Question about Whirlpool Dryers
Whirlpool mdl LER3634EW0 runs but no heat? - Whirlpool Dryers
  • Whirlpool Master
  • 7,482 Answers
Normally this problem is caused by the heating element being faulty.
Sometimes can also be caused by the thermostats being faulty.
If it is an electric dryer (you did not say) then you could pull the back off and check in the dryer air tube, it comes from the blower assy to the drum of the dryer. That is where the heating element and thermostats are normally located.
Posted on Sep 27, 2009
Duet. Why does it run but no heat and doesn't dry clothes?
You most likely have a bad heating element.
Try this video
Jun 10, 2015 | Whirlpool Dryers
Whirlpool Calypso Washer Mdl#30942 gets stuck during rinse cycle. Machine runs, then stops, but does not rinse completely. Last 35-38 min cycle is problematic. What is wrong and how to fix it?
It's hard to tell by your description of the problem, but it sounds like it could be the timer If it's not running while in spin mode, or as simple as a belt if it's running and not spinning fast enough.
Nov 28, 2014 | Whirlpool Calypso GVW9959K Top Load Washer
Dryer wont heat
The problem is likely the thermal cut-off and/or the high-limit thermostat if the dryer runs but doesn't heat. Verify this by bypassing the thermal cut-off and the high-limit thermostat. Click on the link below for the detailed troubleshooting.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers Running But Not Heating
Feb 18, 2011 | Whirlpool GEW9200L Electric Dryer
Whirlpool Dryer turned on all lights and selection operate. When you push hold button to start. The Dryer clicks and does nothing. All lights and selections remain same. MDL # GEW9250PW0
check for a broken belt,there is what is called a "broken belt" switch down by the drum motor inside the unit and when the belt breaks or come loose it shuts off this switch to prevent the unit from heating and running to protect against fires from no movement and air flow
Dec 18, 2010 | Whirlpool Dryers
Whirlpool Duet Mdl GHW9150PWO Washer stops
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Oct 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Dryer will run but does not heat up
Either bad heating element or missing one leg of the 240V circuit. The motor runs on 120V.
Sep 24, 2009 | Whirlpool LER4600 Electric Dryer
Whirlpool duet dryer runs but will not heat.
do you have 240 at the terminal block on the back of the dryer if so check for continuity on the thermostats , thermal fuse and heating element
Dec 29, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool Gold Range Mod GLP84900
Hi I have a whirlpool gold range mdl GJSP 84902 and had replaced the bottom hidden element after finding out it wasn't getting any heat. So replacement took a little figuring out. it ws easy after a removal of screws and pulling out the whole oven casing out fron the front. Anyhow I still don't get enough heat generate from the bottom element, what other cause are there. checked fuses wiring all is connected HELP ME PLEASE !!!!! thank you Paul
Nov 02, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
My Whirlpool Gas Dryer (MDL # LGR7648KQ1) is not drying properly. The unit will heat up initially but after a while it will not ignite. I've taken it apart and run it without the drum. It ignited...
Be sure the vent is totaly clear.if the t-stat(s) heat up from lack of air flow the heat will not return until the t-stat is cool enough.Running without the drum in place will also heat up the sensor(s).This is a very common problem.
Oct 25, 2008 | Whirlpool Dryers
Dryers Logo
73 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
