Question about HP Computers & Internet
NEED TO REPLACE LEFT SIDE TOUCHPAD BUTTON ON DV5Z STILL WORKS BUT IS VERY LOOSE
    President:
  • 2,600 Answers
Most likely it is more convenient to just replace the entire palmrest. The palmrest has to be taken off anyway to get to the touchpad and buttons. Palmrest assemblies go for around 25 bucks on Ebay.
Posted on Sep 27, 2009
Left buton in touchpad in hp probook 4530s doesnt work
Sounds like a faulty switch under the button. Have a look on ebay for a replacement.
Feb 10, 2014 | HEWLETT-PACKARD ProBook 4520s
Right side of the mouse pad doesnt work
Unfortunately your touchpad is damaged and will need to be replaced. Most likely this will mean replacing the entire bottom chasis of the unit.
Nov 06, 2013 | Compaq Presario Cq56-219wm
Touchpad not working
it looks as if the touchpad cable is loose or faulty , first disconnect the keyboard and try if touchpad is working if it is working u need to replace the keypad
Sep 14, 2013 | Dell Vostro 1520 Laptop
Emachine E725 touchpad does not work
The eMachines E725 has a built in switch to toggle the touchpad on or off by the touch of a button. Look at the button to the left of the main power switch. You'll notice the icon looks like a hand touching a rectangle - or touchpad. if this button is lit up, the touchpad is turned off. simply press the button to toggle the touchpad back on. The light on the button should now be off.
It's that simple. I hope this helps.
Apr 14, 2010 | Acer Aspire 3000 Notebook
My touchpad buttons do not work
hi locate the FN key on lower left side of keyboard next locate the touchpad key usually one of the F1-F12 keys,press and hold the FN + the touchpad key together and release, now check the touchpad.
good luck,
let me know how it turns out.
ken
Apr 04, 2010 | Dell F3534 Touchpad
Fix left click on built in mouse
If you're talking about the touchpad, then I'm afraid that no; it's not easily replaced.  The most probable thing that's happened is the microswitch underneath the button has worn/broken.  You not only have to pretty well completely dissassemble the keyboard part of your laptop, but it's a tricky job when you get there.
The best solution is to get an external USB mouse and use that.  It's a bit late to tell you this, but using an external mouse to take most of the wear is the best thing to do anyway...save the touchpad for when you have no other choice.
Mar 07, 2010 | Gateway M-7315U Notebook
Thin and wide white lines on screen
Yes, your screen most likely is going bad, the only other reason for lines and distortion is a loose data cable that runs up the back of the lcd panel on the left side. For the touchpad, go to the control panel > Mouse > look at the top of the window and look for the device properties. open this tab and look for your touchpad listed. Highlight it and click on the settings button. Go through these settings and make sure that tapping is enabled. Even if it is, you may consider updating the drivers for the touchpad.
Jan 18, 2010 | Compaq NC8000 Notebook
THE LEFT BUTTON LIGHT STAYS ON ON THE TOUCHPAD
this is due to a faulty touchpad. it needs replacement. call the manufacturer.
Aug 04, 2009 | Advent Netbook
"sticky" mouse on compaq laptop
Unless your left mouse button has been severely damaged, it is unlikely that a loose button is the cause of your problem. More likely, it is your touchpad. Chances are your touchpad is set to click when tapped. Oversensitive touchpads can click randomly when you're dragging your finger across the touchpad.
To test this, position your cursor over a link (or other button) but don't press the left mouse button. Instead, lightly tap the touchpad itself. If the link or button is clicked, go to your Control Panel and adjust the Mouse options so your touchpad no longer clicks when tapped. It's usually a setting titled "tap to click" or something along those lines.
Regards,
Javabytes
Nov 07, 2007 | HP Compaq Presario V2000 Notebook
Touchpad button loose
I shouldnt think that opening it up is necessary. The button should click back in with a gentle nudge. Else it is broken and needs to be replaced. If you can take it out completely and examine it you will know if it is broken.
Sep 30, 2007 | Acer Aspire 5100-5033 Notebook
Computers & Internet Logo
181 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
