is flashing and I cannot remove
see this steps and fix it. God bless you
Reset the clock. Press "Clock" and the correct time, using the number pads. Press "AM/PM" if applicable, and press "Start" or "Clock" to confirm.
  • 2 Press "Timer On/Off" to reset the timer if nothing on the touch pad will operate. Use the number pads to select a new timed amount, if desired, and press "Timer On/Off" to start. Press again to cancel.
  • 3 Press and hold "Clear/Off" for three seconds if the timer will not function or is blinking when you touch the pads. This will release the "Child Lock" feature. Make a new touch pad selection.
  • 4 Disconnect power to the microwave if following Steps 1 through 3 does not resolve the blinking timer. Wait a few minutes, and then restore power to reset the microwave.
  • However if the problem persist the display board
    main control board is faulty
    Oct 02, 2012 | Sharp Microwave Ovens
    My over the stove Sharp Carousel Model # R-1505F turn table stopped turning. What part do I need to replace. Also, I broke the glass turn table plate. What size is that and where can I order another...
    Sears Parts Direct has the parts diagrams and many parts for the R-1505 microwave. The glass plate is part 4-3 ($33.99) on this page: http://www.searspartsdirect.com/partsdirect/part-model/Sharp-Parts/Microwave-Parts/Model-R1505/0958/0123370/50019999/00001?blt=06&prst=&shdMod= .
    Without more tests, I can't be completely positive but the turntable motor is the likely problem. That is part 1-4 on the list above. However, it could be a wiring problem with the wiring to the turntable motor.
    Partstore.com has many of the parts as well: http://www.partstore.com/Model/Sharp/Sharp/R1505.aspx .
    I hope this helps.
    Jul 29, 2011 | Sharp R-1505 Microwave Oven
    We have a fairly old Sharp Carousel microwave, model number R-2A95. Out of the blue the entire keyboard stopped working. The numbers were still on the screen, but none of the buttons worked. We took the...
    Before you invest too much time, look and see if the touch pad is still available. Sharp is pretty quick to discontinue parts right after about 5 years. There is a place called encompass parts. They are a distributer for Sharp, you micght check with them.
    Oct 07, 2017 | Sharp Microwave Ovens
    Buttons don't work
    Hello there:
    This is normally caused by a faulty touch pad that is failing These touch pads are replaceable but they can cost about 60 to 100 dollars depending on the exact make and model ok
    I hope this is very helpful for you
    Best regards Michael
    Dec 11, 2009 | Microwave Ovens
    No numbered touch pad for use setting clock
    I think on this one you press the CLOCK/TIMER pad, then enter the desired time using the 10 MINUTES, 1 MINUTE, AND 15 SECONDS pads then press CLOCK/TIMER again.
    If that doesn;t work, press STOP / CLEAR then try the above again.
    Let us know if it does not work.
    Mar 05, 2009 | Sharp Microwave Ovens
    Unlocking child lock on the sharp microwave model R316FSC
    The Sharp Microwave/Convection oven I have says to touch the Custom Help button, the number "1", then touch the Start Button. To turn off the child lock, press the Stop button.
    Or just unplug it, wait 1 minute, and plug in.
    Jan 06, 2009 | Sharp R-308J Microwave Oven
    Sharp R-1450 microwave
    This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
    On these, it's usually a broken tab on the upper switch holder.
    One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
    That sounds like what's happening when you hold the Start pad - maybe you're moving the frame and chassis enough to help it work.
    Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
    Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
    There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
    The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
    Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
    If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
    You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
    The best place to order Sharp parts is Tritronics.
    If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
    William E. Miller
    prototech@usa.net
    http://www.microwavedisplay.com
    Aug 19, 2008 | Microwave Ovens
    Sharp R-1460 Over the Range Microwave
    This is usually caused by either a bad upper door switch, a loose upper door switch mount, or occasionally a problem on the control panel.
    Sometimes it's a lot to just secure the switch with a drop of hot glue instead of replacing the latch head.
    Aug 13, 2008 | Sharp R-1870 Convection/Microwave Oven
    Start button
    We have the service manual for this model and have uploaded it to our site here to help you. You will need the free Adobe Reader to view or print it.
    On these models, the problem is usually a broken tab on the upper door switch mount.
    Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. Other times, it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
    You can probably find exploded views and order parts by entering your model number here at the Sears parts site. The best place to order Sharp parts is Tritronics.
    We're happy to help you and we'd appreciate your thoughtful rating of our answer.
    William E. Miller, AS-EET
    prototech@usa.net
    Jul 22, 2008 | Sharp R-1480 Microwave Oven
    Jenn-Air JMV8208A  Microwave Oven Logo
    445 people viewed this question
    Top Jenn-Air Microwave Ovens Experts
    William Miller
    William Miller
    Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
