Question about HP LaserJet 5p Printer
Hp laserjet 5p will not print with new computer (Vista)
Purchased an adaptor for usb port, added printer sent test page, but nothing happens. I have run a driver update, but no results. I really want to keep this printer because it is low cost and fast.
  • 557 Answers
Check cable for error take a other printer to try
mostaly if you connect usb in the usb port then it select the poort 1 or 2 or 3 and find the printer if you chanche it for a other poort it wil not see the printer
Posted on Sep 27, 2009
I've try to connect my HP laserjet 5p printer to my mac g4, I purchased a USB cable. It prints unreadable text and won't stop, any ideals?
Make sure that you are using the correct drivers for your printer, run through the printer setup again and then check the print.
Jul 13, 2011 | HP LaserJet 5p Printer
HP 5P wont print on Vista
I deleted the email but still have the hard copy, so here goes. This worked with my 14 year old hp and a Dynex USB-Parallel cable.
1. Plug the printer to the USB-parallel printer cable and turn on printer.
2. Plug USB end to USB port on you computer.
3. When you do this, the computer will recognize the cable.
4. Go to Control Panel/Hardware/Device Manager/USB Controllers.
5. Make a click on the + icon and check if you have USB Printing Support
(If you are not able to locate it, unplug cable from USB port and plug it
back in, so you will see something that's new on the Serial Bus
Controllers).
6. Make a double click on USB Printing Support to open a new window
and look for device status. You should see a message "This device is
working properly".
Now you need to open a new com port for the printer:
1. Go to Control Panel and click printers & faxes.
2. You will see an icon there with the name of your printer, make a right
click over it and go to Properties.
3. Select the Port tab and on the display menu select Virtual USB Port.
If you have more than one select no. 1 first. If it does not work, select
Virtual USB Port, and so on. (The virtual port will depend exclusively on
what the printer requires).
4. Click Apply and try to print a test page.
I first hooked this up putting the USB cable into a port on the front of the computer and it worked fine. I then moved it to the back of the computer and it did not work, so I just had to go to the process again until I found a USB prt that worked. It has worked just fine ever since. This solution was given to me by Dynex Prodlucts customer care team. I am no techie and don't understand any of it, but I can follow instructions and it was successful. Gool luck.
Oct 02, 2009 | HP LaserJet 5p Printer
Vista will not print to HP Laserjet 5p
I purchased a Dynex USB to Parallel Converter Cable from Best Buy and tried to connect but had no success. I then sent an email to Dynex customer service and received a reply in about 24 hours. The rep provided spot on instructions which I was able to follow to a tee. My 14 year old HP Laserjet 5P is now ready to run until it blows up.
I spent hours searching web forums and only received overcomplicated replies by people who think they are techies, none of which worked. I am 63 years old and not a techie, so if I can do it, anyone can. I have saved the email and will forward this straightforward simple fix to anyone who needs it. My net cost was $36.00 for the cable.
Sep 05, 2009 | HP LaserJet 5p Printer
HP Laserjet 1160 and Vista
Download update from HP on Vista.
Jul 11, 2009 | HP LaserJet 1160 Printer
New Dell Inspiron connected to HP 820Cse printer. Won't print.
I've not worked with one of these cables before, but here's what I would do: Right-click on the printer icon and go to properties. You'll be looking for the tab that says "ports." Open that tab and see what port the computer thinks it's using for the printer. Chances it says it's using a parallel port, but it is in fact, using a USB port. I can't tell you which to choose without looking at what you see, but I think you might find one that makes reference to a USB port with a parallel connection of some type. Try clicking on that and see if your situation improves.
Feb 24, 2009 | HP DeskJet 820Cse Printer
Have to keep setting up HPLJ 5P on a USB port everytime I print!
1)right click the my computer icon
2)click properties and then click hardware n go to device manager.
3)uninstall all usb ports and then scan for hardware changes
4)ur pc will detect your printer and ask for printer drivers
5)re load drivers and your pc will communicate with your printer
6)for reloding install the cd follow the instructions on the screen and click next
7)restart when the printer is loded.connect the wires and cords properly.
Nov 29, 2008 | HP LaserJet 5p Printer
HP LaserJet 3550 spits out blank paper when job sent from computer but prints fine when printing directly from printer
Try connecting the printer via the USB port on either one of the computers. Then test if the machine prints fine then likely possibility is that the Network interface card is faulty remove the network card and install in a different slot and test. If the same thing happens then reinstall the drivers and test.
Hope this helps
Thanks J
Jan 27, 2008 | HP Color LaserJet 3500 Printer
HP LaserJet 5p Printer Logo
157 people viewed this question
Seeker5211
Seeker5211
