Question about Canon Rebel XT / EOS 350D Digital Camera
My cmera just quit working yesterday no warning ...its not the battery it fully charged
3 Suggested Answers
darntoothysa
  • 489 Answers
SOURCE: Battery Fully Charged Camera Won't turn on
Hi
There are several things that could cause this.
1- Check the battery door indicator switch under the battery door and beside the memory card slot. Is the little black switch damaged or missing? Try pressing down gently using a pen it with the door open and then press the power button. Does it turn on?
2- The fuse has blown and needs to be replaced. Offhand I don't recall where it is on the SD600 PCB or how hard it is to solder on a new one (depends on if its tricky to get at or not). Good thing is fuses are really cheap.
3- Other power problem with the PCB due to corrosion or impact damage. The PCB or 'motherboard' of the camera will need to be replaced.
A couple solutions would be to either buy a defective camera online and make one good camera from the two if you can do that sort of thing yourself, or secondly have it repaired by somebody.
Don't bother trying to send the camera to Canon if it is out or warranty (though you can call them and verify what I'm about to say) because they will want $150+ to do the repair for you. Parts are not cheap to buy from them.
I know of one very affordable digital camera repair business... because I own it. The name is Darntoothysam, feel free to check us out, we are on that big auction website also (I don't plug their name for free), our seller ID is 'darntoothysam'. If you Google "darntoothysam" you will find us.
If we can help with your repair then please let us know.
Hope this helps,
Thomas
Posted on Nov 11, 2008
  • 340 Answers
SOURCE: False battery low warning on
Are you using Ni-MH batteries, this problem are so common on canon A series cameras, the cameras' judge setting of low voltage is too high, you'd batter you lithium batteries.
Posted on Jan 08, 2011
How does semi charged battrey cause electronics to go mad
charge your battery as the computers do not operate correctly if battery voltage is to low.. there is no reset just put in a fully charged battery.
Jul 13, 2014 | 2003 Renault Megane
Phone will not turn on and is as good as dead. It has not been damaged in any way, the battery is fully charged. It was working fine yesterday
no.the battery its not fully charged
the battery got dead.yo need to relife it.by sending it to a mobile repaire store.
or buy a new battery
May 08, 2011 | Cell Phones
I have a 99 Nissan Quest. Replaced battery 4 times in two years. Some of them hada dead cell. Yesterday battery died again and had it charged. Instrument panel warning light flashing for the battery,...
has to be the alternator, you can determine if it works by putting in a known good battery, checking voltage when running-it should be at least 13.8 volts at the battery with the engine running. If not you can check the alternator output at the rear of the alternator itself-there is a post, it is positive, use the meter to check here. If you get low voltage here (less than 13), you know it is the alternator.
Dec 25, 2010 | 1999 Nissan Quest
Battery fully charged but warning light
has your battery being replaced new one might not have sensor if so you can fit a 50 k resistor between the positive terminal and sensor wire located next to the battery this will stop light flashing
May 25, 2010 | 1992 kawasaki GT 750
My Garmin 1350 is fully charged. I used it
the software on garmin 1300 models is atleast 3.6/7 sounds like ur update didnt take, also check in settings see if you have a timer setting for sleep mode/stanby after x time
Dec 26, 2009 | Garmin nuvi 1350 Car GPS Receiver
Kodak Easy Share z712 IS not detecting charged battery
I have the exact same camera almost a year too. It is a total "swinka" on batteries. About 10-15 shots on super ni-cads, and quits without warning.
A pair of Energizer 7X gave me near 500 shots. Much cheaper but still ...
So 4 months ago I bought a charger and 2 rechargeables. Charge one while using the other one.
I may get 70-90 shots per charge on these lithium-ion rechargeable batteries, without flash.
Testing the batteries without a load doesn't really tell you anything.
What's the reading? Should be well over 4 volts when fully charged. Mine show 4.2V
Jul 24, 2009 | Kodak Cameras
Batery gone quickly in one call, eventually cut off
is your battery easily fully charge when you charge it? and easily went down after?? if yes, that migth be battery failure..
if not, there can be some shortage in your phone.
Mar 17, 2009 | Lands Phones
Help
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
May 25, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon Ixus 75 not charging
The camera was working fine 5 days ago. Yesterday when I tried to switch it on, I assumed that the battery was flat so I charged it but when fully charged the camera still won't switch on. i Please help!
Mar 24, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon Rebel XT / EOS 350D Digital Camera Logo
55 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
