Home theatre but TV without audio outlet
Help, purchased new home theatre system and wish to run TV sound through home theatre. Only audio outlet on TV is via headphone outlet. Sound runs through home theatre -albeit low volume but sound still ocurring via TV in built speakers. Need to have quite loud to get benefits of theatre Two questions - How do I increase volume through home theatre and how do I stop / disconnect volume through TV speakers - Thanks & Regards
philips tv 42PF7520G/98
I would suggest that you smash
Philips HTS w/a hammer!
I had better sound from TV alone! Only 2 speakers put out sound from TV. Recordings from DVR can not be heard very well w/all volumes at max. System sucks! You get what you pay for! $2500 LCD TV sounds worse w/Philips HTS than my son's $300 TV! ALL cables hooked up as instucted!!!!
Posted on Jul 09, 2008
Hi I have just purchased a Panasonic Plasma TV and Panasonic home theatre. Everything works well except for I cannot get sound coming out of the home theatre when watching normal TV. I purchased the...
Try running the audio from each video source (NOT the TV, which is an output, not a source) to the HTR digitally so you'll get the best mutichannel sound possible. Then you can turn the TV speakers (assuming it has them) off for hi-end watching.
Aug 15, 2010 | Panasonic Audio Players & Recorders
Ghosting of picture from a Panasonic home cinema system
There must be a fault in the screening of the internal wiring to the scart outlet in the home theatre system. I simply changed the way the player was connected to the TV and the interference disappeared:-
1.) I used the RCA video outlet instead of the scart lead. Picture quality was not compromised. FYI the Panasonic Plasma TV I have has only RGB video input sockets at the back, so I used a scart to RCA adaptor to overcome this problem of connecting old technology to new.
2.) The surround sound when playing DVDs is generated directly from the home theatre system so there was no need to connect the audio from the home theatre system to the TV
3.) I used a pair of RCA leads to connect the "audio out" from the TV to the "audio in"on the home theatre system to provide the option of TV sound through the home theatre system.
Mar 18, 2009 | Panasonic Televison & Video
Samsung series 6 tv & Samsung 2:1 home theatre problems
if you got all the lead you should have fibre optics which connects from dvd to tv and then set your dvd to digi in. you should get the sound. i have same cinema system and i have done the same
Jan 13, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Sound goes off
You probably have too much power running to your power strip that you probably have your xbox, playstation, tv and home theatre system plugged into, try using seperate wall outlets for your tv and home theatre system
Dec 20, 2008 | LG LHT854 Theater System
Samsung HT-BD2R 7.1 Channel Blu-ray Home Theatre System
Connect the PS3 with HDMI to the Home theatre.
Connect the TV digital optical out put to the optical input cable of HT-BD2R provide your tv has a optical digital out put
You have the option of channeling the out put through either optical or HDMI in PS3.Go to the set up and set the audio out put to HDMI
Nov 28, 2008 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
How to redirect the sound of my new LG 52" HDTV LCD to my LG home theatre?
Flemflam-   There is a couple of options here. If you are using a DirecTV Receiver or a box from the cable company then you want to run the Audio out lines to your Audio/Surround Sound Receiver. If you are running cable directly into the TV then you want to use the Audio Out Plugs on the TV. In some cases there is no Audio out but there is a Headphones out. In this case you can run a Mini-Plug to Composite Audio cable to the receiver.    You can also Call 1-800-GeekSquad and they will dispatch an Home Theater Installer to resolve your problem! They are great for Turn Key Solutions!
Jul 11, 2008 | Insignia LCDTV26 26 in. Television
No sound from plasma to home theatre
First off it's always best to start from scratch when it comes to home audio. LoL. Many times I've been in this situation.
So with everything disconnected. You should have your HDMI, COMPONENT, RCA(R,W,Y)
HDMI and COMPONENT are the exact same thing and in all preference COMPONENT is far better thand HDMI for the pure fact that each wire is in it's own casing and insualted to avoid feedback from the other wires.
Anyways, with everything disconnected we begin
From you Cable/satellite box- Run your HDMI cable from you cable box to your HDMI 1 input on your tv.(If your speakers were to work on your tv you would automaticaly get sound and picture)
That should be all that you should be running from you cable box. Now that we have one thing running we go to the next thing.
From your TV run your audio out (RCA Red/White) to your amp. Usually your preference but more than likely your TV IN on your amp.
With your amp now set on TV, you should automatically get sound from your tv. and if your running an HD cable box even though your only running RED/WHITE to your amp, you will still be receiving Digital sound.
Most new amps Should have a digital input and if your running and 1080iUp this one RCA plugin will give you dolby digital sound from your dvd player to your amp. Then running a video rca up to your tv, will give you the picture, while the digital out on your dvd player to your amp will give you dolby digital sound.
It's a basic simple step to get sound. Like a continuing current. So just as long as you have your cable to -- tv -- home theatre. Everything should work. Otherwise I would go and check your cables and make sure they are not faulty.
I hope this confusing walkthrough helps.
Jun 23, 2008 | Panasonic TH-42PX60U Television
Panasonic home Theatre
You need to obtain audio leads and connect from home theatre directly to audio input in back of tv - be careful as there are normally 2 in back of tv
Dec 14, 2007 | Panasonic SC-HT720 System
There sould be audio outputs on the back of it, and the manual should clearly show how to set up a home theatre with an external sound system and all.
I don't know what kind of sound system you have, but I think it might be best to connect your video source (typically DVD player) to your sound system, as it usually can be done better that way. No need to introduce another link in the chain (your TV) that could degrade sound. Also any external tuner could (should) be connected to your sound system directly.
If you use the internal tuner in your TV to watch TV the audio out is your option. Best way to get this right is to consult the manual. They usually have some diagrams that shows a few options of how to do it.
Dec 05, 2007 | LG 42LC2D 42 in. LCD HDTV
752 people viewed this question
