Question about Midland 1001Z 40-Channels Base CB Radio
Receivers complain about squeeling noise from my midland 1001z when I transmit. Is this an RF Gain setting problem?
I had the same (squealing) problem on transmit with the Midland 1001Z when I used it indoors as a base unit. The problem was my power supply: it broke into oscillation when drawing more than 150 mA at 13.8V. The 1001Z draws about 150 mA on Receive, and much more (but only about 900 mA) on Transmit. If using the 1001Z as a base unit, I suggest you power it with a fully-charged car battery indoors, or test your power supply to check if it can't supply the required 1 Amp, approx., on Transmit. It's a GREAT radio, just give it a good power supply. My power supply was defective out of the box, but now I have a good one and get great reports on signal strength and audio quality. Remarkable, for the low price and 3 year warranty. Good luck!
--Sky Junkie / Tucson, AZ / USA
Posted on Oct 12, 2009
  • 23 Answers
No, the RF gain control is a receive function on your end. It likely a problem with your mic.
Posted on Oct 09, 2009
Midland 1001z cb wont come on
check fuses and reverse polarity diode and also turn radio to on position ,SQuelch turned all the way to left and RF gain all the way to right.
Jun 08, 2012 | Midland 75-822 40-Channels Handheld CB...
I can,t transmit or receive signal antena is ok
Does radio show receive or transmit on display or meter?
Mic has been tested and or eliminated as the problem?
Apr 26, 2012 | Midland 1001Z 40-Channels Base CB Radio
Would like to know the proceedure for mod limiter clip and mod peak, seems to have plenty of receive with the RF Gain.
that is one of midlands big secrets. they want to do the work on their product so they will only release certain manuals for certain radios. unfortunately the 1000 z isn't one of them. Hey I mean I have a 9001z and midland told me they don't have service manuals for it.
Nov 02, 2010 | Midland 1001Z 40-Channels Base CB Radio
I can't transmit, but I can receive signals
Hi,my name is John. Start with checking your Squelch and RF GAIN wide open. Check that your antenna is grounded good and no metal objects are blocking it. Turn the MIC GAIN to MAX. Key the Mic, the needle should move or a light should come on. Try another MIC. if it doesnt. Let me know how it does, could be something internal that I can help you with.....hope this was very helpful...
Sep 02, 2010 | Midland 1001Z 40-Channels Base CB Radio
I have a midland 1001z cb radio with a magnetic mount attenna by cobra. When I transmit receivers are getting a lot of squealing. Before I bought the midland i had a radio shack cb which worked find.
is this same antenna as before. you should always check the SWR's to see if set correctly.. other than that. bad grounds, bad microphone can make any radio squeal..
Nov 27, 2009 | Radio Communications
MIdland no sound s/rf dancing
may be u burned yr final transistors...check if yr antenna is well grounded and try just after this to transmit, if the indicator is not stable on the green area when you are in "am" modulation stop to try and bring to the assistance
rgds Stefano
Dec 17, 2008 | Midland 1001Z 40-Channels Base CB Radio
"squeak" when transmitting
Make sure you have a good ground for the radio and antenna. How long is the antenna coax if a little to long and you have extra what did you do with it coil it if so uncoil it and lay it out try it. If no luck I would shorten the coax and recheck your SWR.
Jun 22, 2007 | Midland 1001Z 40-Channels Base CB Radio
Midland 1001Z 40-Channels Base CB Radio Logo
373 people viewed this question
Top Midland Radio Communications Experts
Steve
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
