Question about Broncolor Cameras
Baroncolor impact 41 flash tube need replacement of flash tube.
Baroncolor impact 41 flash tube, need replacement.
Flash wont pop up err05
Usual cause is either spillage or impact to the flash unit. Most spillage is on the two flash pivots. Pull on top cover when it is attempting to go up to free it and remove the screws underneath and pry off the flash cover. You can now reach the pivot screw (many times rusted - remove, scrape off rust, and put on grease and re-install). BE VERY CAREFUL. THERE IS 300 VOLTS ACROSS THE FLASH TUBE AND YOU CAN GET A NASTY SHOCK!!!!
Oct 02, 2013 | Canon EOS 600D Rebel T3i Digital Camera
Built in flash clicks but wont engage on canon xti
Usually caused by sticky liquid spillage around the pivots of the flash or impact. If liquid, manually pull up on the flash when it clicks to free the flash, and then remove the three screws holding the flash cover. On the right side is a spring with a screw inside it. Carefully remove the screw and check for rust. You can scrape off the rust with an Xacto knife and then clean the hole with a Qtip with Windex, then put some grease or Vaseline on the screw and see if the flash moves smoothly. Also clean off the flash and base with the Qtip and Windex to get rid of any sticky liquid.
Be very very careful! There is 300 volts across the flash tube!!! Do not touch the flash tube where the wires are soldered to it!!!!!
Sep 26, 2013 | Canon EOS 400D / Rebel XTi Digital Camera
Nikon D5000 flash issue
Sounds like the flash tube is bad. Another possibility would be a bad flash capacitor or circuit. Has the camera been impacted - especially around the flash?
Another possibility is that the light tube that goes from the frame around the tube to the sensor further back in the flash base has come loose or impact has broken the frame.
Pop up the flash. Underneath there are two screws; remove the screws, push the flash back down and using a slim piece of metal pop off the flash cover. You can then see the tube and the light pipe (looks like a thick black wire) and the sensor located at the back on the right.
Be very careful. There can be over 300 volts across the flash tube - do not touch!!!
Apr 30, 2013 | Nikon D5000 Digital Camera
Broncolor Impact 41. The modeling lamp does not work.
You have this posted in the wrong product category, please re-post.
Jun 05, 2012 | Cars & Trucks
Runs but when you try running on a nut it just blows air. should the plates and drum be greased when rebuilt?
The air motor on the 285B needs to be oiled, the hammer section needs to be greased. The symptom described could be in the hammer mechanism, 285B's have 2 different side plates (item# 41) that sit atop the hammer mechanism, tools made from 2005 to 2007 use the old style side plate (item# 41) that has a small lip that need to sit looking toward the hammer case bushing (item# 44) when installed with the small lip facing in to the hammer will cause it to lock, tools made from 2008 to the present have a side plate that is flat on both sides and can be installed in either position. also check the hammer and anvil for cracks and pitting.
Follow this link to view the parts list.
http://manualarchive.ingersollrandproducts.com/ir_pdfs/Tools/Vehicle%20Service%20Tools/Air%20Impact%20Tools/80162944.pdf
Jun 01, 2011 | Ingersoll Rand Ingersoll - Rand 285B - 6...
Broncolor Impact 41 fires by itself.
Ir sensor causing self flashing.Press sensor button to switch off Infra red sensor unit will stop self flashing.
Feb 28, 2011 | Broncolor Cameras
Our Monitor MPI 41 model heater won't stay on. It flashes 88:88 in the time/temp window and the Burner status flashes high. When we shut it off (power down) and power it back on it works until it reaches...
Mine is getting fuel, but it still clicks off like the original post stated, and its clean. The only other thing .. that water in the tubing. We get a TON of watered fuel here in Alaska! Damn oil venders.
Dec 31, 2010 | Heating & Cooling
My 2004 f 150 airbags light stays solid for a couple of seconds when I turn the truck on then flashes 4 times then its off then it flashes 2 times then 4 then 2 what's the problem
A LFC ( light Flash Code ) 42 is the front impact severity sensor on a 2004 New Body Style ( should not get this LFC on a 2004 Heritage or Lightning ).
The Front impact severity sensor is located on the center radiator support, open the hood and you will find it next to the ambient air temperature sensor.
The part number is 6L3Z-14B004-AA
You might find cleaning the connector might work, but usually it is a case of the front impact severity sensor is corroded inside the sensor itself, and needs to be replaced.
Jun 20, 2010 | 2004 Ford F150
96 marquie air bag flashes code 41
This code is center right impact sensor circuit opened .Check for corrosion .
Aug 09, 2009 | 1996 Mercury Grand Marquis
Cameras Logo
119 people viewed this question
Top Broncolor Cameras Experts
Are you a Broncolor Camera Expert? Answer questions, earn points and help others
