Question about Bushnell Trail Sentry 11-9200 Digital Camera
Camera has new batteries and takes password. registers 1 on counter but then shuts off and does not take any pictures
Memory contains no images
Is the card inserted properly?At the side of the card take the lock off.When taking a picture check the camera counter after the shot to see if the image registered
Oct 21, 2012 | Nikon Coolpix L110 Digital Camera
The camera will only take pictures on one or two of the setting from the top, when you turn the clicker on the top of the camera it will take a picture, when you go to shut the camera off with out pushing...
I understand you issue as; the camera only takes about 1-2 pictures and then it shuts itself off.
This could be a direct result from using the wrong battery type
Please make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
Thank you
Jan 21, 2010 | Kodak EasyShare C360 Digital Camera
My camera stops working but the battery showed full.
Those are the symptoms of a battery that has been charged many times or has been allowed to completely discharge once or twice. Try some new ones.
Jan 06, 2010 | Panasonic Lumix DMC-LZ2 Digital Camera
After taking 2 pictures with my camera, it shut off
Yeah your correct there might be a problem also in the battery., are you using the battery came form the box of your camera? or using the recommnded battery KODAK Li-Ion Rechargeable Digital Camera Battery KLIC-7001 If yes you may call kodak toll free 1 800 235 6325, It means that your camera needs of service
Nov 01, 2009 | Kodak EASYSHARE M1063 Digital Camera
Despite changing batteries constantly, camera wont work properly. With fresh, new AA batteries, camera will take 1-2 pictures and then low battery light comes on , then camera shuts off
hi, this can be happening due to some bad battery contacts in the camera. take some cotton buds and clean the lower and upper contacts of the camera. this will help you. else revert back to us. thank you sweet rascal
Oct 18, 2009 | Canon PowerShot A75 Digital Camera
Camera keeps shutting down
Yes, that's sounds like a main board.
Mar 18, 2009 | HP Photosmart M417 Digital Camera
Replace battery sign in New canon A590si camera.
You're using the wrong batteries. You need to purchase lithium batteries. They are quality batteries for high powered, battery operated electronics. Personally, I have a battery charger and use rechargable duracell batteries. (HR6/ DC1500/ NiMH/ 1,2V) Gives you approximately 16 hrs before having to recharge.
Dec 01, 2008 | Canon PowerShot A540 Digital Camera
Events taken
Events are not the same thing as pictures. I am not sure what makes the event counter move but I have 17 of these cameras and have used them for several years and most of my cameras have over 1500 events. I think an event is logged when it takes the first photo but an animal can remain in the area taking more photos which will show on the picture total. The evnt counter must have to be dormant for some period before it will register as a new event. Let the camera cycle through each counter and I believe the picture total is displayed after the events.
Don't worry about your event counter just the picture counter. I hope this helps.
Nov 28, 2008 | Moultrie MFH-DGS-200 Digital Camera
Camera goes into Shut Down Mode & Flashes the Letter H
Hey sonax,
This H error message means either the film is loaded incorrectly, or there is an internal malfunction in the camera. To determine if the film is loaded incorrectly you should take the film and the batteries out of the camera then reinstall the batteries and try taking a picture without film in the camera. If the camera allows it then the film was loaded incorrectly and I would refer to the camera manual for directions on how to load the film correctly. If the H error message persists then there is most likely an internal malfunction and I would have the camera looked at by an authorized service technician. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 23, 2008 | Canon Sure Shot 65 35mm Point and Shoot...
No picture
it seems that the flex ribbion cable from the camera body to the lense assembly is damaged. A good repairer can replace it.
Oct 28, 2006 | Samsung Maxima 120Ti 35mm Point and Shoot...
Bushnell Trail Sentry 11-9200 Digital Camera Logo
67 people viewed this question
Top Bushnell Cameras Experts
Johnny Massengill
Johnny Massengill
Are you a Bushnell Camera Expert? Answer questions, earn points and help others
