Question about Garden
I tried to start my honda gc 190 and noted the air
I tried to start my honda gc a90 and noted the air intake was filled with engine oil. cleaned it out and the carb and all seems ok what would have caused this
    Problem Solver:
  • 18 Answers
Worn rings or valves and valve will do it.
Also over filling the crankcase with oil which is most likely because it is a common error. Especially if it is not a high mileage bike.
Hope this helps!
Rob
Posted on Sep 27, 2009
Why is the oil in my honda gc 190 grey
grey oil is water contamination. check for leaking seals to stop water getting to the oil
May 21, 2015 | Karcher 3000 PSI Gas Pressure Washer with...
Pressure washer was working fine then it shut off. and now I cant pull the string
Whoa! Wait when water pressure is at hose you have to pull the trigger on wand to release pressure so the engine can turn freely. It has so much pressure at wand that it will not let you turn enging over. If not It may have froze up. Check the oil first , no oil then it is locked up. If not you can remove pull rope cage and try to turn it manually.
Oct 01, 2014 | Garden
Honda gc 190 starts then floods and stops. Wont start again till plug is taken out and dried then repeats same thing
Float level or a sticking needle valve, check float level as if it is adjusted incorrectly it can cause the main jet to allow fuel to flood through, the needle valve can do the same.
Jul 28, 2014 | Honda Engine Gc160 Gc190 Gcv135 Gcv160...
How do you replace the honda gc190 decompression mechanism
This is a problem with GC-160 and GC-190 engines on pressure washers, tillers, etc. Once they get some hours on them and as things seat in-wear in, they get to a point you can not pull the start cord. If you remove the spark plug, the engine turns easily. The valves need adjusted. The valves are set .005" to .006" off the seat. This allows enough compression release but the engine runs. I find the valves need adjusted every 25 hours, not the 100 hours Honda states.
Mar 16, 2013 | Karcher 2500 PSI Pressure Washer
Honda GC190 can't pull starter cord
This is a problem with GC-160 and GC-190 engines on pressure washers, tillers, etc. Once they get some hours on them and as things seat in-wear in, they get to a point you can not pull the start cord. If you remove the spark plug, the engine turns easily then the valves need adjusted. The valves are set .005" to .006" off the seat. This allows enough compression release but the engine runs. I find the valves need adjusted every 25 hours, not the 100 hours Honda states.
Aug 29, 2012 | Honda Garden
Troy built mower honda 160 engine oil leak around governer shaft. no oil seal but shows one on parts breakdown. Can not find part number for shown seal.
Drain oil from mower until proper level. Remove spark plug and pull starter rope several times to blow out cylinder. Spray starter fluid in cylinder pull rope several times to clean out. Replace fouled plug with new spark plug. Remove air cleaner, ensure no oil present, replace filter as needed. Clean air filter box with carb cleaner. Install new air filter reattach filter cover. Prime engine, pull starter rope 1/2 way 4 times to help prime, then pull starter rope fully up to 10 times to start.
May 24, 2012 | Troy Garden
I have a honda dx 1987 it starts up blowing blue smoke we replaced the valve seals and gaskets
In order to get the best gas mileage the Honda motors only have one compression ring and a oil control ring on the pistons. If the oil wasn't changed regularlly then it's time for rings after about 120 thousand miles. they all use a little oil because of this one ring system, about a quart in 1000 miles, even when new. When doing your work did you clean the valve cover real good? the cover has the baffles for the oil control of crankcase blowby and as they fill up with carbonized oil the baffles in the valve cover instead of separteing the air and the oil start passing oil into the PCV systema and into the air cleaner and into the air entering the air intake of the engine gets burned in the combustion gases and out the tailpipe.
Mar 08, 2011 | Honda Accord Cars & Trucks
My mother-in-law put gasoline in the oil fill spout. tiller sat like this for 6 months. was not started. I have drained oil/gas, but still can't get to start
This is a new for me. I suspect that removing the spark plug to put a squirt or two of engine oil on top of piston to lubricate and raise the compression would be a good start. Insure that the spark plug is clean and dry and sparking when pulling the starter rope. Reinstall spark plug and try again. If no success remove air cleaner and with choke open and throttle open give a short squirt (1/2 second only) of ether in intake orfice and start right away. If engine wants to fire the carb. is plugged up with old fuel and will most likely need to be cleaned our rebuilt. Note: 6 months in storage with the fuel not drained or at least stabilized is a major cause of small engines that will not start.
Feb 21, 2011 | Garden
Honda engine will not start,,,new plug, new gas, new oil
Karcher Model G2650 OH with Honda 6.0 HP, GC 190 Engine. Engine won't start. New gas, has spark. Seems to flood instantly. Much gas in cylinder. Spark plug wet. Choke pulled out, power on. Oil OK. released pressure in line. Where can I down load a Honda Engine manual! Thank you !
Jul 06, 2010 | Karcher 2500 PSI Pressure Washer
Garden Logo
276 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
