Question about Epson PowerLite 830p Multimedia Projector
I am having a problem with my Epson 830 projector, i see a black spot (a big one) when i project it on the screen or a wall. the power is working fine and everything else is also OK as i was able to play a movie but that black spot had been a distraction. please provide help on what to do.thanks.
  • 5 Answers
SOURCE: Epson projector issue
I've found my solution. My troubleshooting info said to go to "signal" and make sure that "auto" was turned on. However, I couldn't find "auto" when I first tried. There are two places where signal comes up. The second one is under "set-up" and that is where you turn "auto" on. It works perfectly now. I hope this helps. For the icons, make sure you have "mirror image" turned on in your displays preferences if you're on a Mac. Good luck.
Posted on Jan 06, 2008
  • 3 Answers
SOURCE: computer screen doesn't project onto wall
There is a function f-key combo that you need to toggle on your laptop. I'm assuming that you are just using a laptop. Depending on the manufacturer, the f-key will have either a square with a line beside either side. Maybe it says ctr/lcd, or it looks like two squares side by side. You will have to press the fn key at the same time as the corresponding f-key, up to three times, depending on manufacturer.
Posted on Dec 29, 2008
SOURCE: can i watch tv through my epson projector?
Yes, if your projector has a video input. Connect your projector's composite video input jack (usually colored yellow) to your video source. You said you want to use it to watch TV, so you'll want to connect it to the video output of a video tuner (such as a digital TV converter box) or a VCR with a built-in tuner. Set your projector to the video input and you're good to go! If your only tuner is your television, you'll need to check your owner's manual to see if it has an "output" jack. Some do, some don't. If yes, you're in luck. If not, try one of the other sources I mentioned earlier. Good luck!
Posted on Mar 30, 2009
zabolyx
  • 38 Answers
SOURCE: epson powerlite s4 projector is pink
I assume this is an LCD. I don't remember the s4 being a DLP projector.
This sounds like the LCD panel used for the red color has gone out. The image is made up of red, green and blue images layered upon the screen. If the red panel has gone out then there is nothing filtering out the red light in the image. This causes a nice red hue to the whole screen.
It could be a simple open and reconnect fix. I personally have never opened a projector, so I'm not going to walk you through it as I do not know how hard it would be to tinker with. It should eb a cheap fix for a true repair man though.
Posted on Apr 01, 2009
zabolyx
  • 38 Answers
SOURCE: images has a blue color across the center
Wow, 3 in a row. As described on 2 other projector issues this is very similar to those others. I'll repeat the info here.
This sounds like the LCD panel used for the blue color has gone out. The image is made up of red, green and blue images layered upon the screen. If the blue panel has gone out then there is nothing filtering out the red light in the image.
It looks like yours has just a secone of the panel dying or comming loose from it's connector.
Vivtek d510 projector has black and white spots covering 1/3 of projected image
The DLP Chip is failing .The DLP or Digital Light Projection Chip contains up to 8 million tiny microscopic mirrors that tilt to project a digital image onto the screen. These mirrors are failing causing light and dark spots to appear.Unfortunately fixing this projector is probably going to cost more than buying a new one. Hope this helps.
Jan 02, 2014 | Vivitek Office Equipment & Supplies
Epson powerlite 710 image too big for screen
Move the projector closer to the screen.
Jun 07, 2012 | Epson Televison & Video
Epson Projector Lamp Type
Bay chip reset software from ebay or another place
for epson
http://cgi.ebay.in/Printer-Chip-Resetter-for-Epson-Reuse-Your-Cartridge_W0QQitemZ110521839309QQcmdZViewItemQQptZLH_DefaultDomain_203?hash=item19bb9d6ecd
Apr 16, 2010 | Epson EMP-830 Multimedia Projector
Wonderwall projector has black spot in middle of screen
Tranlucent dark spot on Optoma image. Looks like something is on the lens.Off center--top to bottom. Cleaned lens, blew out case, changed bulb, still with dark spot.
Aug 08, 2009 | InFocus LP70+ Multimedia Projector
Epson Powerlite 710 viewing issue
the fn + f8 should tally between the 2 or 3 different connections for it
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Jul 20, 2009 | Epson ELPLP10S Projector Lamp for...
Hitachi projector model CP X260 projects yellow spot on screen
This is probably the polarizing filter. It will need to be replaced. It should not cost very much to fix.
Jan 07, 2009 | Office Equipment & Supplies
Yellow hallo problem
It sounds like it is related to the red filtered glass before the prism inside the projector. When this gets to hot, it will burn a spot on the glass that causes the yellow spot. I have seen in happen on alot of epson 53c projectors. This has a red filter that is easily scratched when it gets too hot. It will actually look burnt.
Dec 27, 2007 | Epson EMP-830 Multimedia Projector
Epson PowerLite 830p Multimedia Projector Logo
41 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
