Question about Amana ABB222ZDES Bottom Freezer Refrigerator
Refrigerator door gasket needs replacing.
The door gasket on my Amana ABB222ZDEB refrigerator is breaking apart and needs to be replaced. Is this something I can do myself?
    Problem Solver:
  • 14 Answers
Yes.. costs is about $100.00 for a gasket (bought from an appliance store- add 4-6 hours of frustration trying to get the !@#$%^&* gasket to seat flat against the door frame.. Then call the appliance store.. probably about another 75-100$ to have them do it..
Posted on Dec 26, 2010
Can gasket for CR09FFW be replaced?
if you are referring to the door seal ( sometimes called a gasket) yes it can be replaced by a new genuine item or in some areas there is a private operation that goes around making door seals to fit and are fitted as part of the price
look in the yellow pages (business directory ) for refrigerator repairs or refrigerator door seals
Note here - although you may contemplate doing the job your self , some old seals are glued in and need knowledge as how to remove it , and the door will some times go out of shape when the door shelves panel is removed so it is best to get in a professional to do the job
Nov 11, 2015 | Crosley Refrigerators
Water drops under top door always!
That is strong indication that the magnets inside of the door gasket(s) are weak and aren't holding tight to the door to seal it. The door gasket(s) need to be replaced.
Gene
Aug 05, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
I have an Amana side by side refrigerator model SXD225SW and the other day water began leaking from underneath the refrigerator. As the couple of days have worn on, it seems as though the amount of water...
Move the refrigerator out from the wall and look for the location of the leak.
Step 2
Check the side panels and the seals around the door for beads of "sweat." This could indicate a condensation problem.
Step 3
Check the floor. A puddle there could indicate a missing or cracked drip pan, or a leak in the water line that feeds your ice maker.
Step 4
Check for water seeping from the front of the freezer or the refrigerator. This could indicate your defrost drain is plugged or your ice maker is leaking.
Fixing a condensation problem
Step 1
Check that the doors shut correctly. Hold each door about halfway open, then let go. If the doors don't shut completely, adjust the screw legs on the front of the refrigerator so the unit tilts back a bit. With adjustable pliers, turn each leg one revolution clockwise. Recheck the doors and, if necessary, repeat the process until they shut securely.
Step 2
Inspect the door gaskets. Look for debris that may keep the doors from shutting. Also check for cracks or gaps in the gaskets that could allow the cold air to seep out. If you find debris, clean the gaskets with warm, soapy water. If you find cracks or gaps, you'll need to replace the gaskets (see How to Fix a Refrigerator That Cools Poorly).
Step 3
If your refrigerator is equipped with a door-frame heater that evaporates condensation, make sure the heater is turned on. The switch should be located with your other refrigerator controls
Hope this helpout......
Aug 15, 2010 | Amana SXD524VW Side by Side Refrigerator
Amana refrigerator door gaskets not inflated and do not seal prop
you might need new door seal :
Refrigerator gasket Number: 67003548 70$ and see if it EZ to replace...good luck
Jan 01, 2010 | Amana ABB1927DE Bottom Freezer...
Amana refrigerator door gasket Model #sr22gl
You may wish to contact the folks at RepairClinic.com. They have a large selection or repair and replacement parts at a fair cost. You'll need to know your brand name, model #, serial #, and the approximate age of the appliance.
Jul 24, 2009 | Refrigerators
Door gasket repacemrnt
call marcone appl parts they will ship it to you give them mod #
Jul 05, 2009 | Amana Refrigerators
Amana 22 side-by-side refrigerator, freezer door opens slightly
There are three possibilities to this problem:
1. Door seal which should be magnetic is faulty.
2. Ice maker caddy (container) has not socketed properly into ice maker rear drive tang.
3. Door stay closed plastic hing pieces are damaged. These are tapered pieces that fit in hinge area that allow door weight to help close and hold door. Some are black in color and some are white. As far as I know they are interchangeable.
Jul 17, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Amana bottom freezer refrigerator
could be the cause. check by putting a slip of paper between seal and cabinet and with door shut, check paper is gripped all round the door. if it is not, try warming the seal with a hairdryer in the faulty place and pulling the seal out gently. many of these seals are foamed in and impossible or v dificult to replace. check also that the hinges are not worn
Jun 14, 2007 | Amana ARB2257CSR Bottom Freezer...
Amana ABB222ZDES Bottom Freezer Refrigerator Logo
134 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
