Question about 2wire 2700HG-B Router (2700HGB)
Changing channel on router
Where do I go to access my router settings? I have 2wire 2701 HG-B. I can't find the answre anywhere.
    Problem Solver:
  • 8 Answers
Hi....
to change wireless channel of your 2wire 2701hg youjust need to access its default gateway 192.168.1.254 type it on your address bar using internet explorer and you'll see network at a glance page. click on home networking tab at the top and look for subtab written in blue click wireless settings. you'll seewireless name and under that you'llsee wireless channel you just need to pick the channel that you want to use...
Posted on Sep 29, 2009
4 Suggested Answers
SOURCE: My 2wire router 2701 HG-B
Your wall filters may be plugged in wrong. Verify they are plugged in correctly. This is likely the problem.
Posted on Nov 14, 2010
XopenX
  • 108 Answers
SOURCE: I need information on how
Log into your router. Click on home network. Status at a glance box, click on edit settings under wireless settings. Under setting click enable SSID and Wireless network security. Your WEP key is on the side of your router. The number above the second bar code with brackets around it.
Hope this helps you.
To log on to your router type the routers ip address into the address bar. If you don't know it....click start....run...type cmd press enter....type ipconfig /all at command prompt...press enter... look for default gateway address.... type that number into the address bar of your browser.
Posted on Jan 29, 2009
phofire
  • 27 Answers
SOURCE: i have this 2wire 2701
you can ussually surf to the routers configuration page via its ip address
From a command prompt type IPCONFIG and the default gateways 'should" be the router's IP
Posted on Feb 04, 2011
Can the 2701 HG-B handle 6000-plus Kbps?
According to the setup screen, it can handle DSL link speeds up to 10692kbps (down) and 1036kbps (up)
I can't verify that it works, but... that's what it says
Jan 02, 2013 | 2wire 2700HG-B Router (2700HGB)
I have this 2wire 2701 HG B wireless modem router. I have lost its manual. How can i access its settings to disable wireless router
Feb 04, 2011 | 2wire (2701HG-B) Wireless Router
My 2wire router 2701 HG-B drops the wireless connection when someone calls on the home hard wired line. Is there something wrong?
Oct 01, 2010 | 2wire (2701HG-B) Wireless Router
Is the DWL-520 Wireless Adapter compatible with the 2701 HG modem
The 802.11b and 802.11g Wi-Fi networking standards are generally compatible. An 802.11b router / access point will work with 802.11g network adapters and vice versa.
There is no such conflict reported with the above devices. But as suggestion use an 802.11g wireless card with the Bell as it would give you better performance
Thanks for using Fixya
proton
Jul 27, 2009 | D-Link Air DWL 520 802.11b (DWL-520)...
I have a 2wire 2701 hg-b modem,it wont let me get on the internet,it says that tcp port 80 wont let it get on,something with the firewall?is there any way i can get around this and get online?
Try restoring it to factory defaults and start again with securing your network, document every change you make that way you can come back to it and see what change you made that might be affecting your internet access
Mar 29, 2009 | 2wire (1000-400108-001) Router
I need information on how to configure my 2wire 2701 HG-B modem for wireless access
Jan 28, 2009 | 2wire 2700HG-B Router (2700HGB)
RE: My posted. Connecting DSL/Router to DIR-628 internet router
Installing a router to work as the second one on a home networkrequires special configuration. Do the following on the second routerto ensure it (and the devices attached) function properly:1. Connect as local device or bridge - If connecting the second router via Ethernet cable, plug it into one of the LAN ports on the first router. If connecting the second router wirelessly, ensure the second router is set for client mode.Note that some home wireless routers do not support client mode; thesemust be connected by cable. Check your router documentation for detailson its client mode configuration support.
2. Check / change IP address - Most home network routers use a default IP addresssetting. Often, these default IP addresses will not work in a tworouter environment. Check the second router's IP address value andreset it if necessary to work within the valid address range of thefirst router (and to not conflict with any other device on the network).
3. Disable DHCP- To avoid IP address conflicts between all of the devices on the homenetwork, only one of your two routers should assign addresses via DHCP. All mainstream routers provide an option to disable DHCP as part of the router's configuration screens.
(My netgear router supports client mode. The 2wire supports bridged and router mode. My 2wire is the main router. I set up my netgear using my laptop. Once you change the address on the router.. You will only be able to directly access through the main router to the 2701.)
Configure your 2701 IP address to a static address in the 192.168.2.1 range and diable DHCP. Only 1 router can run the DHCP service. To disable Dhcp on the 2701.... log on to 2701> click on home network>advanced settings>uncheck enable DHCP>Next section is Public routed subinterface...Check enable and Aout Firewall Open>Input your main router address and mask>save config..
This worked with the Netgear router.. May not with your router. Good Luck! Hope this helps!
Jan 16, 2009 | 2wire 2700HG-B Router (2700HGB)
2wire058, mod 2701 HG-B
To akd56 - tks for yr earlier advise, I got as far as "connect to a network" which asked for my security key / pass phrase when setting up which I now forgot.
Nov 18, 2008 | 2wire 2700HG-B Router (2700HGB)
2wire 2700HG-B Router (2700HGB) Logo
400 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
