Question about Toshiba 50H72 50" Rear Projection Television
Toshiba 50H72 When the tv is cold started, the picture is wavy and then goes blank. There is still sound. No bad smells.
I have one of these would you be willing to repair, i already have the board disconnected from main board. LMK.
I can be reached @ itsmesab@comcast.net
Posted on Sep 01, 2008
  • 934 Answers
The Hyper Module Is Defective / It Is Located Behind The Jack Panel On The Signal Board.
More specifically the 11 16v/10mf caps on that board need to be replaced... Not expensive, I do them for under $100.00 dollars..
Bill
Posted on Feb 03, 2008
When turned on picture is very wavy (can't tell what you are even watching). After a time it becomes clearer until picture eventually returns. Recently, picture is wavy, mores on top, and has a slight...
The problem is from the lamp of the television, it seems to be having some faults, it is gradually getting damaged.
It will start by being wavy until it goes completely blank.
Some lamps go for about $125 or more. Some go for $200.
Take care and Good luck
Oct 23, 2010 | Televison & Video
My samsung le40r73bd tv has developed a fault the tv switches on and you get sound and picture then after approx 2 minutes screen goes blank and sound remains other times tv comes on with sound but no...
there is a problem on your inverter board and the cold cathode lamp.The inverter board is the supplying high voltage supply to the cold cathode lamp.This cold cathode lamp is the illuminating the screen in which the the picture will appear once cold cathode is lit.here is a link where you can buy the parts.. Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
  1. http://s807.photobucket.com/albums/yy352/budm/Bad%20backlight%20lamp/
  2. http://s807.photobucket.com/home/budm/allalbums
:Good luck hope this helps you..
please rate my help
Jun 14, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
TV goes blank - no sound or picture
Sounds like a bad capacitor or two in the power section. Do you hear a hissing sound also?
Nov 18, 2009 | Pioneer PRO-510HD 53" Rear Projection...
We have a samsung rear projection tv with the same problem of fine wavy lines across the whole screen,more visible with light and dark colours, its like watching the tv with fine rain, sometimes the...
Your convergence ICs could be going Bad if so TV will shut down if the one that starts it goes out first STKs big black ICs also 2 resistors l;ow ohm 2.7 ohms near ICs.
Aug 14, 2009 | Samsung Televison & Video
Samsung T.V. goes on for 30 seconds then no picture
If this is a flat panel LCD tv, this is a sure sign that the panel itself is bad. I have seen this before. Tv comes on works fine then within 5 minutes goes blank.
Aug 07, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
RCA F27442: no picture.
you may have bad solder connection in the horiz.countdown section.
you may also have a GEM Star module bad.
Nov 06, 2007 | RCA F27442 27" TV
Picture issues
a short grid with an internal cathode in the CRT
Sep 02, 2006 | Toshiba CF32G50 32" TV
Wavy picture
this is caused by a bad convergence module, and there are probably some dried out electrolytic caps in the circuit as well. i have one in the shop right now that came in with the same problem. if you have it serviced, make sure they replace all of the convergence modules (there are usually 2, but sometimes 3 of them), because if one went bad the other(s) is likely to go out soon as well.
Jun 28, 2006 | Toshiba 65H82 65" Rear Projection...
Toshiba 50H72 50" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
