Question about Garden
Gas filter fell off
Where does teh gas filter attach. It fell off when I removed the gas cap.
I need "step by step" instructions on how to replace the fuel filter on my 2001 Dodge Ram 3500 pickup. Thanks !
Here you go if it is a diesel:
A. FUEL FILTER REPLACEMENT:
The fuel filter is located inside of the fuel filter housing
1. Unscrew and remove fuel filter cap at top of fuel filter housing. To unscrew, attach tool to 6-sided hex center of cap. Do not loosen cap at outer edge. The fuel filter cap is designed to remove filter while pulling up on cap.
2. Remove O-ring from cap and discard.
3. The filter is retained to cap with little fingers. Carefully pry a couple of them off from old filter.
B. FUEL FILTER REPLACEMENT:
1. Thoroughly clean inside of filter housing, cap, etc. with clean diesel fuel
2. Fill filter housing (canister) with clean diesel fuel. NOTE: If you do not do this, you will have to manually bleed air out of system later. No fun.
3. Snap new fuel filter to bottom of cap.
4. Install new O-ring
5. Apply lihgt film of clean diesel oil to cap O-ring
6. Load filter/cap into housing.
7. Tighten cap to 25 ft. lbs. torque. Do NOT over-tighten.
Sep 03, 2010 | 2001 Dodge Ram 3500 Truck
Location of fuel filter,its boggs down when applying gas to speed up,was told fuel filter is clogged but i cant find it
Open the gas door and remove the gas cap. This will help to alleviate the pressure in the fuel line.
  • Step 2 Crawl under the Bravado and trace the fuel line from the fuel tank. The filter is an in-line filter and attached to the fuel line.
  • Step 3 Unsnap the fuel inlet line from the filter. The filter is equipped with a quick-connect fitting that can be unsnapped and pulled off the piping of the filter.
  • Step 4 Remove the outlet line off the piping of the filter. This line can removed the same as the inlet line.
  • Step 5 Unbolt the mounting bracket holding the filter in place with a socket wrench. The bracket is held in place by one bolt.
    Replacing the Fuel Filter
  • Step 1 Attach the new fuel filter to the mounting bracket and secure it to the frame. Tighten the bracket snugly with the socket wrench. Ensure the arrow on the filter is facing toward the front of the vehicle. The arrow indicates fuel flow direction.
  • Step 2 Snap the inlet line on the filter. Push the line on to the piping of the filter till it clicks in place.
  • Step 3 Connect the outlet line on the filter. This line will snap in place as well.
  • Step 4 Screw the gas cap back on to the fuel door. Close the gas door.
  • Step 5 Crank up the SUV and let it idle. Ensure there is no hesitation or stalling
  • Jun 05, 2010 | 1996 Oldsmobile Bravada
    WHERE IS THE FUEL PUMP ON A 1994 TOYOTA CAMRY
    Fuel pump is located inside the fuel tank and is attached to the sending unit. Do not smoke or have any open flame in the work area when removing the fuel pump.
    REMOVAL OF FUEL PUMP:
    1. Disconnect the negative battery cable.
    2. Relieve fuel pressure
    3. Remove the rear seat cushion.
    4. Remove the floor service hole cover .
    5. Disconnect the electrical fuel pump wiring at the fuel pump assembly. Check for any fuel leakage while in there.
    6. Remove the gas cap, this will prevent any fuel gas spilling out of any high pressure lines.
    7. Use a fare nut wrench to disconnect the outlet.
    8. Remove the pump bracket attaching screws
    9. Disconnect the return house from the pump brackets, then pull ou the pump/bracket assembly.
    10. Remove the nut and spring washing, then disconnect the wires from teh pump bracket.
    11. Remove the sending unit attaching screws then remove the unit from the bracket.
    12. Pull the lower side of the fuel pump from the bracket.
    13. Unplug the connector to the fuel pump
    14. Disconnect the hose from the pump.
    15. Separate the filter from the pump. Use a small screwdriver to remove the attaching clip.
    16. Inspect all the lines, houses and fittings for any sign of corrosion, wear and damage to the surfaces. Check the pump outlet hole and the filter for restrictions
    17. When reassembling, ALWAYS replace the sealing gasket with a new ones. "Also replace any rubber parts showing any sign of deterioration".
    To install:
    1. Install the pump filter using a new clip. Install the rubber cushion under the filter
    2. Connect the outlet hose to the pump and pump bracket.
    3. Engage the connector to the fuel pump. Install the fuel sending unit to the pump bracket. The remainder of the installation is the reverse of the removal.
    4. Start the engine and check carefully for any sign of leakage around the tank and lines. Road test the vehicle for proper operation.
    Dec 15, 2009 | 1994 Toyota Camry
    My wife was washing some throw rugs in the HE5t and one of them fell apart in the wash. Clogged up the filter and will not drain. Door is locked so I can't get inside to clean filter and washer. How do I...
    hello, You should remove the lower panel at the front of the machine, behind there you will find what looks like a gas cap from a car right next to the pump, unscrew the cap making sure you have plenty of towels handy and remove the filter...empty the water out and clean the filter...re-install the filter trap and you should now be able to open the door. Don't forget to unplug the machine before servicing. Hope this helps, thanks for using fixya..good luck . Mike
    Aug 06, 2009 | Washing Machines
    How do you replace the fuel filter on a homelite st 145? the hose snapped and the filter fell into the fuel tank. Thanks
    Take the old piece of fuel line and have the vendor match the size. Buy 1 ft. so that you have a little extra to work with. Cut fuel line at an angle. This will allow for easier insertion into the hole in the gas tank. Feed the line through until you can pull it out of the opening where the gas cap is. Cut the line off square. Attach the fuel filter. Pull the line back through until it rests comfortably on the bottom of the tank. Assemble the trimmer. You will then get a more accurate measurement to the carburetor.
    Jim
    Jun 10, 2009 | Homelite Garden
    2003 yamaha v-star 1100 gas cap assembly instructions. The screws fell out of my gas cap and the gas cap fell apart. I need to be sure that I have all the parts out of my gas tank. I need a gas cap...
    You are probably not going to find assembly instructions. If you can't find all the parts or screws then get another cap. Google " motorcycle salvage yamaha " and you can probably find one at a much lower cost than the dealer would give. By the way, forget any loose screws in the gas tank. The stuff can not get past the fuel valve and filter and are not going to hurt anything.
    Please rate this answer. Thanks!
    May 01, 2009 | 2003 Yamaha V Star 1100 Classic
    I recent got my purse stolen with all of my keys in it. that also includes the gas cap key for my 1997 dodge neon. I had a spare key for the door and ignition. but i now need gas and i have no key! what...
    you may need to call a lock smith. if you attempt to remove the cap by force you will damage the filler neck adn cause an evap system leak. if you cut the cap off i would be concerned with debris falling into the fuel tank and causing drivability problems not to mention the possibility of making a spark at the top of you fuel filler neck,.... well you see where that is going. maybe there is a number stamped on teh cap near teh key hole that would be helpful to teh locksmith.
    Dec 13, 2008 | 1997 Dodge Neon
    Genral oil change
    1.Get your supplies ready and expose your engine 2.Unscrew the Oil Filler Cap 3.Remove the Oil Drain Plug 4.Remove and Replace the Crush Washer 5.Clean the Oil Drain Plug 6.Remove the Oil Filter 7.Remove and Clean Plastic Mesh Filter 8.Lubricate the O-ring of the New Filter and Attach it to the Engine 9.Motorcycle Oil Change - Replace Oil Drain Plug & Plastic Mesh Filter Pour Oil 10.Check the Oil Level,,
    Nov 10, 2008 | 2000 Gas Gas Pampera 320
    Genral oil change
    Nov 10, 2008 | 2007 Gas Gas MC 125
    Garden Logo
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
