My acer laptop is not starting , i am switching on the start button the green light is comming but the windows are not starting
    President:
  • 942 Answers
Today's machines require we make our own or order them. Let's see if Acer has some boot recovery method but first, I'm going to write as if there is no issue about losing files on the machine.
Try the ALT+F10 key
First of all you must be aware that some of the operations to come can cause irreversible change on your hard disk, I recommend to you and I will never make it enough make a backup of your system before launching you in any hazardous operation.
Any damage and/or modification done on your system will be under your whole responsibility. The following procedures were done on a Acer Aspire 5102wlmi and some also functioned on a Dell Inspiron 9400/1705.
As you know, the Acer computers and those of other manufacturers are now delivered with a system of restoration installed in a hidden partition of your hard disk. This system launches out while pressing keys ALT+F10 simultaneously. And sometimes for various reasons this system ceases functioning.
The first cause often comes owing to the fact that function D2D Recovery is disable in the bios (menu principal).
The solution : enable the function and try to press keys ALT+F10 during the starting of the computer.
The second cause : in this case hidden partition PQSERVICE was erased or damaged, or you replaced the disc and in this case it is not present.
The solution : If you did not previously make a backup of your system by making an image disc. It will not be possible to use the D2D recovery. Your only hope will be to have in your possession Acer Recovery CD/DVD.
And the third causes : the Acer Master Boot Record (MBR)was damaged or replaced by non-Acer MBR. As long as partition PQSERVICE is present or that you can put the hand on the necessary Acer files you can reinstall the MBR of Acer.
The solution :
First method : on a functional Windows system:
1 disable the D2D recovery option of the bios.
2 open a Windows session with an account administrator.
3 Download, unzip and launch partedit32(registration required for download).
4 Identify the Pqservice partition by its size (at the bottom of the partedit window there is a partition information box) it is a small sized partition approximately 2 to 6 Go.Once made change the type of your partition into 0C and save. Restart and open a session with an administrator account, you should be able to navigate to the PQservice partition. Seek these two files mbrwrdos.exe and rtmbr.bin once localised open a command prompt and launch this command mbrwrdos.exe install rtmbr.bin, this will install the Acer MBR. Close the command prompt window restart again Windows go into the bios and reactivate the D2D recovery. Now ALT+F10 should launch Acer recovery at the starting of the computer.
Second method : On a nonfunctional Windows system.
For that you must use a Linux distribution (for me Mandriva provided all the tools necessary).
1 Boot on the Mandriva install CD/DVD the boot menu will give you the possibility to repair or to restore the Windows boot loader.
2 If that is not enough launch an installation of linux(this will be an occasion to test this terrible OS) and choose LILO as boot loader(a boot menu that allow you to choose between several operating systems) once finished the installation. Restart your computer in the boot loader menu system you will have at least 2 Windows options the first generally point to PQservice choose it and you will boot directly into acer D2D recovery.
The last solution is the simplest one, just note that during the Linux installation you will have to resize your Windows partition to create a place for a new Linux partition it is the most perilous part because irreversible, therefore take your precautions at this time.
Regards
PCmania
Posted on Sep 27, 2009
Why does my screen keep going black on my Acer Chromebook c720?
Try checking the lights on the front of your laptop, are any indicator lights on? I have an older Acer Extensa, but the quickest way for me to identify what its probably doing is that if I see two different colored lights I know that; 1. a green light means there is power to the laptop so more than likely it isn't actually off or all lights would be off, 2. if I see an amber/orange light on the front or near the power button its in a power setting mode, which means its either hibernating or sleeping. You can usually wake it by quickly tapping the power button or tapping the enter button, depending on your laptop you may have options hot keys on the keyboard. If it wakes by doing any of those things then check your power settings to see if you have it set to sleep or hibernate.
I have Windows 7, I left click on the start/ lower left Windows Icon on the task bar/control panel/performance and tools/ then on the left side list, power setting options. Or just click start and in the search box type power options, you'll see the direct link under the control panel section. I hope that helps. Try running troubleshooter too
Mar 04, 2014 | Acer C720 Chromebook Gray 11.6" Notebook...
Will not power up. Green light on power source
Red battery light means battery is charging. It should start up even if battery is low. Try pressing on the area above and to the right of the power button, while you are pressing the actual power button.
May 13, 2010 | Acer Aspire 9500 Notebook
Acer aspire ONE PC will no boot
Try reseating the ram inside the laptop or try known working ram.
May 05, 2010 | Acer Aspire One PC Notebook
I bought my acer in 2008. worked great up until a certain period where it would over heat and shut off. i put in windows 7 and that problem stopped, it wouldn't over heat anymore and shut off. then it...
i would never by an acer my sister bought 3 of them same problem but i had a hp and did that hard drive was failing, yours could be a computer virus too
Mar 24, 2010 | Acer Aspire 7520-5185 Laptop
I just want to know to turn on my TravelMate Laptop computer. I want to where the start button is? Simply as that.
You will find a key that has C facing upwards with an I in it. This is the power on switch.press it lightly. Three LEDs will turn green for a moment and then some more LEDs with start blinking. And finally you will get the Windows desk top.
Nov 08, 2009 | Acer TravelMate 4150LCi Notebook
Acer aspire one power button comes on but screen doesn't come on.
1/ Take a close look at the display in bright light; can you see anything there? (If so then the CCFL (or its power supply) needs replacing on the display
2/ hook up an external monitor and see if that works (or at least if the light stays green on the monitor)
3/ Any boot beep? any "Windows sound"?
4/ try removing the battery and (using only external power) see if it starts.
4/ remove the battery AND the external supply, hold the power switch in at least 30 seconds. Hoojk it up again, try it.
JOAT
Oct 16, 2009 | Acer Aspire One PC Notebook
Laptop wont switch on fully
Did you press F8 as you boot up to get boot up options and did try the Last Known good Configuration and Safe Mode?
If these didn't work I suggest you re-install Windows.
Apr 10, 2009 | Acer Computers & Internet
Brand New laptop, won't start
Try taking the battery out before you turn it on. Have seen completely a dead dead battery keeping a laptop from starting up. Does the hard drive activity light flickering? If it is you can try holding down the Function button (FN) and there should be another button to hit to switch between LCD\CRT.
Mar 01, 2009 | Acer Aspire 5520-5908 Notebook
I have a brand new acer aspire one. A moment ago, when I wanted to open it, I saw that the green light on its top right, that is, at its "start" button was on, and the battery was a bit displaced at one...
Most likely your laptop is going into sleep mode. Lots of them do not like sleep mode if nothing happens when you push the power button try to hold it down for about 5 sec. your computer should power off and then you can start as normal. If this problem persists change the options in your control panel to turn sleep mode off. That should solve it.
Dec 18, 2008 | Computers & Internet
Computers & Internet Logo
1,368 people viewed this question
David Payne
David Payne
